Flaps/No flaps...practical difference??
Old August 16th 19, 04:32 PM posted to rec.aviation.soaring
Joel Flamenbaum[_2_]
Default Flaps/No flaps...practical difference??
On Thursday, August 15, 2019 at 5:43:09 PM UTC-7, Delta8 wrote:
If cross country flight is a part of your plans I don't understand why
landing off field would not be a large part of the flaps/no flaps
decision?
Using flaps can get you into a field safely vs overshooting. I can
touchdown and stop without brakes on a grass strip (tail skid ) in 450'
with an ASW 20a max positive flap setting . The stall speed is down to
36kts so even if I hit something it will be a considerably slower speed
Many Moons ago flying in a contest out of Fairfield, PA, flying an ASW20a- My only option at the time was a college soccer field. I flew one 360 to scope it out. With full flaps and judicial use of dive breaks the 20 comes down like a helicopter. I chose the diagonal and was stopped with room to spare.
Delta8
Old August 16th 19, 05:24 PM posted to rec.aviation.soaring
krasw
Having flown a lot both ASW20 and D2, I would not try to land one glider in a place I would not land the other as well.
Old August 16th 19, 07:21 PM posted to rec.aviation.soaring
Mike the Strike
Ditto - ASW20, Discus 2 and Ventus 2bx experience under my belt. I have never felt there was a place I could land one of the flapped ships and not the D2.
(although the "Jesus" flap setting of the earlier ASW 20s was interesting!)
Mike
Old August 16th 19, 10:55 PM
Delta8 Delta8 is offline
Member
First recorded activity by AviationBanter: Apr 2019
Quote:
Mike
I used them every flight . My trailer is halfway down a 2000' strip and not wanting use a tow vehicle more than necessary . Spoilers in at 40' and flare at 20' seems to work well. The angle of descent is 4 to 1 .
I see why they did away with that position in later models , if you decide to move up a setting below 200' between any wind gradient and higher stall speed you're in trouble .
Old August 16th 19, 11:07 PM posted to rec.aviation.soaring
BobW
the D2.
interesting!)
Captain Obvious here (maybe)...
There's a world of difference between 'mere' camber-changing flaps (with or
without a 'landing' position) and large-deflection landing-flaps in terms of
steepest-glide-angle at approach-speed, and reduced (compared to unflapped
ships of equal span) stall speed, everything else being equal (which of course
it ain't). The devil's in the details.
Yeah, likely the main benefit of stalling-speed-reduction occurs somewhere
around (say) 30-ish degrees of flap deflection, beyond which the remaining
aerodynamic effect is pretty much additional drag, and yeah, manufacturers of
'flapped ships (w/o large deflection capability)' almost certainly optimize
such designs (and their landing spoilers) so that the *primary* purpose of the
flaps is to maximize soaring-performance-range for some design-targeted span
(and not maximize short-field capability), and hence == when considering
*these* sorts of flapped designs == there's arguably little
landing-capability difference between flapped and unflapped ships.
But to suppose that's true for *all* flapped designs (i.e. those w.
large-deflection landing flaps, e.g. some early versions of ASW 20s, pre-D
versions of PIK-20s, and a few, semi-rare (even in the U.S.; likely even more
rare in EASA-land) U.S. designs (Nugget, SGS 1-35, Zuni, many older HPs,
etc.)), is incorrect. Depending on the ship, *seriously* incorrect.
Most U.S. pilots w. 1-26 experience would likely agree no other glider would
be their first choice for landing in a small/approach-obstructed field. I
would, too, but for the HP-14 I flew for several hundred hours, more or less
immediately after my 1-26 time. The Zuni in which I have most of my
flapped-ship time, not so much, though its actual touchdown speed is (thanks
to its flaps) lower than all other 15-meter span glass ships with which I have
observational experience since ~1980.
Reiterating...the devil is in the details in the case of 'flaps.' All flaps
aren't the same - not by a long stretch. I chose large-deflection
landing-flapped ships for all my single-seaters, post-1-26, exactly for this
reason...and continue to believe they're something of a 'lost religious war'
in soaring-land.
Point being, anyone seriously claiming 'there's no practical difference in
landing capability' between flapped and unflapped gliders is either genuinely
ignorant, or 'discussionally choosing' to ignore the very real additional
landing-capabilities associated with large-deflection landing-flaps.
