FS Dittel FSG2T radios fresh from overhaul
Old July 17th 19, 03:14 PM posted to rec.aviation.soaring
Default FS Dittel FSG2T radios fresh from overhaul
Curious, why is it a better radio ?
Dan
On Wednesday, July 17, 2019 at 2:35:50 AM UTC-4, wrote:
I bought a 2T from Ross.
If you have an FSG-71, it is a direct replacement and is a much better radio.
Old July 17th 19, 05:55 PM posted to rec.aviation.soaring
Europe went to a smaller freq spacing a few years ago....thus, many EU radios are "junk" since they can't handle the freq spacing.
For at least the US, they are perfectly fine and likely way better than older US radios....
Sooooo........newer radio that matches US/FCC rules but not EU rules.
At least, my understanding. Research before buying, but I believe I am correct.
Old July 17th 19, 06:30 PM posted to rec.aviation.soaring
JS[_5_]
Dan
The digital encoder on the FSG2T doesn't work well if dirty, like digital encoders on other equipment. It's easy to clean. I recommend the same stuff as in the CAI303 thread:
https://caig.com/product/deoxit-d5s-6/
Remove the radio, remove the dual concentric knobs, undo 4 screws, remove the face, squirt, replace everything.
Besides being easier to set up microphones and having variable squelch, the FSG2T deals with noise from USB stuff much better than the FSG71M.
Perhaps the 71M predated USB stuff in the cockpit?
Old July 18th 19, 12:05 AM posted to rec.aviation.soaring
Dan
I replaced my 71 with a 2T from Ross and the fidelity was much better.
As Roy says, the channel selector switch can be a weak point though. I understand it is more susceptible to external mechanical impacts.
Old July 23rd 19, 08:59 PM posted to rec.aviation.soaring
Ross[_3_]
Only 5 left.
Old August 14th 19, 12:59 AM posted to rec.aviation.soaring
On Tuesday, July 23, 2019 at 12:59:17 PM UTC-7, Ross wrote:
Only 5 left.
I am interested in 2 radios for my club. Please contact me....
-mike
F.S. Dittel FSG2T Set Ross[_3_] Soaring 1 March 1st 16 05:42 AM
FS: Dittel FSG2T Ross[_3_] Soaring 2 February 1st 16 06:32 AM
FS: Dittel FSG2T Romeozulu Soaring 0 March 31st 15 08:48 AM
Turnaround time for Dittel FSG2T Radios Charlie Papa Soaring 3 December 1st 10 11:10 PM
Service Bulletin on Dittel FSG2T Radios Paul Remde Soaring 0 September 9th 10 05:31 PM
