I have a 1990 Cobra with non functioning brakes due to a blowout where I didn't catch it and drug the trailer quite a ways and tore up the drum assembly.
I've got to get a Dexter Axel on there with electric brakes. I think having functioning trailer brakes even at fairly low weights is very important. A pickup pulled out in front of me this summer and I had a wild scary close call, having trailer brakes would have been very good. I was lucky I didn't T-Bone him and have a very nasty accident. Highway travel is dangerous. |
"Highway travel is dangerous."
Nick- we didn't worry so much about dangerous situations when we were hang gliding with JZ and Zoardog. What changed? Lightning strike or something? ;-P~~~~ |
I pulled the drum off the wheel that was hot enough to steam water Both ends of the sealed bearing fell out along with most of the ball bearings! I believe the bearing was in the process of failing from overheated brakes after an hour of down hill towing......hwy80 west of Reno. W&W didn’t have the replacement and Cobra is on Holiday, but I was able to find it on line for $45/ea after giving ID 30mm, OD 60mm, H 37mm ( old bearing was. Armed AL-KO 581736).
This is the second time I have had very hot brakes after an extended downhill tow. I have fitted a simple brake lock-out that prevents the surge brake from surging! It consists of a piece of plastic pipe who’s ID matches the OD of the surge cylinder (2” pipe X3.75” for my Cobra), split it into two halves with a hacksaw and place them on the surge brake in the fully extended position. Secure them with two hose clamps and I’m good to go down the Sierras without hot brakes! E-mail me for photo. JJ PS, my blown tire was most probably age related, these new looking tires all have a born on date of 99! |
I just changed the tongue damper on a 10/2007 Cobra.
Had been in procrastination mode. Perhaps others put that job off too? Thanks for keeping the thread going as a reminder! It took 90 minutes from chocking and jacking the trailer prior to removal until rolling it out with the new part installed. This part I believe is critical in maintaining good braking behaviour. There is an Al-Ko Workshop manual, covering axles, brakes, hitches and overrun devices. It also has lists of lubricants and accessories. http://www.tabberiet.dk/T%40B-siden/...al%20AL-KO.pdf The missing information for those with the square tongue: Remove the jockey wheel. After disconnecting the brake rod, remove the two bolts holding the drawbar onto the tongue. Remove the drawbar. Tools: 17mm open end for the brake rod. 19mm socket and open or box for the other bolts. Alignment tool for the new damper. Torque wrench. Options: Hammer, beer. Jim |
FS - New Tost Brass 200 x 50 Tail Wheel with tire and tube | Dave Springford | Soaring | 1 | June 26th 18 11:12 AM |
Tost brass tail wheel, tube, tire for sale: USA | Barny | Soaring | 2 | August 12th 11 10:43 PM |
Spare wheel/tire | Steve Freeman | Soaring | 0 | August 12th 10 11:21 PM |
looking for wheel/tire/brake | Brad[_2_] | Soaring | 1 | July 29th 10 02:56 AM |
Wheel pants for 6.00 x 6 wheel/tire | Wallace Berry | Home Built | 2 | January 23rd 04 04:22 AM |