YMMV,
Bob - Cap't. Obvious - W.
This email has been checked for viruses by AVG.
https://www.avg.com
Old August 17th 19, 01:59 AM posted to rec.aviation.soaring
Dave Nadler
in soaring-land.
I've got an RHJ-8 looking for a home, flaps not quite as effective as HP-14
but quite frightening to passengers unused to such a treat of a landing...
Old August 17th 19, 02:18 PM posted to rec.aviation.soaring
BobW
or without a 'landing' position) and large-deflection landing-flaps in
terms of steepest-glide-angle at approach-speed, and reduced (compared to
unflapped ships of equal span) stall speed, everything else being equal
(which of course it ain't). The devil's in the details.
Snip...
would be their first choice for landing in a small/approach-obstructed
field. I would, too, but for the HP-14 I flew for several hundred hours,
more or less immediately after my 1-26 time...
flaps aren't the same - not by a long stretch. I chose large-deflection
this reason...and continue to believe they're something of a 'lost
religious war' in soaring-land.
HP-14 but quite frightening to passengers unused to such a treat of a
landing...
Oh man..born 40 years too soon, I was! I lusted after this ship (and its two
siblings) ever since I learned of 'em. May yours find a(nother) good home!
Bob W.
https://www.avg.com
Old August 18th 19, 09:30 AM posted to rec.aviation.soaring
krasw
YMMV,
Sure, if you totally botch landing circuit and approach way too high and fast, '20 flaps will get you down sooner than D2 airbrakes. But if you get into this situation, glider you need is ASK21 with flight instructor.
Old August 18th 19, 03:30 PM posted to rec.aviation.soaring
BobW
in landing capability' between flapped and unflapped gliders is either
genuinely ignorant, or 'discussionally choosing' to ignore the very real
additional landing-capabilities associated with large-deflection
landing-flaps.
YMMV, Bob - Cap't. Obvious - W.
Continuing (I think) a slow drift from the original poster's question...
I guess I don't understand the point you seem to me to be supporting. When I
imagine the "50%-extended glidepath" height-vs.horizontal distance diagram, at
normal approach speed, of (say) an ASW-20 (w. 65-degree flap capability) and a
D2, it strongly suggests to me that the former ship will have a greater number
of theoretically available fields from which to safely choose, independent of
anything else...pilot skill, trees, wind shears, etc. It will also be capable
of actually touching down with less energy to dissipate.
I'm not bashing flapless gliders; simply trying to make the point that
gliders' *usable* landing capabilities, differ...with real-world practical
effects. I'm OK with agreeing to disagree.
Anecdotally speaking, my habit/landing-preference with large-deflection
landing-flap-equipped gliders is to fly landing patterns where the terminal
portion of the approach employs full flap deflection, because: it's fun, not
fundamentally difficult, *and* it's useful prep for outlanding in
approach-obstructed/short fields, and in that sense no different than choosing
to consistently fly/practice full-spoiler-opening approaches in spoiler-only
ships. To each their own...
YMMV.
Bob W.
https://www.avg.com
Old August 18th 19, 05:02 PM posted to rec.aviation.soaring
Sorta my point on a -20A.....get current in the spring, then do a local pattern "way high" full flaps, full dive brakes, roll the nose over....sheesh....
I have shoveled into small fields from a 1-26 and up.....sorta hard to beat a -20A in a very small field.
Yes, I have -24 and -28 off airport landings.
Circuit may not be the issue, crappy fields (yes, you didn't call it quits soon enough...) may NEED max decent rate.
Sorry, standard class would have a hard time compared to many flapped ships.
YMMV...
BTW, I "believe" while testing the -20A, pilot was on final at 1000' above landing spot....Hang everything out, roll nose beyond vertical, land on spot......no turns..,,didn't exceed any speed......try that in a non flapped ship.
No, I don't believe the -20B or C could do that.
I did once a year for practice since it may loosen bottom wing/flap seals.....so....a test....
More flaps? WingFlaps Piloting 36 May 26th 08 07:33 AM
flaps again Kobra Piloting 107 January 5th 08 04:31 PM
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
flaps Kobra[_4_] Owning 85 July 16th 07 06:16 PM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
