Feds Want to Equipe Gliders With Transponders and Radios
Old May 2nd 08, 09:15 PM posted to rec.aviation.piloting
WingFlaps
Default Feds Want to Equipe Gliders With Transponders and Radios
On May 3, 4:15*am, wrote:
Steven P. McNicoll wrote:
"Gig 601Xl Builder" wrote in message
news:jqednZIj4dsLq4fVnZ2dnUVZ_u2dnZ2d@supernews .com...
Are you asking about stoke or if it is a problem to ATC?
I'm asking how TSA's view of things is a problem to ATC.
If national security, a DHS issue, overlaps ATC, a DOT issue, don't
count on DOT winning the argument.
Yes one must concider the potential horror of fleets of all fiberglass
gliders with no transponders coming across the Atlantic filled with
terrorists and nuclear bombs.
I didn't imply that there was such a threat. This as most conversations
with Mr. McNicoll is an offshoot of the original conversation. Because
he made some comment that while not really wrong isn't how the real
world works.
Didn't say you did.
My point is that in a sane world (big leap of faith there) DHS wouldn't
have any interest in gliders as one would be hard pressed to come up
with a scenario involving national security and a glider.
Not hard at all.
It flies, it can carry a bomb and explosives. It is cheap and readily
available.
Cheers
  #122
Old May 2nd 08, 11:35 PM posted to rec.aviation.piloting
Steven P. McNicoll[_2_]
m...
m...
TSA is in DHS, DHS does not dictate ATC policy.
No the POTUS does and he probably listens to DHS more than DOT.
What ATC policies have been dictated by the POTUS? Why would the POTUS
rely on DHS for ATC policy over DOT? Would he rely on DOT over DHS on
security matters?
And policy promulgated by DOT, DHS, DOD, is dictated by the POTUS.
What ATC policies have been promulgated by DOT, DHS, or DOD?
In most cases it is actually dictated by people he selects to handle those
departments but the final authority rests on the desk of the POTUS.
What ATC policies have been promulgated by the secretaries of DOT, DHS, or
DOD?
As for your other two questions think overlap.
Why can't you just answer the questions?
  #123
Old May 3rd 08, 01:11 AM posted to rec.aviation.piloting,rec.aviation.soaring
Eric Greenwell
Alan wrote:
Other factors include the output voltage under load at discharge -- a
lead acid battery is rated to 10.2 to 10.5 volts for a "12 volt" battery
at discharge.
Powersonic uses 10.5 volts for 5 to 20 hour discharge rates.
Unfortunately, most 12 volt radios and devices are designed
for a charging electrical system, with a voltage of about 14 volts.
Most panel mounted radios (definitely for Dittel and Becker radios)
bought new in the last 20 years (and even some older ones) meet the
current requirements to function properly to 10.5 volts, and at even
lower voltages, but with reduced power output. "Very old" radios likely
will have problems at 10.5 volts. I have no idea what the percentage of
"old" and "new" are.
When
the battery is down to 75% of the expected voltage for the radio, not all
of them work. I have had aircraft radios that would not transmit below
about 11.5 volts, at which point the battery would be still above 50% charged.
Powersonic shows it's batteries have only 25% capacity left at 11.5
volts. I haven't checked other brands, but believe they are the same for
the batteries we use in our gliders.
Lead acid batteries are normally rated for capacity at a 20 hour rate of
discharge. A 7 AH battery would deliver 7000 / 20 = 350 mA for 20 hours.
Faster discharge rates result in less capacity being available (look up
Peukerts exponent for more details). Discharging faster than that, reduces
the amp-hour capacity of the battery.
At a current drain of 700 ma (10 hour rate) that you might have with
transponder, radio, etc, Powersonic shows a capacity of 90% of the 20
hour rate. That's not a show-stopper, but worth taking into account.
Lead acid batteries have less capacity when cold. One guide suggests that
for every 10 degrees centigrade below room temperature, you should add 10%
to the battery capacity needed. High altitude flight tends to get up into
cold places.
This corresponds with the Powersonic chart, so at -10C (15F), you have a
30% loss of capacity. For winter flying, and spring or fall flying in
places where you can climb to, say, 10,000' agl, it's an important
factor. Especially so, when you know your encoder will likely be using
it's heater, adding 50-150 milliamps to your current drain.
  #124
Old May 3rd 08, 08:27 AM posted to rec.aviation.piloting,rec.aviation.soaring
Morgans[_2_]
"Eric Greenwell" wrote
This corresponds with the Powersonic chart, so at -10C (15F), you have a 30%
loss of capacity. For winter flying, and spring or fall flying in places where
you can climb to, say, 10,000' agl, it's an important factor. Especially so,
when you know your encoder will likely be using it's heater, adding 50-150
Put a insulated cover around the battery, and the heat of discharge will keep
it warm and the capacity up, unless it is seriously freakin' cold.
  #125
Old May 3rd 08, 03:49 PM posted to rec.aviation.piloting,rec.aviation.soaring
Eric Greenwell
a 30% loss of capacity. For winter flying, and spring or fall flying
in places where you can climb to, say, 10,000' agl, it's an important
keep it warm and the capacity up, unless it is seriously freakin' cold.
Insulating it will keep if from cooling off as quickly, but I'm
skeptical about the amount of self-heating. Do you know how much it is,
or where I can find a reference to it that applies to the batteries we
us? Insulating my battery is difficult due to it's location, so I'd like
to know it's worth the effort before attempting it.
  #126
Old May 3rd 08, 09:37 PM posted to rec.aviation.piloting,rec.aviation.soaring
Bob Noel
WingFlaps wrote:
How slow does a target need to be to be undisplayed -typically? I
would have thought that even a glider is fast (45 knots) compared to
usual clutter.
Don't forget that it's the radial velocity that is detected by skin paint.
Bob Noel
(goodness, please trim replies!!!)
  #127
Old May 3rd 08, 11:18 PM posted to rec.aviation.piloting,rec.aviation.soaring
WingFlaps
On May 4, 8:37*am, Bob Noel
usual clutter.
Aha, someone who understands Dopplewho knows!. data from the secondary
sites can fix that problem.
Cheers
  #128
Old May 4th 08, 12:15 AM posted to rec.aviation.piloting,rec.aviation.soaring
In rec.aviation.piloting WingFlaps wrote:
On May 4, 8:37?am, Bob Noel
usual clutter.
The FAA radars are what they are.
You can arm wave forever about what they could be, but that isn't going
to change them.
Jim Pennino
Remove .spam.sux to reply.
  #129
Old May 4th 08, 01:07 AM posted to rec.aviation.piloting,rec.aviation.soaring
Larry Dighera
On Sat, 03 May 2008 23:15:03 GMT, wrote in
to change them.
But decommissioning them, as part of the ADS-B implementation, will
make them moot.
Gliders, transponders, and MOAs Greg Arnold Soaring 2 May 26th 06 05:13 PM
Cessna forced down by the Feds C J Campbell Piloting 51 February 8th 05 01:29 PM
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* JStONGE123 Military Aviation 1 May 11th 04 06:22 AM
Transponders and Radios - USA Ray Lovinggood Soaring 1 February 27th 04 06:10 PM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 2nd 03 11:27 PM
