Mistral-C vs DG-100
Old August 27th 19, 04:02 PM posted to rec.aviation.soaring
6PK
Default Mistral-C vs DG-100
And one other thing;for the most part taking off with a CG hook poses no problem unless if one gets out of wheck say 10/15 degrees off center line as in a crosswind -things could quickly escalate leading to a ground loop, much more so than gliders equipped with a nose hook.
Just my 5 C worth on that....
Old August 27th 19, 07:41 PM posted to rec.aviation.soaring
The Pegase manual doesn't say where to set the trim for a CG launch but it does say if 20 degrees or more off towing axis release immediately. My Peg has only the CG and I'm still thinking about adding a forward release. That said, its never been a problem. You just have to pay attention. You go where you're pointing.
MISTRAL -C manuals SP[_3_] Soaring 0 January 17th 14 11:47 PM
MAE : mistral jmp Aviation Photos 0 March 20th 08 09:44 PM
MAE : mistral jmp Aviation Photos 0 March 20th 08 09:30 PM
MAE : mistral jmp Aviation Photos 0 March 20th 08 09:28 PM
Mistral C [email protected] Soaring 1 October 23rd 07 08:30 PM
