Flaps/No flaps...practical difference??
Old August 12th 19, 11:21 PM posted to rec.aviation.soaring
Default Flaps/No flaps...practical difference??
For simple long pleasure flights in the western US or for the rare flights in the Alps would I notice any real PRACTICAL difference between a Discus 2c and other flapped 18m ships? I have NO interest in competition. Thanks
Old August 12th 19, 11:50 PM posted to rec.aviation.soaring
JS[_5_]
One consideration is what to do when a tow is too slow and not getting faster, particularly when full of water.
Pull in an extra notch of flaps, or...
Old August 13th 19, 01:05 AM posted to rec.aviation.soaring
Dan Marotta
You'll have something to do with your left hand.
Dan, 5J
Old August 13th 19, 01:24 AM posted to rec.aviation.soaring
Gary Wayland
Well, on that pleasure flight, as he blows by you at 100 knots. When are we not in competition? And, the pilot has the same wingspan to do it...
Now, if you get a Libelle, you can out thermal them all!
"SQ"
Old August 13th 19, 02:34 AM posted to rec.aviation.soaring
George Haeh
Landing flaps in Schleicher ships give you a nice steep approach and aileron control once on the ground.
Negative flap helps with aileron control in the initial ground run on aerotow.
But each available flap setting gives you another opportunity to get it wrong.
Exceeding maximum speed for a given flap setting can make bad things happen. Pay attention to the white triangles on the airspeed.
Old August 13th 19, 03:22 AM
Brett Brett is offline
Member
First recorded activity by AviationBanter: May 2006
[quote=Brett;997703]I have about 500 hours in a D2C (18m). And a number of 18m flapped gliders since. The D2C is a beautiful sailplane to fly and very competitive. If you fly under 100kts it gives very little away to a V2cx.
I had no problems towing full of water or landing short. Very docile handling.
AND it will easily out-climb a Libelle.
I highly recommend it for your type of flying.
Brett
Old August 13th 19, 05:02 AM posted to rec.aviation.soaring
[email protected][_1_]
What George and JS said and in addition, landing speed and the angle of attack needed to lift off at high wing loadings.
Old August 13th 19, 10:12 PM posted to rec.aviation.soaring
6PK
Snip/paste: "AND it will easily out-climb a Libelle. "
I very much doubt that....!
Old August 14th 19, 02:35 AM posted to rec.aviation.soaring
Gary Wayland
V2cx.
handling.
Brett
Brett
Who was the slug in that Libelle? No one can out thermal a Libelle! lol
Just kidding... I have a sweet spot for the Libelle. My first Sailplane. 250 hours that first year. She was a fun machine... No plane in that era ever flew through that glider in a thermal...
For the money, based on the thermal aspects and pure fun, I can't think any other plane that matches it that was in standard class for its time. I'm biased, of course...
Gary
"SQ"
ASW27b
Old August 14th 19, 02:38 AM posted to rec.aviation.soaring
Gary Wayland
Ok, we are friends! Viva la Libelle!
More flaps? WingFlaps Piloting 36 May 26th 08 07:33 AM
flaps again Kobra Piloting 107 January 5th 08 04:31 PM
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
flaps Kobra[_4_] Owning 85 July 16th 07 06:16 PM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
