#11
On Aug 30, 11:31*am, Andy wrote:
On Aug 30, 7:06*am, bildan wrote: On Aug 29, 6:05*pm, tstock wrote: On Aug 29, 4:34*pm, wrote: Educational video... Murphy's law at work... one thing leads to another... towplane: Wilga glider: LAK place and time: competition at Pila in Poland, late August 2009 towplane's engine misses than cuts off during takeoff prop collides with the wingtiphttp://picasaweb.google.pl/Wojtekpara/Wypadek#5238527461393125826 Andre V, CFIG Any clues as to what caused the tow pilot to lose control at the end of the runway and/or make the hard right turn into the glider's path? After watching this a couple of times, it appears to me the tug pilot intended to turn around and didn't lose control until he saw the glider about to collide with him - a failure to maintain situational awareness. I've had a tug abruptly stop on the runway centerline just after I was airborne forcing me to fly around him - it's an experience I won't forget. *Just as in flight, the tug pilot should bear left if aborting takeoff on the runway so the glider has somewhere to go. The PZL 104 Wilga's Russian Ivchenko/Vedeneyev radial can be a cranky beast - 'ready to go' and 'ready to quit' sound about the same. *The tug pilot may have been confused by that. I had an L-19 run out of gas on me on a downhiill asphalt runway. I had just broken ground and my LS-3 was full of water. Full spoilers and flying it onto the runway to engage the LS's powerful Tost drum brake (not!) was the only thing that kept me out of the swampy overrun. The tow pilot was smart enough to coast to a stop off the left edge of the runway, leaving me room to scoot past on the right edge of the pavement. *I ended up with the tow rope wrapped around my axle but no harm done. The "tug out of gas" incidents/accidents are getting old. I can recall no less than a dozen - which means 10x that number are likely to have happened. You'd think a pilot who is back on the ground every 10 minutes would have time to check his fuel. We had an as yet unexplained fuel exhaustion incident this summer - the pilot glided safely back to the runway. One possibility is that a fuel drain continued to dribble fuel overboard after the pre-flight. Please take a second or two to check the drains shut off after taking a fuel sample. |
At 17:31 30 August 2009, Andy wrote:
On Aug 30, 7:06=A0am, bildan wrote: On Aug 29, 6:05=A0pm, tstock wrote: On Aug 29, 4:34=A0pm, wrote: Educational video... Murphy's law at work... one thing leads to another... towplane: Wilga glider: LAK place and time: competition at Pila in Poland, late August 2009 towplane's engine misses than cuts off during takeoff prop collides with the I had an L-19 run out of gas on me on a downhiill asphalt runway. I had just broken ground and my LS-3 was full of water. Full spoilers and flying it onto the runway to engage the LS's powerful Tost drum brake (not!) was the only thing that kept me out of the swampy overrun. The tow pilot was smart enough to coast to a stop off the left edge of the runway, leaving me room to scoot past on the right edge of the pavement. I ended up with the tow rope wrapped around my axle but no harm done. I doubt very much if the brake fitted to any glider is going to stop it anytime soon if it is full of water and even if it did I suppose the water would be handy to put out the brake fire. In the case of the LAK it is a heavy beast even without the water, as anyone who has been conned into rigging one will testify. If the tug does not get out of the way it's going to collect the glider. |
![]() I doubt very much if the brake fitted to any glider is going to stop it anytime soon if it is full of water and even if it did I suppose the water would be handy to put out the brake fire. In the case of the LAK it is a heavy beast even without the water, as anyone who has been conned into rigging one will testify. If the tug does not get out of the way it's going to collect the glider. Looks like a LAK 17 rather than a 12. |
On Sun, 30 Aug 2009 19:46:05 +0200, "Maciek K."
wrote: Also the weather was very poor: four tasks played during 16 days of competition (two of them played on the 16th day - yes, two tasks played one day). I was too curious, so I find found out! http://www.soaringspot.com/smpj/resu...ay-by-day.html Aldo Cernezzi |
On Aug 30, 8:15*pm, Don Johnstone wrote:
In the case of the LAK it is a heavy beast even without the water, as anyone who has been conned into rigging one will testify. Sorry to go off-topic but the LAK-12 (to which you must be referring, though this glider is a LAK-17) is 100 pounds lighter than an ASW-17. So when you say "heavy beast" I assume you are referring not to the glider itself, which is on the light side for a 20.5-meter. You must be referring to the fact that the wings are one-piece. All that is needed is a decent wing-rigging dolly and so forth and it becomes a one-man operation. The dolly carries the weight, not the human. But without proper knowledge of how to align the wings it will be difficult to assemble. With proper knowledge and rigging aids it is a rather easy one-man operation. The secret to rigging a LAK-12 is finesse, not brute force. Disassembly is rather easy since no finesse (critical wing alignment) is required. I suspect the same is true of many 15-meter gliders. Regards, -Doug |
Ouch. Myself being Lak-17 owner it was just painful watching that
beautiful wing getting chopped off. Looking at the takeoff I can see the glider was loaded with water to the top and wheel brakes are pretty weak on Lak-17s. Limus |
Isn't there supposed to be a convention that the tug pilot turns right and
the glider pilot turns left (or the other way round) in the event of an engine failure during the take off ground run? Derek C At 23:13 31 August 2009, Limus wrote: Ouch. Myself being Lak-17 owner it was just painful watching that beautiful wing getting chopped off. Looking at the takeoff I can see the glider was loaded with water to the top and wheel brakes are pretty weak on Lak-17s. Limus |
At 13:00 01 September 2009, Derek Copeland wrote:
Isn't there supposed to be a convention that the tug pilot turns right and the glider pilot turns left (or the other way round) in the event of an engine failure during the take off ground run? Derek C Hmmm.... Maybe in a wide open space like Lasham, but be careful not to plant a bad seed here, Derek. ;o) |
On Sep 1, 9:00*am, Derek Copeland wrote:
Isn't there supposed to be a convention that the tug pilot turns right and the glider pilot turns left (or the other way round) in the event of an engine failure during the take off ground run? In the US I believe the answer is yes. From my copy of the SSA Soaring Flight Manual: "If the towplane loses power, the sailplane pilot should immediately release, maneuver to the right of the towplane, and stop as quickly as possible. The tow pilot can then discontinue the takeoff and maneuver to the left side of the runway." Regards, -Doug |
![]() "If the towplane loses power, the sailplane pilot should immediately release, maneuver to the right of the towplane, and stop as quickly as possible. *The tow pilot can then discontinue the takeoff and maneuver to the left side of the runway." This is exactly what I did many years ago in the same situation. I was unable to stop my ballasted open-class ship before reaching the towplane and coasted past it on the right. I recall seeing the propeller stop abruptly as I was just about airborne. He pulled to the left and I went right - no problem. Mike |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Airplane collides with ambulance | Don Pyeatt | Aviation Photos | 3 | May 26th 07 07:58 AM |
Glider - Towplane Signals | Mike the Strike | Soaring | 24 | March 26th 05 09:33 PM |
VIDEO: Frecce Tricolore collides over Ramstein - a new head on video | Montblack | Piloting | 1 | February 12th 05 04:03 AM |
Auto-rotating helicopter hits towplane during take-off | Dave Nadler \YO\ | Soaring | 8 | August 20th 03 04:14 AM |
