2 civilian airliners down south of Moscow
Old August 31st 04, 12:09 AM
running with scissors
Howard Berkowitz wrote in message ...
(running with scissors) wrote:
Pooh Bear wrote in message
Howard Berkowitz wrote:
Hijack is 7500. For some reason I haven't fathomed, the FAA ATC
procedure is to contact the aircraft by radio and ask "Sir, please
confirm you are squawking 7500."
Oh great ! What presence of mind ! What berk thought that one up ?
someone has a good presence of mind. let look at this:
"'Aircraft X', confirm your squawk, 'Center X'". thats taken what 7
words, how long does it take to say ?
Note that I did not make the statement about presence of mind. While I
don't have the procedure in front of me, those are not the words said by
ATC. Those words specifically are confirming a squawk of 7500.
if you note, i wasnt responding to your post, but rather the one that
made a comment as to the berk, that thought up the basis of a
confirmation.
and i have had those words said to me on using an incorrect xpndr
code.
Consistent with controller workload, occasional random squawk
verification requests might be a decent idea, to decrease suspicion.
suspicion of what ? if the aircraft hasnt deviated from its flight
plan or any vectored deviations, what is the concern?
Of
the recent crop of hijackers, their English was imperfect, and a routine
query just might get by -- it might not.
what recent crop of hijackers ? do you think if a controller during an
interchange with a flight crew suddenly has unusual voice to deal
with, with an unusual request or statement and a deviation from
altitude or heading its not going to be considered as perhaps a little
unusual?
now consider the following:
1. when an emergency code is squawked, say for example a 7500 squawk,
the controller doesnt leap in his chair exclaiming "A Hijack! A
Hijack! what do i do?" for someone else say, "****! get the president
on the phone!" rather:
I certainly did not suggest that was the procedure, which indeed would
be asinine.
i didnt say you did.
2. transponders have a couple of different methods of entereing the
squawk code, some have numeric keypads, others have rotating dials.
some also have a feature to shortcut to a specific code.
accidental input of a specific code, has happened, does happen and
will happen. Personally speaking, durin the very first days of
instruction, a few moons ago now, i was advised to enter transponder
codes from the back first, to prevent any accidental emergency code
squwaks (with the rotational dial transponder its possible as you are
winding through the numbers to trigger an emergency code) and so set
off the alam bells at the handling control center.
And a simple confirmation request doesn't draw attention to 7500.
umm so you are saying that a controller asking for a confirmation of
the code you are squawking is not going to lead a pilot to think "umm,
why is he asking me that, perhaps i sould turn my head a little and
see what i am squawking, then again, naah! i really cant be bothered!"
do you think if a pilot is asked to confirm his altitude or heading
he carries on blindly? when a controller is asking you to 'confirm'
something, its because something needs attention.
now, just before people go off on a tangent that the pilot could have
a gun to his head and is lectured on how to respond, controllers are
pretty adept at working things out for themselves.
You seem to be making quite a few assumptions about tangents.
hardly assumptions.
[snip explanations of tangents]
gee thanks!
so, after considering the above, is it more appropriate to say 7 words
and confirm the situation, or go all out into full blown emergency
situation. presence of mind yes. berk, no.
Were the words what you suggested, I would have less concern. Specific
confirmation of 7500, for exactly the reasons you mention below, do not
make sense from a human factors standpoint.
huh ! what ? so from a human factors aspect, you suggest that a full
scale alert and conatinment situation should be initiated, with no
confirmation that a threat exists.
from a human factors standpoint, the situation the flight crew, the
controllers, the military pilots, the chain of command, everyone
between and connected are going to have a lot more human factors to
deal with in going into a full scale alert and containment situation
instead of saying seven words. confirming the validity of a situation
before taking repercussive action is part of human factors. aww ****,
you know what, next time i get an odd indication, **** it, i am going
to squawk 7700, divert, hit an emergency descent and get the runway
foamed and land gear up, wether its on the MEL or not. thats so much
better huh!
While terrorists may not be courteous enough to be repetitive, any 7500
is sufficient to alert NORAD. Fighters always can be recalled, but if
the hijacking is real and a suicide attack is a real possibility, time
is urgent. I can easily see a pilot's last living act to be changing the
squawk before a hostile takes his life, and control of the aircraft.
well then you cant see very well at all then.
Has it occurred that just maybe, here and there, a hijacker just
might
not notice the transponder code was changed?
which is irrelevant either way. if it hasnt been changed he will
continue with his plan, if it has, he will continue with his plan. but
the ability remains to provide a non verbal indication of an emergency
situation.
Mercuns just love to screw up the admin way.
hardly.
Graham
Did we win in Viet Nam? Lisakbernacchia Military Aviation 89 July 12th 04 06:03 AM
SpaceShip 1 - South African Connection MWEB Home Built 4 July 1st 04 07:08 AM
CIA U2 over flight of Moscow John Bailey Military Aviation 3 April 9th 04 03:58 AM
U.S. Troops, Aircraft a Hit at Moscow Air Show Otis Willie Military Aviation 0 August 28th 03 10:04 PM
U.S. Air Force lands at Moscow air show Otis Willie Military Aviation 0 August 20th 03 04:19 AM
