Pooh Bear wrote in message ...
Howard Berkowitz wrote: Hijack is 7500. For some reason I haven't fathomed, the FAA ATC procedure is to contact the aircraft by radio and ask "Sir, please confirm you are squawking 7500." Oh great ! What presence of mind ! What berk thought that one up ? someone has a good presence of mind. let look at this: "'Aircraft X', confirm your squawk, 'Center X'". thats taken what 7 words, how long does it take to say ? now consider the following: 1. when an emergency code is squawked, say for example a 7500 squawk, the controller doesnt leap in his chair exclaiming "A Hijack! A Hijack! what do i do?" for someone else say, "****! get the president on the phone!" rather: an emergency squawk initiates a set procedure, which will involve the controller requiring radio silence from everyone else on that freq. and will likely provide an alternate freq. for everyone else to change to and other aircraft will be vectored from the vicinity. the controllers will implement an action plan or rather set procedure depending on what the situation requires. 2. transponders have a couple of different methods of entereing the squawk code, some have numeric keypads, others have rotating dials. some also have a feature to shortcut to a specific code. accidental input of a specific code, has happened, does happen and will happen. Personally speaking, durin the very first days of instruction, a few moons ago now, i was advised to enter transponder codes from the back first, to prevent any accidental emergency code squwaks (with the rotational dial transponder its possible as you are winding through the numbers to trigger an emergency code) and so set off the alam bells at the handling control center. 3. controllers are pretty capable people, believe it or not, and their familiarity with their daily profession enables them to make accurate judgement calls on many situations. A controller asking an aircraft transmitting an emergency squawk to confirm, is going to get perhaps only a few alternative responses: - the pilot responds with "'Center X', thats a negative on the 'x' squawk, we're good here, please confirm correct squawk, thanks for the heads up "aircraft x'" - the controller gets no response, which is an indication as to a problem. - an unusual response occurs, which again is an indication as to a problem. now, just before people go off on a tangent that the pilot could have a gun to his head and is lectured on how to respond, controllers are pretty adept at working things out for themselves. a controller can pretty much figure out if you have a problem with something from vocal cues. furthermore pilot are pretty adept at dealing with problems, there was one instance during a hijack that the pilots keyed the mic during the hijackers vocal outbursts in the cockpit so not only could the control center hear, but also it was on the tapes. thats not mentioning the basic issue of has the aircraft deviated from the flight plan, has it changed heading or altitude ? listening to the tower tapes of an emergency situation, before all the other pilots on the frequency changed off to the alternative assigned frequency, there were a few blind transmissions from other pilots just quickly and simply "good luck guys, god be with you" though i am not particularly religious nor sentimental, it's something to give to a flight crew in a ****ty situation. as another side note, a friend of mine worked out rather rapidly during flight that he lost the ability to transmit, could recieve fine, but not transmit. which of course led him to input 7600 transponder code. the controller obviously came back to attempt to make communication (bear in mind the controller only knows its lost comms) and at the controllers call attempts, he hit ident. the controller pretty much worked out rather rapidly, that the pilot could hear and not talk, and so an easy day was had by all, as the controller issued him with vectors, confirming by replying with the ident. so, after considering the above, is it more appropriate to say 7 words and confirm the situation, or go all out into full blown emergency situation. presence of mind yes. berk, no. Has it occurred that just maybe, here and there, a hijacker just might not notice the transponder code was changed? which is irrelevant either way. if it hasnt been changed he will continue with his plan, if it has, he will continue with his plan. but the ability remains to provide a non verbal indication of an emergency situation. Mercuns just love to screw up the admin way. hardly. Graham |
Howard Berkowitz wrote in message ...
