#91
Mike Schumann writes:
Depending on where the 747 was, it could take a minute or more to get it off the runway. There's a lot of mass involved. A 747 on the runway will have its engines running. It can be clear of the runway in a few seconds. And in this case, it would have far more time to get clear, probably several minutes. Of course, this is all a hypothesis that has no real basis in reality. In reality, 747s do not sit on the runway blocking traffic. Plus, you may have taxiways that are clogged with other traffic. No, you don't. The taxiways off the runway are clear. Aircraft may be taxiing in other areas, but they are not parking on the taxiways directly adjacent to the runway. 747s don't make good off road vehicles. They don't have to. They can move very quickly. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#92
Which gets us back the the real question - If you have an unexplained fuel shortage and suspect a leak, why aren't you landing at the closest airport? There are many possible reasons. The nearest airport may not have a runway suitable for your aircraft. The nearest airport may not have a runway that is accessible to you without a lot of extra maneuvering. You may be low on fuel but with a very precise idea of how long you can continue to fly, which may allow you to reach an airport with better facilities than the closest one. Not only do you have an issue with running out of fuel, but leaks are a serious fire hazard. A leak that is a serious fire hazard will cause a fire fairly quickly. A leak that has not done so isn't likely to begin doing so after an extended period. A leak that loses fuel to the atmosphere isn't much of a hazard at all from a fire standpoint. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#93
Steven P. McNicoll wrote:
"Mike Schumann" wrote in message .. . I'm not saying that ATC didn't have a problem, but by the same token, it is also unacceptable for the pilot to continue to his destination after he declared an emergency to avoid the delays and hassles of diverting to a closer airport. What closer airport? The Dallas news said McKinney (KTKI) and Addison (KADS) were other choices. As someone else said, the decent cruise to KDFW would have been just as quick. -- Regards, Ross C-172F 180HP KSWI |
#94
Ross wrote:
Steven P. McNicoll wrote: "Mike Schumann" wrote in message .. . I'm not saying that ATC didn't have a problem, but by the same token, it is also unacceptable for the pilot to continue to his destination after he declared an emergency to avoid the delays and hassles of diverting to a closer airport. What closer airport? The Dallas news said McKinney (KTKI) and Addison (KADS) were other choices. As someone else said, the decent cruise to KDFW would have been just as quick. OK the word is descent.... -- Regards, Ross C-172F 180HP KSWI |
#95
Nomen Nescio writes:
Maybe we have to define "closest". If you're over airport A at 30k ft and within gliding range of airport B which is 30 nm away.......which airport is "closest". I tend to think that from the airplane's perspective, there is virtually no difference. If you can be confident than you have at least x minutes of fuel, then an airport that is x-y minutes away is just as close as one that is x-z minutes away. In other words, fuel is not an issue for any airports that are within your fuel endurance; the choice among those airports can therefore be based on other factors. If you are losing fuel at an unknown rate, then you need to take that into consideration in your choice, but I don't know if that was the case here. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#96
![]() "Tony" wrote in message ps.com... Did anyone see the news about an AA (maybe 777) airplane declaring a fuel emergency in DFW, requesting a downwind landing to I think 17 Center, and being told no, had to circle to land on 31 R? I'm not exactly sure of those details, but it's close enough. It's that old deal, when a pilot makes a mistake, the pilot dies, and when a controller makes a mistake, the pilot dies. Turns out the airplane had enough fuel to circle and land, butr damn it, heads should roll, or at least jobs lost. I hope the next time such an event happens the PIC TELLS the Controller p@ic@ he is landing on 17 Center, rather than request it. As it happens DFW was using 35 C runway for departures, and I gather it would have been 'inconvenient' to make a suitable hole. We should OWN the sky when we declare an emergency, and sort out the details once the event is over, dammit! Does anyone know the details of how a flight from Tulsa to Dallas ended up emergency fuel? Also, on my solo flight of a T-38 at Reese AFB, I had a compressor stall on climb out. I declared an emergency on and asked for a vector back to base. I was initially kind of ****ed off because I was told to maintain current heading. It was VMC, so I was seriously considering saying those magic words "Cancel IFR" when the controller gave me my vector back to base. Danny Deger |
#97
![]() "Ross" wrote in message ... The Dallas news said McKinney (KTKI) and Addison (KADS) were other choices. As someone else said, the decent cruise to KDFW would have been just as quick. What do you suppose the Dallas news would have said if the flight had crashed on the way to KTKI or KADS after being denied their choice at KDFW? |
#98
![]() "Not as Arrogant as Mxsmanic" wrote in message ... MXMORON WROTE: That statement makes it pretty clear that you don't understand this thread. I understand the FARs, which is a lot more important. -- Transpose mxsmanic and gmail to reach me by e-mail. Yeah, the FARs are really important when you're out of gas. Rulebooks are paper, the will not cushion the meeting of metal and stone. Earnest K. Gann Al G |
#99
![]() "Ross" wrote in message ... Steven P. McNicoll wrote: "Mike Schumann" wrote in message .. . I'm not saying that ATC didn't have a problem, but by the same token, it is also unacceptable for the pilot to continue to his destination after he declared an emergency to avoid the delays and hassles of diverting to a closer airport. What closer airport? The Dallas news said McKinney (KTKI) and Addison (KADS) were other choices. As someone else said, the decent cruise to KDFW would have been just as quick. This brings up an interesting question. Maybe a straight-in to the south was not a problem for these other airports, but a straight-in to the south at DFW was a pain in the ass for DFW traffic. Does ATC have the right to decline a straight-in to DFW if they can give the pilot a reasonable alternative? I would say ATC should immediately provide the straight-in to DFW if they can not give the pilot a different option, but if a straight-in to another airport is offered maybe they can deny the straight in to DFW. Obviously, to the pilot, landing at a non-DFW airport will create quite a fuss for his carrier. There will cerainly be a lot of ****ed off passengers that are delayed in getting to DFW. Obviously the pilot can fly the straight-in to DFW regardless of ATC clearance, but the pilot will have to answer to the FAA after he lands (this is hint that a "certain somebody" does not need to repeat for the upteenth time on this thread that the pilot can do what he needs to do in the event of an emergency). BTW, I don't see a regulation that requires ATC to do exactly what the emergency pilot wants at exactly the time the pilot asks for it in the FARs. There is a reg that says the pilot can deviate, but I can't find the one that ATC must obey the pilot without question or offering alternatives. Danny Deger -- Regards, Ross C-172F 180HP KSWI |
#100
![]() "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... KTKI has 7000 feet of runway, KADS had 7200 feet of runway. Both were in his flight path. Runway 15 at KADS is 6223', runway 33 is 6431'. I believe someone here said the airplane was a 777 but I don't think that's been confirmed. Will the runways at KTKI and KADS support a 777? Were they landing to the south at those airports? |
fuel leak or auxiliary fuel pump malfunction? | [email protected] | Owning | 7 | December 17th 06 12:57 PM |
Fuel quality control standards for aircraft rental/fuel sales... | [email protected] | Owning | 19 | January 19th 05 04:12 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Home Built | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Aviation Marketplace | 0 | January 26th 04 07:48 AM |
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve | Bill Berle | Owning | 0 | January 26th 04 07:48 AM |
