Weight and balance, ballast, trim when flying alone
Old January 15th 08, 05:53 PM posted to rec.aviation.piloting
Mxsmanic
Default Weight and balance, ballast, trim when flying alone
What is your method for handling weight and balance when you are piloting a
small aircraft alone? Do you just trim to adjust for the lateral imbalance,
or do you put something on the other side of the plane (ballast, luggage,
etc.) to balance it out, or what?
Old January 15th 08, 06:03 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
piloting a small aircraft alone?
lateral imbalance, or do you put something on the other side of the
plane (ballast, luggage, etc.) to balance it out, or what?
Why, you thinking of becoming ballast?
you're overqualified.
Bertie
Old January 15th 08, 07:52 PM posted to rec.aviation.piloting
Kloudy via AviationKB.com
Bertie
niiiice...
actually some of these are pretty good.
"underqualified" might be what I'd expect from you, yip.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200801/1
Old January 16th 08, 01:23 AM posted to rec.aviation.piloting
"Kloudy via AviationKB.com" u33403@uwe wrote in news:7e42a64257da1@uwe:
Bertie
niiiice...
As a flame, or as ballast myself?
Bertie
Old January 16th 08, 05:55 PM posted to rec.aviation.piloting
[quoted text clipped - 7 lines]
Bertie
Nah,
suggesting the simboi was underqualified as ballast.
Message posted via http://www.aviationkb.com
Old January 16th 08, 06:08 PM posted to rec.aviation.piloting
"Kloudy via AviationKB.com" u33403@uwe wrote in news:7e4e31d71a563@uwe:
Bertie
Nah,
Ah, OK. depends on what you wnat out of your ballast I suppose!
Bertie
Old January 16th 08, 02:25 AM posted to rec.aviation.piloting
Tina
I'm not sure, but would guess the outer edges of fuel tanks on
something like a Mooney centered about 8 feet from the centerline. If
there's a 10 gallon differential in the tanks -- 60 pounds -- that's
480 foot pounds of unbalance. That's about the same as a 300 pounder
sitting 1.5 feet from the centerline. We tend to burn an hour's worth
out of the takeoff wing (10 gallons easy) before switching, and the
airplane does not fly especially wing heavy.
Bertie, MX may not be overqualified as ballast. If, for example, I was
PIC (about 130 pounds) with a center of gravity (watch it now, if you
comment on the location of my center of gravity) 18 inches to the left
of centerline, a 260 pound ballast sitting in the back 9 inches to
the right of center would bring things into left and right balance.
There should be enough trim for fore and aft balance. You might assume
I would not invite ballast to sit in front.
Bertie
Old January 16th 08, 02:35 AM posted to rec.aviation.piloting
Tina wrote in
OK, he's perfect. I can't imagine any box of lead doing a better job.
Wel, you put ballast where it does the most good!
In anthony's case that would be in the Dumpster behind the airport cafe.
BTW, on big ones, there is a L/R loading issue, but it's only for floor
strength issues. It's only on widebody AC, though.
Bertie
Old January 16th 08, 03:39 AM posted to rec.aviation.piloting
Lead's better. It doesn't argue.
Dan
L23 weight and balance Tony Verhulst Soaring 5 December 31st 05 01:54 AM
Weight & Balance DVD jon Home Built 0 October 8th 05 05:39 PM
Weight and Balance Dale Larsen Home Built 2 June 23rd 04 05:11 PM
Weight and Balance JP Piloting 2 January 13th 04 10:54 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
