Electrically Powered Ultralight Aircraft
Old August 17th 07, 10:19 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
Default Electrically Powered Ultralight Aircraft
Morgans wrote:
wrote
Unless the added weight is enough to deform the tires, the increase
in rolling resistance in the total energy expediture can't be found.
Bull hockey.
Just because it is not noticeable, or measurable by the lack of sensitivity
with the instrument you are currently not using, does not mean that it does
not exist.
More weight on the bearings will cause more rolling resistance. That is
fact, not open to dispute. If you say it is, I want to buy the rights to
the bearings you are using, so I can patent them and make a fortune.
If a bird craps on your windshield, it is more likely to noticeably
influence your aerodynamic drag than rolling resistance.....I took Jim's
"can't be found" to mean lost in the noise. According to SAE studies,
aerodynamic drag accounts for 60% of the resistance that must be
overcome for highway cruise, with tires being 25% and driveline friction
making up the last 15%.
I suspect an electric motor and associated batteries however, are going
to deform the tires. The power companies that I work with are doing
studies on a number of electric vehicles. I have been told that they
run some interesting tires and pressures.
Charles
  #144
Old August 17th 07, 11:52 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Dan Luke[_2_]
not exist.
aerodynamic drag accounts for 60% of the resistance that must be overcome
for highway cruise, with tires being 25% and driveline friction making up
the last 15%.
Pardon the intrusion on this interesting discussion, but just how *does* added
weight in a car impose extra load on the powerplant besides via bearing
friction and tire deformation?
Added weight means the powerplant is doing more work to maintain the same
speed; there's no way around it, the laws of physics demand it. So where's
the extra power going?
Dan
T-182T at BFM
  #145
Old August 17th 07, 11:58 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
cavelamb himself[_4_]
not exist.
the last 15%.
To accellerate...
  #146
Old August 18th 07, 12:20 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Phil
On Aug 17, 2:19 pm, "Morgans" wrote:
"Phil" wrote
IF these can be made practical, they sound ideal for use in an
airplane. They are light, and they can be shaped in just about any
way to fit inside the airframe. Suppose they were integrated into the
airframe and wings such that a large percentage of the airplane
consisted of battery. It might be possible to get enough capacity
there for a practical general aviation electric plane.
I can see the headlines, now.
Plane (or car) crashes, and the car's structure electrocutes the occupants.
g
I know you're only half serious, but yes, that would have to be
considered. That's a risk in hybrid autos as well. EMTs and
firefighters are taking special training to handle the wrecks of these
cars. And the gasoline we use for our current airplanes poses the
risk of incinerating the occupants in a crash. I am not sure that an
electric plane would actually pose more risk. I would think that the
increased reliability of the propulsion system would decrease the risk
overall. How many people are killed every year in crashes caused by
engine failures?
  #147
Old August 18th 07, 12:40 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Matt Whiting
not exist.
the last 15%.
Heating the brakes. :-)
Matt
  #148
Old August 18th 07, 12:55 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
not exist.
the last 15%.
It takes more power to accelerate the car to cruise speed in a given time.
F=ma
Ummm, no, quite the opposite.
The laws of physics say once an object is in motion it takes no energy
to maintain the velocity UNLESS there is some other force at work
that would cause the velocity to decrease.
Since at a constant speed, the a in F=ma is zero, the force is zero
no matter the mass.
Once at speed in a car (or airplane or rocket ship) the only energy
needed to maintain speed is that equal to any drag forces that
would otherwise slow the car down.
Have you looked at the current crop of high mileage cars?
They all have very aerodynamic profiles to get the air drag down.
Jim Pennino
Remove .spam.sux to reply.
  #149
Old August 18th 07, 02:33 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Ernest Christley
no matter the mass.
They also have very narrow, hard tires. Unfortunately, the DOT has laws
against solid rubber tires or they could be made even harder.
Your analysis would be mostly correct if we were talking about trains.
I've stood beside a loaded one and watched it deform the tracks. A car
on the road is like a machine rolling across a mattress. Extra weight
pushes the tire down into the mattress and increases the drag. The
energy is going into deforming the tires and heating them. Ask any over
the road trucker what happens when you're hauling 40-tons and you don't
keep your tire pressure up. Tends to light up the night.
  #150
Old August 18th 07, 03:05 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
no matter the mass.
My analysis of what?
The biggest source of drag on a car is air followed by tires.
Of course the makers are going to put hard tires on as well as
streamline the vehicle to get mileage up.
The less drag, the less gas the vehicle uses.
What's your point?
Jim Pennino
Solar powered aircraft. Was: Can Aircraft Be Far Behind? Jim Logajan Piloting 4 February 9th 07 01:11 PM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Is JB Weld electrically conductive? Scott Home Built 14 July 12th 04 11:24 PM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
