More trailer tire/wheel issues
Old July 20th 19, 06:59 PM posted to rec.aviation.soaring
[email protected][_2_]
Default More trailer tire/wheel issues
Chip....how do you disconnect the brake system?
R
Old July 20th 19, 07:39 PM posted to rec.aviation.soaring
Dave Nadler
https://www.homedepot.com/s/sawzall?NCNI-5
Beat ya to it Bob K. !!
Old July 23rd 19, 12:05 AM posted to rec.aviation.soaring
Temporary (!) ways to disconnect the surge brake on my 1992 Cobra:
1. The aft end of the long brake rod under the trailer (just ahead of the axle) is threaded and attaches to the "splitter" plate that pulls the Bowden cables, one for each brake. IIRC, there's a nut and a lock nut: just remove these and pulling on the brake rod will have no effect on the brakes. Make sure the aft end of the brake rod can't fall down and drag if the emergency brake is actuated. If so, cable tie it to the bracket under the trailer.
2. Recently I disassembled the front pivot for the hook that is pushed by the end of the surge brake tube inside the tongue. That hook then pulls the brake rod, which runs under the trailer. On my trailer, remove one bolt and the hook and emergency brake assembly fall out. You could just tie up the front end of the brake rod and the emergency brake handle and mechanism with a shock cord. Fold the handle down before you do this, though. This would disconnect the brake but it might also allow the sliding tongue to compress even more than normal when braking. I don't think so--there's an internal stop--but I'm not going to try this until I check.
3. The ends of the Bowden cable housings bolt into the splitter plate. So if you unthread the cable housings, the cables can't be actuated. If they're flopping around loose, tie them up so they can't drag.
Methods 1 and 3 involve crawling under the trailer. It's not bad; you don't have to jack it up. Method 1 is quicker and easier. But method 2 would be easier still if it doesn't cause harm.
And, of course, you have to be careful when reassembling that you don't thread things up too tight and actuate the Bowden cables, then drive around with the brakes partially applied. In my experience, it's very easy to see when the cables are slack and when they're under tension.
Of course, a brake system that works every time would eliminate the need for any of this.
Chip Bearden
Old July 23rd 19, 12:31 AM posted to rec.aviation.soaring
OK...thanks....I’ll print this out and save for reference should the need arise.
R
Old July 23rd 19, 03:03 AM posted to rec.aviation.soaring
JS[_5_]
Old July 23rd 19, 09:17 AM posted to rec.aviation.soaring
A Pfeiffer and Komet we owned for years were troublefree. I can't recall whether the Komet had the automatic feature that allowed you to back up without locking out the surge brake but the Pfeiffer did not. Maybe the added complication makes the system a bit sensitive.
When the system works, as it normally does, it works well. But when it doesn't, the failure mode can be catastrophic: failed bearings and cooked brake lining crumbling off the brake shoes (I've never had a tire fail because of it). It's probably something simple. But it's not because of neglect, lack of knowledge of conventional brake systems, or motivation.
Chip Bearden
FS - New Tost Brass 200 x 50 Tail Wheel with tire and tube Dave Springford Soaring 1 June 26th 18 11:12 AM
Tost brass tail wheel, tube, tire for sale: USA Barny Soaring 2 August 12th 11 10:43 PM
Spare wheel/tire Steve Freeman Soaring 0 August 12th 10 11:21 PM
looking for wheel/tire/brake Brad[_2_] Soaring 1 July 29th 10 02:56 AM
Wheel pants for 6.00 x 6 wheel/tire Wallace Berry Home Built 2 January 23rd 04 04:22 AM
