Tweaking the throttle on approach
Old March 14th 07, 09:20 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Capt. Geoffrey Thorpe
Default Tweaking the throttle on approach
Mxsmanic wrote:
You've never flown a baron. Stop lying. Real pilots who haven't caught
on to your bull**** and lies might be dangerously confused.
We really aren't that stupid.
Geoff
  #132
Old March 14th 07, 10:47 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
On Mar 14, 10:23 am, Mxsmanic wrote:
I'd prefer a system that allows me to draw fuel symmetrically from tanks on
both sides of the aircraft. That way imbalance is one less thing that I'd
have to worry about.
In my plane, that imbalance is not an issue. I start by flying 30
minutes on one side, then switch to the other side for 60 minutes,
then back for another 60 minutes. 30 minutes of imbalance is about 5
gallons (30 lbs) and not noticeable to me. A bigger worry is not
remembering to change tanks and then running a tank dry at low
altitude, might be on the ground before figuring out what's wrong.
2. Condensation rarely is the problem. The real problem is poorly
sealing fuel caps.
You just said they couldn't be sealed, so how is this a problem?
I think he means rain being driven into the tank past poor seals on
the fuel caps. I see this occasionally on my plane. But I get very
little, if any, condensation. All tanks that I know of on small
planes have a vent somewhere to let air in, so that the fuel will come
out.
  #133
Old March 15th 07, 12:10 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
chris[_1_]
On my Garmin 96 there is a built in fuel timer - set it for however
many minutes you want between changes and it somehow knows when you're
flying and when you're not, and lets you know when a tank change is
due.
sealing fuel caps.
out.
One of the club planes I fly must have a dodgy seal on one of the fuel
tank caps - I always seem to get a bubble of water when sampling from
one tank but never the other..
  #134
Old March 15th 07, 12:13 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mike Young
"Gary" wrote in message
first. There are reasons why kids learn to read with books from Dr.
Seuss rather than Dr. Salk, why the first science class offered in
elementary school isn't quantum physics; why you can't go from junior
That's not a bad place to leave it. Sims are not an unreasonable first step,
just as Sam I Am makes for a companionable reading primer. The skills and
decision making transfer directly. Some don't progress much beyond flipping
pages and looking at the primary color illustrations, but others have
returned in later life to study his use of anapestic tetrameter. You get out
of it what you put into it. It can be a little. It can be a lot.
  #135
Old March 16th 07, 06:34 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Roger[_4_]
On Wed, 14 Mar 2007 08:54:41 -0400, Ron Natalie
Mxsmanic wrote:
A flight in the sim takes the same time as its real-life counterpart, though.
Bull****. I don't have to preflight the simulator, or pull it from the
hangar, or preheat it, or get it started, or call for the fuel truck
or any of the hundred things that REAL pilots have to deal with with
flying REAL airplanes that you'll never experience in your pathetic
little fantasy world. Don't lecture real pilots (or those who are
attempting to become real pilots) from your distorted self-interested
masturbation.
You missed a rough run-up where you make the go-nogo decision, the
taxi back to the hangar, wait for the engine to cool enough to handle
the plugs which are almost impossible to get at, then spend the better
part of another hour cleaning the lead out of the plugs. (Did that
last week)
I think so. If you can learn all the complex and HP stuff _eventually_, then
that also means that you can learn it right up front. It might seem more
daunting at first than a simple aircraft, but the overall elapsed time to
become proficient in the complex aircraft would be the same in both
situations.
Again you have no clue. The some of the time will be longer as
you waste time initially being behind the complex aircraft which will
entail more instruction time than if you started simple and worked up.
After you get competence in the simple aircraft, adding the control of
the complex is trivial.
It even confuses a pilot with many hundreds of hours in a 172 or
Cherokee. :-)) Like many things it's easy once you've done it, or it
looks easy if you haven't.
On a high wing aircraft, the fuel system is gravity fed, and you have
a fuel selector with L / R / Both choices. Leave it on Both and
you're set.
Sounds good to me.
