FAA ADSB Performance Website Working??
Old July 30th 19, 05:11 PM posted to rec.aviation.soaring
Scott Williams
Default FAA ADSB Performance Website Working??
On Sunday, July 28, 2019 at 8:58:33 PM UTC-5, Bob Gibbons wrote:
Has anyone gotten the FAA ADSB Performance website to work recently?
https://adsbperformance.faa.gov/PAPRRequest.aspx
It worked fine for me last year, but multiple attempts recently to
file a report results in a return to the original input screen when
you press "Submit Request" at the bottom of the page.
Bob
Hey Bob,
I've pulled several reports in the last few weeks, works fine,
Occasionally I forget to enter info in all the boxes, especially the 2nd emitter category, "not installed"
good luck,
Scott, STD Cirrus, standard category pure glider, ADS-B out
Old July 30th 19, 05:31 PM posted to rec.aviation.soaring
Dan Marotta
Scott had the right answer.Â* I just got a report for yesterday's flight.
Bob
Hey Bob,
good luck,
Dan, 5J
Old July 30th 19, 11:12 PM posted to rec.aviation.soaring
Scott Williams
Bob
Hey Bob,
good luck,
Dan, 5J
https://adsbperformance.faa.gov/paprrequest.aspx
I wonder if it's caps sensitive?
Old July 31st 19, 04:13 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Tue, 30 Jul 2019 09:11:41 -0700 (PDT), Scott Williams
Bob
Hey Bob,
good luck,
Thanks Scott, looks like that is the issue. I neglected to select "not
installed" for the "Enter 2nd GPS" field.
Got the report back in a few minutes.
Thanks
Bob
ADSB out in tow planes Charles Longley Soaring 57 June 5th 18 04:39 AM
Stratus / Foreflight ADSB 6X Soaring 5 December 17th 13 09:34 AM
ADSB is only the start... Martin Gregorie[_5_] Soaring 0 October 1st 09 01:27 PM
Santa and ADSB Mal Soaring 0 December 15th 06 07:42 PM
Complex / High Performance / Low Performance R.T. Owning 22 July 6th 04 08:04 AM
