i think I flew into class c airspace accidentally withoutestablishing communication
Old January 28th 08, 07:25 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default i think I flew into class c airspace accidentally without establishing communication
"Gig 601XL Builder" wrote in message
Which is one of the systems I mentioned to start off with. But when I took
my PPL test ride ADF and GPS weren't options so I shortened it.
You said use of a VOR was in the PP requirements. It's not.
  #92
Old January 28th 08, 07:34 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
Larry Dighera wrote in
On Mon, 28 Jan 2008 10:04:29 -0800 (PST), Cary wrote
in :
Organization: http://groups.google.com
NNTP-Posting-Host: 152.131.11.16
But don't expect GoogleGroups to provide complete anonymity. For
instance, you posted your article from: Department of Veterans
Affairs. I just thought you'd like to know.
Netkkkoping ****.
Bertie
  #93
Old January 28th 08, 07:49 PM posted to rec.aviation.piloting
Gig 601XL Builder[_2_]
Default i think I flew into class c airspace accidentally without establishingcommunication
Bertie the Bunyip wrote:
Well, what I'm advocating is a bit more nuts and bolts nav sense if
people are going to start dicing with weather, rather than just rely on
GPS, so I think we're on the same page. The one in sixty rule just
means, for example, that every sixty miles you are from a navaid, each
degree is about one mile. So, if you're sailing along roughly abeam a
VOR with no DME, and you know your groundspeed is about 2 miles a minute
and you cover two degrees in about a minute, well, you know that that
VOR is sixty miles away. If you cover four degrees in a minute, you're
thirty miles and so on. It's rule of thumb, but it works well.
Likelyise, if you are dead reckoning on top and there is one quick
visual reference and you know how far it is off your dsired track since
our last known position, you can calculate your drift quite accurately
for your next leg. There's a thousand and one uses for it.
Cool eh?
Bertie
Yes it is cool and I'm pretty sure somebody taught it to me at some
point. It's back up in the front of the memory system now so, Thanks.
  #94
Old January 28th 08, 07:50 PM posted to rec.aviation.piloting
Peter Clark wrote:
On Mon, 28 Jan 2008 11:38:59 -0600, Gig 601XL Builder
Steven P. McNicoll wrote:
VOR is obviously implied by the language to even the most casual reader.
It's not implied at all to an informed reader.
OK Steven, please inform us what electronic navigation
systems these lines are referring to...
2. Demonstrates the ability to use an airborne electronic navigation
system.
3. Locates the airplane's position using the navigation system.
4. Intercepts and tracks a given course, radial or bearing, as
appropriate.
GPS? LORAN? ADF?
And........?
  #95
Old January 28th 08, 07:51 PM posted to rec.aviation.piloting
Kloudy via AviationKB.com
How many know the 1/60 rule?
Bertie
Looks like the worthwile posts to crap ratio.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200801/1
  #96
Old January 28th 08, 07:57 PM posted to rec.aviation.piloting
Peter Clark
On Mon, 28 Jan 2008 13:50:25 -0600, Gig 601XL Builder
system.
appropriate.
GPS? LORAN? ADF?
And........?
Of course VOR. I was agreeing that there are multiple choices of
radio style thing that can satisfy that section of the PTS.
  #97
Old January 28th 08, 08:00 PM posted to rec.aviation.piloting
"Kloudy via AviationKB.com" u33403@uwe wrote in news:7ee616c22803b@uwe:
Bertie
Could be worse....
Bertie
  #98
Old January 28th 08, 08:01 PM posted to rec.aviation.piloting
Gig 601XL Builder wrote in
on GPS, so I think we're on the same page. The one in sixty rule just
each degree is about one mile. So, if you're sailing along roughly
abeam a VOR with no DME, and you know your groundspeed is about 2
miles a minute and you cover two degrees in about a minute, well, you
know that that VOR is sixty miles away. If you cover four degrees in
a minute, you're thirty miles and so on. It's rule of thumb, but it
works well. Likelyise, if you are dead reckoning on top and there is
one quick visual reference and you know how far it is off your dsired
track since our last known position, you can calculate your drift
quite accurately for your next leg. There's a thousand and one uses
for it.
Cool eh?
Bertie
I still use it al the time, eve with teh pink string in front of me.
Bertie
  #99
Old January 28th 08, 08:19 PM posted to rec.aviation.piloting
george
Default i think I flew into class c airspace accidentally withoutestablishing communication
On Jan 29, 5:25 am, Bertie the Bunyip wrote:
Gig 601XL Builder wrote in news:13prvb8h2m12219
@news.supernews.com:
What if you are VFR over a cloud layer? There are lots of times that
GPS, VOR and even ADF are the primary navigation aids for VFR pilots.
Well, there are other, more traditional, methods that are really pretty
essential if you're going to do that. 1 in 60 rule, for instance.
Determinging drift from aircraft ref points and celestial bodies, that
sort of stuff.
Bertie
Last time I checked celestial navigation wasn't in the PP requirements
and use of a VOR was.
I know, but going vfr on top is kinda heavy territory for someone with a
fresh ppl anyway.
Me. But I'm old :-)
  #100
Old January 28th 08, 08:28 PM posted to rec.aviation.piloting
On Jan 28, 11:21*am, "Steven P. McNicoll"
"Gig 601XL Builder" wrote in ...
Last time I checked celestial navigation wasn't in the PP requirements and
use of a VOR was.
When did you last check? *"VOR" does not appear in Part 61.
The PP written exam expects you to know about VORs though.
Class B airspace notation BillJ Piloting 59 December 27th 07 12:48 AM
Class A airspace flying_monkey Soaring 66 October 22nd 06 03:38 PM
Class C Airspace Discussion Mike Granby Piloting 48 April 18th 06 12:25 AM
Meigs Class D Airspace Defly Instrument Flight Rules 0 July 19th 04 02:53 PM
Tower with only Class G Airspace Jeff Saylor Piloting 8 May 10th 04 09:53 PM
