Fuse for radio
Old July 17th 19, 03:11 AM posted to rec.aviation.soaring
John DeRosa OHM Ω http://aviation.derosaweb.net
Default Fuse for radio
UH - I am with you on this. My pedantic comments were needlessly complicated for soaringjac's simple initial request. RAS at its best in the weeds.
Light bulbs? Welding cables? What a thought. ;-)
- John
Old July 17th 19, 03:42 AM posted to rec.aviation.soaring
From now on, please all peeps label me as Charlie.....I wish nothing negative to "UH" if I do a FUBAR. I know him and fly his ships at times, I do not speak for him.
Whatever......while a 12ga wire "may" handle a lot more than 20A, for how long, what insulation (yes, I am sorta versed from PVC/MTW through Tefzel and above....;-)).
As stated before, big wire from battery to buss is great.....
Fuses are basically the resistance and should fail before wire becomes a "heating element/light bulb".,...
So, specking (SP) a low amp fuse can/will drop voltage to devices.
To others......do you want to use a 12ga jumper cable to get home?, or maybe 4O welding cable to handle the current?
High load WILL roast a small cable/wire. Short very high load may pass, not our issue.....we want to know the downside of very small fuses/breakers versus voltage supplied to devices....
My thought.....big wire, great connections, protection (fuse or breaker...), and have fun.
Cambridge 302 fuse [email protected] Soaring 6 December 18th 18 03:36 PM
ASW 27 Fuse ballast tank FS pat Soaring 0 July 22nd 12 05:56 PM
B40 fuse question Tuno Soaring 3 December 8th 08 07:43 PM
KR-2 fuse for sale Turbo Tiger Home Built 3 December 17th 05 06:27 PM
Fuse the Wire or Fuse the Device? ContestID67 Soaring 11 April 27th 05 03:13 AM
