Throttle movement
Old December 8th 04, 07:36 PM
Max Richter
Default Throttle movement
Hallo,
i know that French;Italian and Japanese airplanes prior and in WW2 had
an opostite throttlemovement than British;American and German airplanes.
I mean that to increase power you had to pull the Throttle backwards and
not forward.
Now i asumed that after WW2 with the availability of surplus British and
American planes to the mentioned countrys this habit was not longer
followed.
Now i read that the French got T28 in the early sixties and modified
them to the COIN-configeration and the reversal of the
throttlequadrantmovement was one of the mentioned modifikations.
Now my question: have Mirages or Rafales or any other airplanes this
oddity also.
Or became it extinct in the world.
Thank You
Max
Old December 9th 04, 12:33 AM
Orval Fairbairn
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
Thank You
Max
If not, it should have become extinct!
Old December 9th 04, 02:49 AM
Jake Donovan
I have a few hours in FENECs, the French T28 and unless they were modified
back to US configurations, the throttles where the same as the old B's and
C's I flew.
A Rafele I flew at Empire had a "normal" throttle configuration.
Just my observation of these 2 aircraft. I can not comment if either one
was modified previously.
Jake
"Orval Fairbairn" wrote in message
news
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
Thank You
Max
Old December 11th 04, 09:37 PM
Orval Fairbairn
In article
Orval Fairbairn wrote:
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
Thank You
Max
Upon reflection, I have flown a friend's EADS Epsilon, which has the
"proper" throttle movement (push for thrust), so it appears that even
the French can make some progress!
Old December 9th 04, 05:02 AM
Guy Alcala
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
I asked an IAF pilot about this some years ago. He'd flown Ouragans, dual
Mirages and Kfirs (the majority of his combat time was in A-4s). He said
they and theVautour all had standard (forward = increased throttle)
movement. The same was presumably true of Mysteres and Super Mysteres, but
hehad npo personal experience.
Guy
Old December 9th 04, 04:50 PM
Ken Duffey
Guy Alcala wrote:
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
Guy
Wasn't the wing sweep lever on the F-111 changed early in its
development programme??
IIRC, the engineers designed it so that, moved forward, the wings swept
back (to go faster, same as throttle), moved back, the wings swept
forward (to slow down - same as throttle).
The early test pilots insisted it be changed to a 'natural' movement -
back to sweep the wings back, forward to sweep them forward.
Or was it the other way round ???
Ken
Old December 9th 04, 05:55 PM
nafod40
I don't know why, but it reminds me of the timne I was at the Norfolk
airport (departures on one side, arrivals on the other), standing
outside waiting for my ride for and hour and a half. Finally took a
taxi. When I got home, asked my wife why didn't bother to pick me up.
There may have been a "WTF" in there. She said, "I was waiting on the
DEPARTURE side of the airport. You were departing the airport, weren't you?"
Old December 10th 04, 10:55 AM
Guy Alcala
Ken Duffey wrote:
Guy Alcala wrote:
Max Richter wrote:
Hallo,
not forward.
followed.
oddity also.
Guy
The wing sweep control (aka the Trombone handle) of the production a/c pulled
back to sweep the wings back, and forward to sweep them forward; even so, it
wasn't an intuitive design, and labelling the extremes FWD and AFT really didn't
help. Bill Gunston, in his ARCO book on the F-111, says that at least three
experienced pilots, including one company test pilot, got it wrong with serious
consequences. He wrote that it's mildly amazing that 40 years after a/c controls
began to be designed to resemble the system they were controlling to avoid
errors, no one insisted on having a small 'wing' mounted on the cockpit side,
which would be moved in exactly the same direction as you wanted the real one to,
and which a single glance at would eliminate any possible confusion.
Guy
Old December 11th 04, 03:34 AM
Gord Beaman
Guy
Yes...pilot error will always be with us despite what Mary says..
-Gord.
(use gordon in email)
Old December 11th 04, 03:00 PM
Pechs1
Guy writes about the F-111- Bill Gunston, in his ARCO book on the F-111, says
that at least three
consequences. BRBR
I say-after flying the Turkey, Ifind it amazing they 'got it wrong' with the
wingsweep. Altho the F-14 wings were auto, every once in a while you moved them
around manually while airborne. It seems intuitive to me, particulalry since it
changed how the A/C 'felt', when moving them back. Plus the switch was aft for
back, forward for forward.
P. C. Chisholm
CDR, USN(ret.)
Old Phart Phormer Phantom, Turkey, Viper, Scooter and Combat Buckeye Phlyer
Lycoming throttle linkages Evan Carew Home Built 0 September 29th 04 01:58 AM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
Throttle friction lock slipping - How do I stop this? Ron Home Built 2 January 24th 04 12:55 AM
Shakespeare Throttle Friction Lock Larry Smith Home Built 3 November 8th 03 03:01 PM
Rotax 912 Full Throttle Springs Mark Callahan Home Built 0 July 5th 03 01:31 PM
