Procedure for calculating weight and balance
Old January 6th 07, 02:47 PM posted to rec.aviation.piloting,rec.student.aviation
Mxsmanic
Default Procedure for calculating weight and balance
The manual for my aircraft gives figures for MOM and ARM at various
stations, but it doesn't actually explain how to use these to
calculate weight and balance. I want to place the load so that the
aircraft neither pitches down nor pitches up. Can someone provide me
with a pointer to an explanation of the procedure on the Web
somewhere?
Old January 6th 07, 03:02 PM posted to rec.aviation.piloting
Neil Gould
Recently, Mxsmanic posted:
somewhere?
The calculations are simple math. Why would you need a pointer to anything
but an elementary math book?
Neil
Old January 6th 07, 03:55 PM posted to rec.aviation.piloting
Mxsmanic
Neil Gould writes:
I'm sure the calculations are simple, but I still need an explanation
of which calculations to perform.
Old January 6th 07, 04:39 PM posted to rec.aviation.piloting
BT
"Mxsmanic" wrote in message
Neil Gould writes:
anything
An Example should be in the POH that explains everything
BT
Old January 6th 07, 04:50 PM posted to rec.aviation.piloting
Mxsmanic
BT writes:
I looked, and there are charts, but nothing specific on how to
actually calculate things. The Wikipedia article helped, although I
still don't know how to find the center of gravity in the aircraft, as
apparently manufacturers don't set their reference point at the actual
center of gravity (the point that would keep the aircraft level).
Old January 6th 07, 07:13 PM posted to rec.aviation.piloting
Orval Fairbairn
Mxsmanic wrote:
Neil Gould writes:
All W & B calculations result from taking the sum of all moments and
dividing by the sum of the associated weights.
Sum (arm*weight) / sum (weight) = CG
The arms are referenced to the datum -- an arbitrary point -- sometimes
the LE of the wing, sometimes a point ahead of the nose; but nonetheless
it is THE reference point for a given aircraft.
The POH will list the arms for each seat, fuel, oil, baggage, etc.
Old January 6th 07, 09:11 PM posted to rec.aviation.piloting
Mxsmanic
Orval Fairbairn writes:
OK, thanks. That doesn't seem too difficult. Apparently "moment" and
"arm" are synonyms (?).
I guess the manufacturer doesn't say exactly what point constitutes
neutral trim.
I've been experimenting with changing the payload in flight (one of
the advantages of a sim) and that helps a bit with figuring out how to
get the most neutral load distribution possible.
Old January 6th 07, 09:33 PM posted to rec.aviation.piloting
Thomas Borchert
Mxsmanic,
Dammit, learn to google and wikipedia, if you don't remember this
elementary stuff from school (you did go?). Moment is arm times weight.
neutral trim.
The manufacturer gives a range of allowed arm.
Thomas Borchert (EDDH)
Old January 7th 07, 02:55 AM posted to rec.aviation.piloting
BT
weight * arm = moment
they are not synonymous
total moments, divided my total weight = the current CG location
it has nothing to do with "zero trim"
BT
neutral trim.
Old January 6th 07, 10:55 PM posted to rec.aviation.piloting
Morgans[_2_]
Are you sure you want to be answering this putz? I beg of you; reconsider.
Differences between automotive & airplane engines Chris Wells Home Built 105 February 18th 06 11:00 PM
Pocket PC Weight and Balance Spreadsheet Navzilla Support Piloting 0 October 9th 05 11:47 PM
Cessna 172 F Weight and Balance [email protected] Owning 8 September 22nd 05 02:38 AM
172S Weight and Balance Question David J Piloting 9 March 23rd 04 01:08 AM
Weight and balance.. Bart Rotorcraft 9 August 19th 03 02:57 AM
