In the 3 Pawnee’s I fly 2 use the floor mounted dump lever which I like. The other one uses a shorter lever mounted in front of the throttle which I like even more!
On Monday, August 5, 2019 at 7:44:32 PM UTC-4, Charles Longley wrote:
In the 3 Pawnee’s I fly 2 use the floor mounted dump lever which I like. The other one uses a shorter lever mounted in front of the throttle which I like even more! Our Pawnee floor lever lies almost on the floor. There is a tab with a hole which looks like it should have a tension spring to keep the handle more upright. Anyone know if there is supposed to be a tension spring here? Where would the other end attach? Part number? Thanks in advance, Bob 7U |
On Monday, August 12, 2019 at 11:57:16 AM UTC-4, wrote:
On Monday, August 5, 2019 at 7:44:32 PM UTC-4, Charles Longley wrote: In the 3 Pawnee’s I fly 2 use the floor mounted dump lever which I like. The other one uses a shorter lever mounted in front of the throttle which I like even more! Our Pawnee floor lever lies almost on the floor. There is a tab with a hole which looks like it should have a tension spring to keep the handle more upright. Anyone know if there is supposed to be a tension spring here? Where would the other end attach? Part number? Thanks in advance, Bob 7U I do not recount seeing one with a spring. There should be enough tension on the release cable to keep the handle in the closed or locked position. |
Install a Tost reel system and you can use a simpler “release” setup due to the use of a guillotine. Very little force needed to cut the tow rope so the release lever can be smaller and mounted right in front of the throttle. Both our Pawnees have been equipped for several years and I would not like to go back to the Elmira Death Hook!
Plus you get a built in Tost release for when you just have to drag a 200 ft rope behind you... Kirk 66 |
Piper PA-25 Pawnee pics [04/11] - Pawnee pulls a glider.jpg (1/1) | Miloch | Aviation Photos | 0 | November 10th 18 03:53 PM |
Piper PA-25 Pawnee pics [01/11] - A Swift glider is performing continuous full rolls while being towed by a Pawnee.jpg (1/1) | Miloch | Aviation Photos | 0 | November 10th 18 03:53 PM |
Pawnee Tost Release | Mike125 | Soaring | 1 | April 16th 08 03:59 PM |
Tow Release Handles for Pawnee and C182 | [email protected] | Soaring | 2 | March 12th 07 02:40 AM |
WTB towhook release for Piper Pawnee | [email protected] | Soaring | 2 | November 22nd 06 03:29 PM |
