Ventus rigging advice, please?
Old August 7th 19, 05:09 PM posted to rec.aviation.soaring
Default Ventus rigging advice, please?
On Saturday, August 3, 2019 at 9:47:38 PM UTC-6, Charlie M. (UH & 002 owner/pilot) wrote:
A clean set of pins and some lube goes a long way in rigging......period......
+1 for my Ventus B. I spent a year or two trying to figure out why, with all things to the best of my knowledge the same, sometimes the wings would protest and sometimes not. Fresh lube each rigging has provided the answer.
Old August 8th 19, 02:02 AM posted to rec.aviation.soaring
2G
....and you simultaneously figured out how to align the wings to the fuse. Don't believe me? Misalign the wings and see if they still go on. Alignment is the key (I have had no problem assembling gliders w/o ANY lube)...
Old August 8th 19, 04:30 PM posted to rec.aviation.soaring
Nope. Rather, I'm sure it is that you mistakenly attribute your success in rigging to alignment rather than that you're now properly lubing (see how useless a comment like that is? We could go back and forth forever...)
Old August 9th 19, 05:43 AM posted to rec.aviation.soaring
2G
Bottom line: I have rigged plenty of gliders WITHOUT any lubing WHATSOEVER. Period.
Old August 9th 19, 01:33 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Somehow Tom, this must be a metaphor for your life.
Old August 26th 19, 03:25 AM posted to rec.aviation.soaring
2G
Not sure what you mean (and I am sure it isn't pleasant - which says more about you than me), but I rigged my 31Mi today w/o lubing as a test - it went fine. BTW, the 31Mi has the tightest tolerances of any glider I have rigged.
Tom
Old August 10th 19, 04:08 PM posted to rec.aviation.soaring
danlj
Agreed: "Alignment is the key"
BUT, in solo rigging the second wing tends to push the first back out.
There are TWO serviceable ways to handle this.
1: Align the first wing very carefully, so that the gap between fuselage and root is even and small, fore and aft, top and bottom. This takes a extra couple of minutes.
Then TAPE the gap. The tape holds the first wing in very nicely.
2: After aligning the first wing, insert the main spar pin less than halfway. Then fold a 3 x 5 card or similar stiff, thick paper several times and jam it into the gap between the pin and the "hat shelf".
This works very well until the pressure on the bolts that hold the "hat shelf" in place erodes the fiberglass. You can prep for this by reinforcing the bolt holes on the front surface of the "hat shelf" with aluminum or wood (glue holds wood better), and the edge the pressed against the main spar pin likewise.
I did this many years ago, and it greatly helped to hold the first wing in place.
3: I strongly recommend folding the seatback forward and NOT folding it back until the main spar pin is in place and saftied, to ensure against failing to insert it fully. (Wing gap tape *will* hold the wings on for at least an hour, but is not recommended...)
ventus rigging visual clues [email protected] Soaring 13 May 3rd 18 12:08 PM
Ka-6 Rigging vontresc Soaring 19 August 14th 08 04:55 AM
Ventus C rigging James Hamilton Soaring 8 July 7th 06 08:30 AM
Ventus C rigging James Hamilton Soaring 0 July 6th 06 07:41 PM
ski rigging Drew Dalgleish Home Built 3 December 3rd 03 04:16 AM
