On Wed, 14 Aug 2019 08:31:30 +0000, Phil King wrote:
Much simpler to look at the TPM and check that it is showing green! A search on "tyre pressure monitor cap" shows that shops on Amazon UK sell them - a four-pack costs less than GBP 2.00. They look as though they are a bit fatter and longer than the brass tyre caps on my glider, but at the price its probably worth trying them, even if they do end up on your car or trailer. -- Martin | martin at Gregorie | gregorie dot org |
At 11:17 14 August 2019, Martin Gregorie wrote:
On Wed, 14 Aug 2019 08:31:30 +0000, Phil King wrote: Much simpler to look at the TPM and check that it is showing green! A search on "tyre pressure monitor cap" shows that shops on Amazon UK sell them - a four-pack costs less than GBP 2.00. They look as though they are a bit fatter and longer than the brass tyre caps on my glider, but at the price its probably worth trying them, even if they do end up on your car or trailer. Thanks Martin. There are several different types on the market. I was looking for anyone with experience of using them on gliders who could save me the time required to try different ones and find a good one. I've actually bought some rather more expensive ones off eBay (3 quid each). Some of the cheap ones have had very bad reviews because they don't seal well and let the air out of the tyre. If anyone is interested to know how I get on then I can post the results back here in a few weeks time. |
I believe you are over complicating this.Â* My advice:Â* Just look at the
tires.Â* You can tell if they're too low to fly.Â* That's worked for me for almost 50 years. On 8/14/2019 7:45 AM, Phil King wrote: At 11:17 14 August 2019, Martin Gregorie wrote: On Wed, 14 Aug 2019 08:31:30 +0000, Phil King wrote: Much simpler to look at the TPM and check that it is showing green! A search on "tyre pressure monitor cap" shows that shops on Amazon UK sell them - a four-pack costs less than GBP 2.00. They look as though they are a bit fatter and longer than the brass tyre caps on my glider, but at the price its probably worth trying them, even if they do end up on your car or trailer. Thanks Martin. There are several different types on the market. I was looking for anyone with experience of using them on gliders who could save me the time required to try different ones and find a good one. I've actually bought some rather more expensive ones off eBay (3 quid each). Some of the cheap ones have had very bad reviews because they don't seal well and let the air out of the tyre. If anyone is interested to know how I get on then I can post the results back here in a few weeks time. -- Dan, 5J |
I once took off OK but the glider's main tire was totally flat when I landed. Surprise! Rollout was very short. Must have hit some sharp object in the air?
I've had problems with the tire leaking over months, 3 tubes & valves later it seems solved. Whew! With fixed gear and a wheel fairing covering the rim, checking the pressure is a chore. Of course I can look at the tire once the full glider weight is on it, even bounce the wingtips up and down, although with the stiff tire I used to have that was not sufficient to detect partial loss of tire pressure. |
At 14:19 14 August 2019, Dan Marotta wrote:
I believe you are over complicating this.Â* My advice:Â* Just look at the tires.Â* You can tell if they're too low to fly.Â* That's worked for me for almost 50 years. Not so easy to check by looking at the tire on the nose wheel of a two seat glider such as a Grob Twin II or Duo. And main wheel tires often look OK until you load them up with pilot and water ballast. |
On Wednesday, August 14, 2019 at 8:30:05 AM UTC-7, Phil King wrote:
At 14:19 14 August 2019, Dan Marotta wrote: I believe you are over complicating this.Â* My advice:Â* Just look at the tires.Â* You can tell if they're too low to fly.Â* That's worked for me for almost 50 years. Not so easy to check by looking at the tire on the nose wheel of a two seat glider such as a Grob Twin II or Duo. And main wheel tires often look OK until you load them up with pilot and water ballast. Agree with Dan, just look at them! In my experience, the nose wheel on a Duo never touches the ground unless you have the CG wrong. Two pilots and chutes with no tail ballast will often do it. Perhaps 99% of flats are on rigger, tail wheel, tail dolly and wing wheel.... all thin walled. Tost 400x4 and similar mains are pretty thin walled too. Try Mr. Tuffy or similar material (an old cut up inner tube is better than nothing) on the other wheels. Look for a high quality main wheel tire and tube. 500x5 seems the easiest to find these for. The beefiest example I've used: Goodyear Flight Custom 3 with Michelin Airstop tube. Aircraft Spruce has them. But check if the FC3 fits with the gear retracted! Jim |
On Wed, 14 Aug 2019 08:19:20 -0600, Dan Marotta wrote:
I believe you are over complicating this.Â* My advice:Â* Just look at the tires.Â* You can tell if they're too low to fly.Â* That's worked for me for almost 50 years. Dan, that's not often quite so easy on a grass field, especially as I have a strong suspicion that grass on a UK glider field is somewhat thicker and lusher than it might be in NM. how I get on then I can post the results back here in a few weeks time. Phil, I'd be interested to see what you find out. I was thinking only yesterday that, after all the rain we've had recently, it was getting hard to see if there was still a tyre on my main wheel, let alone how much air was in it. There is very little space between the bottom of the open wheelbox doors and the grass tops. -- Martin | martin at Gregorie | gregorie dot org |
Well, ya got me there... :-D
On 8/14/2019 10:23 AM, Martin Gregorie wrote: Dan, that's not often quite so easy on a grass field, especially as I have a strong suspicion that grass on a UK glider field is somewhat thicker and lusher than it might be in NM. -- Dan, 5J |
Tire Pressure Monitoring Systems for Trailers | AS | Soaring | 6 | July 11th 18 04:00 AM |
PW-5 Main Tire Pressure? | JohnDeRosa | Soaring | 3 | June 23rd 13 09:38 AM |
Accurate tire pressure gage? | Kurt Thams | Soaring | 6 | September 25th 12 11:17 PM |
Tire tread wear vs inflation pressure | Ben Jackson | Owning | 22 | October 6th 06 04:35 AM |
Tire inflation pressure | Paul Lee | Home Built | 80 | November 19th 03 07:56 AM |