It shouldn't. If you bothered to study anything, the above isn't valid
for even Cessnas. Cessna recommends operating in LEFT or RIGHT at
high altitudes. I'm not going to go into the reasons because your
game doesn't vapor lock.
Low wing aircraft (Cherokee specifically) do not have a Both option.
You have Left or Right, and it's up to the pilot to manage his fuel.
For instance, you start on least full tank, switch to fullest before
takeoff. Every 30 minutes, for instance, you need to switch tanks, or
risk a weight imbalance, or at worst, engine failure due to fuel
starvation.
Wow ... sounds incredibly primitive. I guess crossfeeds and stuff like that
are still future science-fiction for small aircraft.
I wonder what he thinks of a plane where you have to pump gas from
front to back in flight to keep the CG where you want it?. Primitive?
No more science fiction than your pathetic brain. My aircraft is a low
wing and has a both position on the fuel selector and tip tank
crossfeeds for a long time. But it adds weight, complexity and things
that may go wrong just as easily as forgetting to switch tanks.
In a twin, though, you have one tank per engine, so you should be able to feed
the right engine with the right tank, and the left with the left tank.
Again, your pathatic idealized world doesn't correspond to reality. Do
you think the fuel flow on each engine is identical? Do you think the
line guy filled both tanks to the same level?
And then look at all the tanks they have in a modern airliners.
I've gotten pretty low in the tanks in the Baron and I've never had to switch
tanks. The only time I've ever had to touch it was for engine failure, in
which case I obviously direct both tanks to the non-failing engine.
Or just dangerous.
Point taken. But I have read that it's good practice to keep plenty of fuel
in the tanks when possible, not only to maximum your reserves but also to help
exclude condensation (I guess small aircraft haven't discovered airtight seals
yet, either).
Again your pathetic ignorance is showing. If you bothered to actually
study things rather than basing the entire world on what you can observe
of Microsoft's simplification of flight you'd know that:
1. The tanks can't be sealed. As fuel goes out, air must go in (either
that or you'll have to have fuel tanks like a playtex baby bottle with
a collapsing bladder.
sealing fuel caps.
I took off one day when one of the "old" or maybe I should say *OLD* O
rings let go. Man, It looked like a contrail, but it was nothing
compared to the day when I did a short field TO and rotated abruptly
at the intersection of our two runways which is considerably higher
than the the rest of 18/38. The filler caps were getting tired on the
tip tanks and they both let go at the same instant. Those 15 gallon
tanks were *dry* after just going around and staying in tight. They
were probably dry by the time I turned cross wind.
Interesting. Full flaps on the Baron do create a lot of drag, but the
"approach" setting creates far less. It's a poor speedbrake--the gear works
better for that (but has a lower maximum speed). When I extend the flaps in
the Baron, I rise very noticeably, then I slow down significantly and I start
to lose altitude; with full flaps, there's a noticeable tendency to pitch
down, too. But I'm expecting all this so I adjust for it.
Again, stop lying. You've never flown a Baron. You don't know how
they behave aerdodynamically.
Is it a good aircraft? I've heard stories about Pipers.
Stories is all you've heard about anything.
How far above the runway? And you don't stall or get a tail strike?
Neither. If you bothered to learn something about ground handling in
wind you'd know these things. It's the first thing that REAL pilots
do in an airplane.
In the Baron I don't think I've ever pulled the yoke all the way back. I stay
almost level until I'm very close indeed to the runway, then pull back on
power a bit and flare. No idle and no full back stick, though. I haven't
actually tried that, but from the way the Baron behaves my intuition tells me
it wouldn't be suitable.
You've never flown a Baron, and you've never pulled a real yoke back.
I heard that you run out of elevator authority if you get too slow but
that's only a guess...
Possibly. I'm usually at least 10 kts above stall speed so I don't really
know (or maybe you are not talking about a Baron?).
