On Wednesday, August 7, 2019 at 9:27:34 AM UTC-7, Tango Whisky wrote:
Exactly. Tubing should be silicone. No additional devices needed. I plan on using the colored tubing from Wings and Wheels. Good stuff? |
Absolutely, very good tubing!
On Wednesday, August 7, 2019 at 12:46:40 PM UTC-7, soaringjac wrote:
On Wednesday, August 7, 2019 at 9:27:34 AM UTC-7, Tango Whisky wrote: Exactly. Tubing should be silicone. No additional devices needed. I plan on using the colored tubing from Wings and Wheels. Good stuff? Craggy Aero also has tubing http://www.craggyaero.com/tubing_&_fittings.htm Richard www.craggyaero.com |
I use silicon tube of 5mm ID cut into 10mm pices and stretched over the tube and fitting.
The rubber donuts deteriorate very quickly to the point of being useless. |
The rubber rings are called docking rings.
Source of green donuts for instrument tubing installation? | Movses Babayan | Soaring | 14 | April 10th 18 09:45 PM |
Relesable instrument tubing | [email protected] | Soaring | 6 | February 13th 07 05:38 AM |
source for clear+red instrument tubing | John W | Soaring | 8 | November 1st 04 01:19 PM |
Tubing strength | Ernest Christley | Home Built | 0 | January 16th 04 11:43 PM |