In article , (running with scissors) wrote: Pooh Bear wrote in message ... Howard Berkowitz wrote: Hijack is 7500. For some reason I haven't fathomed, the FAA ATC procedure is to contact the aircraft by radio and ask "Sir, please confirm you are squawking 7500." Oh great ! What presence of mind ! What berk thought that one up ? someone has a good presence of mind. let look at this: "'Aircraft X', confirm your squawk, 'Center X'". thats taken what 7 words, how long does it take to say ? Note that I did not make the statement about presence of mind. While I don't have the procedure in front of me, those are not the words said by ATC. Those words specifically are confirming a squawk of 7500. if you note, i wasnt responding to your post, but rather the one that made a comment as to the berk, that thought up the basis of a confirmation. and i have had those words said to me on using an incorrect xpndr code. Consistent with controller workload, occasional random squawk verification requests might be a decent idea, to decrease suspicion. suspicion of what ? if the aircraft hasnt deviated from its flight plan or any vectored deviations, what is the concern? Of the recent crop of hijackers, their English was imperfect, and a routine query just might get by -- it might not. what recent crop of hijackers ? do you think if a controller during an interchange with a flight crew suddenly has unusual voice to deal with, with an unusual request or statement and a deviation from altitude or heading its not going to be considered as perhaps a little unusual? now consider the following: 1. when an emergency code is squawked, say for example a 7500 squawk, the controller doesnt leap in his chair exclaiming "A Hijack! A Hijack! what do i do?" for someone else say, "****! get the president on the phone!" rather: I certainly did not suggest that was the procedure, which indeed would be asinine. i didnt say you did. 2. transponders have a couple of different methods of entereing the squawk code, some have numeric keypads, others have rotating dials. some also have a feature to shortcut to a specific code. accidental input of a specific code, has happened, does happen and will happen. Personally speaking, durin the very first days of instruction, a few moons ago now, i was advised to enter transponder codes from the back first, to prevent any accidental emergency code squwaks (with the rotational dial transponder its possible as you are winding through the numbers to trigger an emergency code) and so set off the alam bells at the handling control center. And a simple confirmation request doesn't draw attention to 7500. umm so you are saying that a controller asking for a confirmation of the code you are squawking is not going to lead a pilot to think "umm, why is he asking me that, perhaps i sould turn my head a little and see what i am squawking, then again, naah! i really cant be bothered!" do you think if a pilot is asked to confirm his altitude or heading he carries on blindly? when a controller is asking you to 'confirm' something, its because something needs attention. now, just before people go off on a tangent that the pilot could have a gun to his head and is lectured on how to respond, controllers are pretty adept at working things out for themselves. You seem to be making quite a few assumptions about tangents. hardly assumptions. [snip explanations of tangents] gee thanks! so, after considering the above, is it more appropriate to say 7 words and confirm the situation, or go all out into full blown emergency situation. presence of mind yes. berk, no. Were the words what you suggested, I would have less concern. Specific confirmation of 7500, for exactly the reasons you mention below, do not make sense from a human factors standpoint. huh ! what ? so from a human factors aspect, you suggest that a full scale alert and conatinment situation should be initiated, with no confirmation that a threat exists. from a human factors standpoint, the situation the flight crew, the controllers, the military pilots, the chain of command, everyone between and connected are going to have a lot more human factors to deal with in going into a full scale alert and containment situation instead of saying seven words. confirming the validity of a situation before taking repercussive action is part of human factors. aww ****, you know what, next time i get an odd indication, **** it, i am going to squawk 7700, divert, hit an emergency descent and get the runway foamed and land gear up, wether its on the MEL or not. thats so much better huh! While terrorists may not be courteous enough to be repetitive, any 7500 is sufficient to alert NORAD. Fighters always can be recalled, but if the hijacking is real and a suicide attack is a real possibility, time is urgent. I can easily see a pilot's last living act to be changing the squawk before a hostile takes his life, and control of the aircraft. well then you cant see very well at all then. Has it occurred that just maybe, here and there, a hijacker just might not notice the transponder code was changed? which is irrelevant either way. if it hasnt been changed he will continue with his plan, if it has, he will continue with his plan. but the ability remains to provide a non verbal indication of an emergency situation. Mercuns just love to screw up the admin way. hardly. Graham |
Did we win in Viet Nam? | Lisakbernacchia | Military Aviation | 89 | July 12th 04 06:03 AM |
SpaceShip 1 - South African Connection | MWEB | Home Built | 4 | July 1st 04 07:08 AM |
CIA U2 over flight of Moscow | John Bailey | Military Aviation | 3 | April 9th 04 03:58 AM |
U.S. Troops, Aircraft a Hit at Moscow Air Show | Otis Willie | Military Aviation | 0 | August 28th 03 10:04 PM |
U.S. Air Force lands at Moscow air show | Otis Willie | Military Aviation | 0 | August 20th 03 04:19 AM |
