I just changed the tongue damper on a 10/2007 Cobra.
Had been in procrastination mode. Perhaps others put that job off too? Thanks for keeping the thread going as a reminder! It took 90 minutes from chocking and jacking the trailer prior to removal until rolling it out with the new part installed. This part I believe is critical in maintaining good braking behaviour. There is an Al-Ko Workshop manual, covering axles, brakes, hitches and overrun devices. It also has lists of lubricants and accessories. http://www.tabberiet.dk/T%40B-siden/...al%20AL-KO.pdf The missing information for those with the square tongue: Remove the jockey wheel. After disconnecting the brake rod, remove the two bolts holding the drawbar onto the tongue. Remove the drawbar. Tools: 17mm open end for the brake rod. 19mm socket and open or box for the other bolts. Alignment tool for the new damper. Torque wrench. Options: Hammer, beer. Jim |
FS - New Tost Brass 200 x 50 Tail Wheel with tire and tube | Dave Springford | Soaring | 1 | June 26th 18 11:12 AM |
Tost brass tail wheel, tube, tire for sale: USA | Barny | Soaring | 2 | August 12th 11 10:43 PM |
Spare wheel/tire | Steve Freeman | Soaring | 0 | August 12th 10 11:21 PM |
looking for wheel/tire/brake | Brad[_2_] | Soaring | 1 | July 29th 10 02:56 AM |
Wheel pants for 6.00 x 6 wheel/tire | Wallace Berry | Home Built | 2 | January 23rd 04 04:22 AM |
