source for clips or sleaves for Hotelier linkages
Old August 2nd 19, 01:29 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default source for clips or sleaves for Hotelier linkages
On Friday, August 2, 2019 at 2:10:38 AM UTC-4, John Foster wrote:
On Thursday, August 1, 2019 at 8:09:20 PM UTC-6, Bruce wrote:
Well, I found a source for the pins, and it's local to me, of all places--Ace Hardware! 0.047" (1.2mm) dia. by 19/32" (15mm) long. When I insert them into the holes I drilled, they barely protrude beyond the diameter of the push rod, and will easily clear the holes in the wing root rib. 32 cents each.
So which pins did you end up using? The "bobbie" pins or other? Enquiring minds want to know
Bruce
If you have Facebook, check this link out:
https://www.facebook.com/photo.php?f...type=3&theater
"Sorry, this content isn't available right now
The link you followed may have expired, or the page may only be visible to an audience you're not in."
Source for L'Hotellier Safety Clips George Haeh Soaring 23 January 29th 19 12:20 AM
L'Hotelier Fitting Safety Pins Dan Marotta Soaring 20 October 17th 16 01:40 AM
Complete Hotelier Connections For Sale (Brand New) $400 Scott Alexander[_2_] Soaring 2 July 19th 12 10:40 PM
Hotelier safety sleeves [email protected] Soaring 6 August 31st 07 03:41 PM
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
