Cherokee 140 Oil Temp Sending Unit
Old September 11th 09, 01:08 AM posted to rec.aviation.owning
Mike Spera
Default Cherokee 140 Oil Temp Sending Unit
O.K., I'll chase those numbers down.
"Scott Braddock" wrote in message
mmunications...
Mike Spera wrote:
Scott,
That's the gauge you are looking at, not the sending unit. I don't need
the gauge.
Mike,
My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68,
"Electrical System Installation", item #63: "Gauge-Engine Unit, Oil
Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows
Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW).
Bear in mind all of those #'s have probably been superceded by now, but
perhaps a Piper dealer or Lycoming distributor can take you from there.
Happy Flying!
Scott Skylane
Mike,
I believe the part #'s I gave you are the correct ones. If you have
access to the drawing, you will see it clearly indicates the sending unit,
which screws in to the accessory case. Notice they call it "Gauge,
*Engine Unit*, Oil Temp". The actual gauge, that you see in the cockpit,
is listed in Figure 16 & 17, "Instrument Panel Installation", under items
# 28 & 35, respectively: "Instrument - Oil Temperature", again, depending
on serial no.
Happy Flying!
Scott Skylane
Cherokee 140 Oil Temp Creeping Up Mike Spera Owning 9 June 12th 09 09:02 PM
Cherokee fuel sending units Mike Spera Owning 6 June 26th 06 11:07 PM
Fuel Sending Unit? Bill Adams Home Built 0 April 12th 05 02:46 PM
Cherokee fuel tank sender unit "float" -- anybody know where to get these??? Chuck Owning 5 January 27th 05 03:18 PM
Oil Temperature sending unit Corky Scott Home Built 2 October 19th 04 12:58 AM