Maybe he's talking about a real Baron and not your pathetic fantasy.
www.rogerhalstead.com
  #136
Old March 16th 07, 07:09 AM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Tony
It's worth remembering that once basic aircraft control, navigation,
and communication are taught, most of the flight instruction one gets
for PP or IR is related to dealing with what I'll call adverse events.
We had been taught how to recognize instrument failure and what to do
about it, engine failure and what to do about it, pilot error and what
to do about it, getting into an unusual attitude and what to do about
it, what the airplane feels like and might do if we're close to an
edge (too low and too slow because the low level wind is much greater
than expected because it's a first gust on final comes to mind) -- the
list goes on and on. If one sets 'realism' to high in a sim, does one
get those kinds of failures as often as they might happen with a
general aviation aircraft? Does the weather go marginal, does ice grow
on the wings, vac pumps fail, those sort of things that most of us who
have been pilots for a few hundred hours have experienced?
Oh? you can get them in a sim if you program them in? Actual airplanes
do allow us to simulate emergencies, but in real life sometimes it's
not a simulation.
masturbation.
last week)
situations.
you're set.
Sounds good to me.
starvation.
Or just dangerous.
yet, either).
sealing fuel caps.
do in an airplane.
(N833R, S# CD-2 Worlds oldest Debonair)www.rogerhalstead.com- Hide quoted text -
- Show quoted text -- Hide quoted text -
  #137
Old March 16th 07, 08:31 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
due.
My 196 has a similar feature, although I usually use a separate timer,
or just put a mark on my flight plan when I should switch. What a
REALLY want is just a simple countdown-type timer that signals when
time is up by flashing a large bright light that I can't miss, similar
to the big red stall warning light on the instrument panel of my
Cherokee. I've never found one for sale, but I've thought about
trying to construct one with my rudimentary electronics skills and a
bunch of Radio Shark parts.
  #138
Old March 16th 07, 10:43 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Roger writes:
The Concorde was a special case, although it was primitive by today's
standards.
And the increasing automation in their management.
  #139
Old March 16th 07, 10:46 PM posted to alt.games.microsoft.flight-sim,rec.aviation.piloting,rec.aviation.student
Mxsmanic
Tony writes:
Simulators (including MSFS) usually allow failures to be adjusted
independently of overall realism. So you can have anything from a 100%
reliable aircraft to one that experiences multiple catastrophic failures even
before pushback. Many types of failures are so impractical or dangerous to
practice in real life that they can only be experienced safely and
economically in a simulator.
This is also controllable in a sim.
It's a parameter setting rather than a programming problem.
Actual airplanes
not a simulation.
The most critical emergencies cannot be practiced outside of a simulator,
because they are too dangerous or expensive. You either learn to handle them
in a simulator, or you don't learn to handle them.
Airline pilots practice engine failures regularly in simulators, even though
most of them will never see a real-world engine failure during their careers.
  #140
Old March 23rd 07, 06:47 AM posted to rec.aviation.piloting
Bertie the Bunyip[_2_]
Default Mx: Tweaking the throttle on approach
Mxsmanic wrote in
EridanMan writes:
Its called 'pilot workload'.
In a real aircraft, you must:
-Fly the Plane
-Operate The Aircraft Systems
-Keep track of your current location
-Communicate with ATC
-Keep Watch for Traffic
-Plan your future track (or reference your flightplan), this includes
making absolutely sure you remain clear of all restricted airspace.
All in a reasonably loud, chaotic setting, with absolutely no option
to 'pause'...
Sounds doable, with a bit of practice. I don't have much trouble with
it in the sim.
Snort!
Bertie
ID Please - Throttle Quad Orval Fairbairn Restoration 0 December 17th 05 08:35 PM
Throttle movement Max Richter Naval Aviation 12 December 11th 04 11:09 PM
Engine throttle Bob Ingraham Simulators 13 December 11th 04 07:17 PM
Which throttle governer? Garfiel Rotorcraft 1 December 13th 03 04:30 PM
Completing the Non-precision approach as a Visual Approach John Clonts Instrument Flight Rules 45 November 20th 03 05:20 AM
