Wanted O2 bottle
Old July 18th 19, 01:20 PM posted to rec.aviation.soaring
Default Wanted O2 bottle
http://www.cramerdeckermedical.com/c...?category_id=2
Old July 18th 19, 02:30 PM posted to rec.aviation.soaring
Thanks for the link. Note that the (optional) brass Sherwood CGA 540 valves do NOT have a pressure gauge and are rather bulky compared to the valve/gauge combination offered with the MH cylinders. But the price is definitely attractive.
Old July 18th 19, 02:33 PM posted to rec.aviation.soaring
Oops! I just saw the low profile CGA 540 valve with gauge on the options list. Costs $30 extra.
Old July 18th 19, 03:49 PM posted to rec.aviation.soaring
Tim Taylor
Mark,
I see you found one with a price. Most of the suppliers do not list them on their webpages, but if you call or e-mail they will give you a price for any valve configuration you like. I have had cylinders fitted with the straight through cga 540 with gauge as well as the larger 90 degree 540. I used to use life assist, but there are many suppliers to choose from now.
Tim
Old July 18th 19, 03:55 PM posted to rec.aviation.soaring
Thanks to Tim and Stu8 for the link and advice. I ordered a cylinder from Cramer Decker Medical as a spare for my glider. I will give a report when it arrives.
Old July 18th 19, 06:50 PM posted to rec.aviation.soaring
I bought a tank from Cramer Decker for my PIK 20D in 2017. The valve supplied does not match the fine fit and finish of the Mt. High units, but still workable. However, the brand-new tank that I received had only two years left before the tank needed hydro tested earlier this year.
O2 bottle needed Paul Natkiel Soaring 1 June 8th 19 12:57 AM
Oxygen Bottle for ASW 20 Deming Gray Soaring 2 February 15th 19 12:03 AM
Oxygen bottle for ASW 27 and ASG 29 [email protected] Soaring 8 April 18th 16 04:08 PM
Oxygen Bottle Roger Fowler[_2_] Soaring 2 November 19th 11 09:17 PM
O2 Bottle Space Whiskey Delta Soaring 5 April 2nd 11 07:11 PM
