Seeking head rest for ASW-20C - or a cheap chiropracter : )
Old July 18th 19, 10:38 AM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
Quote:
Originally Posted by Dan Colton View Post
I love my ASW-20C but one thing is missing. A baby soft fuzzy headreast to lean into against those full-rack black-out pull ups, and barf your guts red-out push overs. I need one of those soft lams wool pillows attached to a decent frame to configure the perfect head rest. Does anyone has a lead? Is anyone selling a damaged ASW-20 for parts and has a great headres. Is anyone a lexus parking lot attendant and has access to ..... I won't tell..
DC
Until you find the perfect headrest roll up a piece of memory foam. Works for me .
Old July 18th 19, 03:25 PM posted to rec.aviation.soaring
Dan Marotta
Default Seeking head rest for ASW-20C - or a cheap chiropracter : )
I made a headrest once by stitching together two wash cloths and stuffed
the pillow with foam.Â* Wasn't the greatest looking, but worked great!
Or you could swap that '20 for an LS-6.
DC
Works for me .
Dan, 5J
Old July 18th 19, 10:33 PM posted to rec.aviation.soaring
DC
Works for me .
Delta8
The issue with memory foam is it gets very hard at cold temps. But you don't want to use something bouncy that will cause your head to rebound if you crash. I'm using some foam (type unknown) that seems to absorb some energy but isn't so cold sensitive. Memory foam works great for seat cushions because our body heat keeps it warm Not the same for headrests.
Chip Bearden
Old July 18th 19, 11:07 PM posted to rec.aviation.soaring
JS[_5_]
DC
Works for me .
Delta8
Chip Bearden
Weren't the ASW20C headrests a Mercedes part?
Old August 18th 19, 04:01 AM posted to rec.aviation.soaring
What is the purpose of that headrest anyway? I have flown without headrest for years, but I just purchased an LS8 with a nice soft headrest. I have four flights so far, and other than leaning my head way back to touch the head rest a time or two, I have no idea that it’s been there. Am I missing something? Or is it just to prevent whiplash caused by aggressive winch drivers?
Old August 18th 19, 08:07 AM posted to rec.aviation.soaring
[email protected][_1_]
It’s for the brief nap when you have glide on home 75 miles out.
Or to prevent the crap in the baggage compartment from hitting you in the head in turbulence or a rough landing.
Old August 19th 19, 02:08 AM posted to rec.aviation.soaring
Dave Nadler
On Saturday, August 17, 2019 at 11:01:29 PM UTC-4, wrote:
What is the purpose of that headrest anyway? ...Am I missing something?
Same as in your car:
Headrest is to prevent whiplash injury after forward impact.
Old August 19th 19, 09:42 AM posted to rec.aviation.soaring
Hmmm .... every case of whiplash I treated over the years followed a vehicle rear end impact where the recipient occupant's head went back then whiplashed forward. Of course they were all relatively minor injuries since all cars have head restraints nowadays that absorb some of the energy and also limit the initial backwards extension of the neck.
If you want to protect your neck in a glider front end impact you would need something like an F1 style HANS device - although in a typical glider serious accident there is little point given the likely state of the rest of your body.
Old August 19th 19, 01:11 PM posted to rec.aviation.soaring
Dave Nadler
back then whiplashed forward....
Right, injury would be more common in a car from a rear-end hit,
in a glider the headrest is to prevent injury on the rebound.
Or so it was explained to me...
Typhoon Squadron pilots rest by one of their fighter planes at an allied airbase. - Typhoon Squadron pilots rest.jpg Miloch Aviation Photos 0 August 7th 18 02:52 AM
CHEAP Los Angeles C-172 Flying Club CHEAP [email protected] Owning 1 May 7th 09 03:32 PM
CHEAP Los Angeles C-172 Flying Club CHEAP Sunho Owning 2 May 7th 09 12:13 AM
Head Rest Nyal Williams Soaring 0 August 1st 03 03:19 PM
