Cherokee 140 Oil Temp Sending Unit
Old September 5th 09, 10:00 PM posted to rec.aviation.owning
Mike Spera
Default Cherokee 140 Oil Temp Sending Unit
I am in a quest to troubleshoot an oil temp that has crept up a bit in the
last 100 hours or so. Checked all the baffling and"usual stuff". I was going
to check the accuracy of the gauge via testing.
2 things that I cannot find: the part number of the oil temp sending unit
and a supplier. This part does not appear either in the engine parts list or
the airplane parts list. Engine is a 150hp E-3D.
Any info would be appreciated.
Old September 6th 09, 01:58 AM posted to rec.aviation.owning
Spiking oil temp can sometimes be blamed on poor engine and/or
alternator grounding. That little sender is a thermistor whose
resistance drops as it gets warm, allowing the electrical system to
draw more current out of the engine case, through the gauge and into
the bus.
Now, the alternator is generating electricity. It charges the battery
and powers the bus by "pulling" electrons from the bus and dumping
them into the crankcase to which it is bolted and into the firewall,
to which it should be grounded by a separate cable. If the cable
connections are bad, or if the crankcase-to-engine mount strap
connections are bad, or if the engine mount's interface with the
firewall is bad, those electrons look for other ways to get to the
airframe. They'll travel along control cables, wire shielding, and
yes, through the oil temp sender and through the gauge, having a
boosting effect and making the gauge read higher. You might get
alternator noise in your headset, too.
Cessna had a similar problem and now they recommend a separate, small
ground wire from the case near the sender to the gauge frame itself.
That keeps the potential as close to ground as possible and improves
accuracy. But if engine grounding is poor, hard starting will show up
and some of those little ground wires and engine control cables will
get hot.
I'd start by cleaning all the ground connections. Then see if the temp
is still too high.
Sometimes oil coolers get sludged up and internally coated with
varnish and crud, insulating the hot oil from the cooling airflow.
Dan
Old September 6th 09, 07:47 PM posted to rec.aviation.owning
the bus.
get hot.
is still too high.
Dan
Should have pointed out one more possibility: The Vernatherm, which
controls the oil cooler bypass. As the oil warms up the vernatherm
pushes a valve into a port so that the oil has to go through the
cooler instead of bypassing it. If the Vernatherm is shot, the oil
will get hot.
If your engine has an oil screen, the vernatherm is the big nut on the
back of the screen housing right next to the temp pickup. If it has a
spin-on filter, it's in the bottom of the filter adapter, opposite the
temp sender which is on top.
Dan
Old September 8th 09, 03:24 AM posted to rec.aviation.owning
Mike Spera
Dan,
When I said I checked the "usual stuff", I meant that I already did all the
things you suggested. Oil cooler and Vernatherm replaced with new units, all
connections checked, alternator running properly, gauge and sending unit
properly grounded, baffles sealing, etc.
I am looking for the part number of the sending unit and a source. If it is
cheap enough I may get one and swap it. Getting an immersion heater in a
vessel with the sending unit and a thermometer is a lot of stuff to juggle,
especiall once the heater starts heating up the water.. Done it before. For
a 10 buck sender, I would just replace it. However, if the thing is $50 then
I'll bite the bullet and do the test.
Thanks for the clues,
going
unit
list or
the bus.
get hot.
is still too high.
Dan
will get hot.
Dan
Old September 8th 09, 05:44 PM posted to rec.aviation.owning
Ross
Mike Spera wrote:
Dan,
going
unit
list or
the bus.
get hot.
is still too high.
Dan
will get hot.
Dan
It's not that hard to calibrate the system. I put the sending unit and a
calibrated temperature probe on a DMM in a cup of oil and heated it to
180F and marked the gauge on the panel so I would know exactly where
that magic number occurred. It did take three folks, two to work the
heated oil and one in the plane to mark the gauge with a small piece of
tape.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old September 6th 09, 09:18 PM posted to rec.aviation.owning
Scott Braddock
Mike Spera wrote:
/snip/
Mike,
My Feb. 1995 Cherokee parts catalog shows the sending unit on Figure 68,
"Electrical System Installation", item #63: "Gauge-Engine Unit, Oil
Temperature" Depending on your Serial # ( 20550, or 20550 ), it shows
Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW).
Bear in mind all of those #'s have probably been superceded by now, but
perhaps a Piper dealer or Lycoming distributor can take you from there.
Happy Flying!
Scott Skylane
Old September 8th 09, 03:17 AM posted to rec.aviation.owning
Mike Spera
Scott,
That's the gauge you are looking at, not the sending unit. I don't need the
gauge.
Mike,
Piper part # 462-046, or 550-487 (mfg's part #'s 1514976, or 362-EW). Bear
in mind all of those #'s have probably been superceded by now, but perhaps
Happy Flying!
Scott Skylane
Old September 8th 09, 06:29 AM posted to rec.aviation.owning
Scott Braddock
Mike Spera wrote:
Scott,
gauge.
Mike,
Happy Flying!
Scott Skylane
Mike,
I believe the part #'s I gave you are the correct ones. If you have
access to the drawing, you will see it clearly indicates the sending
unit, which screws in to the accessory case. Notice they call it
"Gauge, *Engine Unit*, Oil Temp". The actual gauge, that you see in the
cockpit, is listed in Figure 16 & 17, "Instrument Panel Installation",
under items # 28 & 35, respectively: "Instrument - Oil Temperature",
again, depending on serial no.
Happy Flying!
Scott Skylane
Old September 10th 09, 04:21 AM posted to rec.aviation.owning
Mike Isaksen
"Scott Braddock" wrote in message
Mike,
I believe the part #'s I gave you are the correct ones. Happy Flying!
Scott Skylane
This Piper Forum post agrees with those numbers:
http://forums.piperowner.org/read/4/5724/5725/quote=1
Old September 11th 09, 01:08 AM posted to rec.aviation.owning
Mike Spera
O.K., I'll chase those numbers down.
mmunications...
Mike Spera wrote:
Scott,
the gauge.
Mike,
Happy Flying!
Scott Skylane
Mike,
access to the drawing, you will see it clearly indicates the sending unit,
which screws in to the accessory case. Notice they call it "Gauge,
*Engine Unit*, Oil Temp". The actual gauge, that you see in the cockpit,
is listed in Figure 16 & 17, "Instrument Panel Installation", under items
# 28 & 35, respectively: "Instrument - Oil Temperature", again, depending
on serial no.
Happy Flying!
Scott Skylane
Cherokee 140 Oil Temp Creeping Up Mike Spera Owning 9 June 12th 09 09:02 PM
Cherokee fuel sending units Mike Spera Owning 6 June 26th 06 11:07 PM
Fuel Sending Unit? Bill Adams Home Built 0 April 12th 05 02:46 PM
Cherokee fuel tank sender unit "float" -- anybody know where to get these??? Chuck Owning 5 January 27th 05 03:18 PM
Oil Temperature sending unit Corky Scott Home Built 2 October 19th 04 12:58 AM
