FAA releases final report on changes to amateur-built aircraft rules
Old September 24th 09, 11:02 PM posted to rec.aviation.homebuilt
Anyolmouse
Default FAA releases final report on changes to amateur-built aircraft rules
"Jim Logajan" wrote in message
The PDF document of the committee's final report is he
http://www.faa.gov/aircraft/gen_av/u...008_report.pdf
Some years ago I read that the reason for the requirement that the
majority of work building an experimental/homebuilt aircraft was to
insure the builder "learned" something. That it was to be an educational
experience. Can't find any mention of it today. It used to be they same
for amateur radio as well. We actually built radios, antennas from plans
and schematics and at a later time from Heathkits, etc. Does anyone else
remember the educational requirement and if so when it was no longer
mentioned?
A man is known by the company he keeps- Unknown
Anyolmouse
Old September 25th 09, 03:48 AM posted to rec.aviation.homebuilt
Ron Wanttaja[_2_]
Default FAA releases final report on changes to amateur-built aircraftrules
mentioned?
I don't believe there was ever solely a education requirement.
The 51% rule came about because some folks were taking production
airplanes, modifying them, and registering them a Experimental
Amateur-Built. The Nelson N-4 was an example:
http://www.nvva.nl/renekrul/catalogs...elson.n14n.jpg
Basically, it was a cut-down J-3, converted to a shoulder-wing single
seater.
Probably wasn't that big of a deal when it was just an occasional owner,
but I suspect some folks started doing this commercially as a way to
bypass the STC process. Hence the requirement that the majority of the
construction had to be done for "Education or Recreation."
Old September 25th 09, 02:51 PM posted to rec.aviation.homebuilt
Anyolmouse
"Ron Wanttaja" wrote in message
educational
same
plans
else
mentioned?
seater.
owner,
Thanks for replying-
We have met the enemy and he is us-- Pogo
Anyolmouse
Old September 25th 09, 04:15 PM posted to rec.aviation.homebuilt
BobR
educational
same
plans
else
mentioned?
Amateur-Built. *The Nelson N-4 was an example:
seater.
owner,
bypass the STC process. *Hence the requirement that the majority of
Anyolmouse-
AND...it is only getting worse every single day!
At the rate things are going, the government will not only spend every
time we earn before we make it but will control both our sleep and our
waking time.
Resistance if futile....you will be assimilated!
Old September 29th 09, 01:04 AM posted to rec.aviation.homebuilt
Peter Dohm
"Anyolmouse" wrote in message
mentioned?
Anyolmouse
I recall the same, in both radio and aircraft, but have no idea when or
where the language might have been dropper--or even whether it is not
entirely omitted.
Peter
Old September 29th 09, 02:08 AM posted to rec.aviation.homebuilt
Charles Vincent
mentioned?
Anyolmouse
entirely omitted.
Peter
Its from 14 CFR 21.191 and it lists the categories under which one may
apply for an experimental certification:
(g) Operating amateur-built aircraft. Operating an aircraft the major
portion of which has been fabricated and assembled by persons who
undertook the construction project solely for their own education or
recreation.
Charles
FAA publishes proposed changes to amateur-built rules. Jim Logajan Home Built 19 July 28th 08 08:30 AM
Flight Restrictions on non-amateur built experimental aircraft?? Don W Home Built 9 April 20th 07 11:23 PM
Air Force Releases USAFA Report Otis Willie Military Aviation 0 September 2nd 04 09:45 PM
clever amateur built placard mods Joa Home Built 5 January 8th 04 08:10 AM
restrictions on Amateur built aircraft Rob Home Built 3 October 20th 03 08:37 PM
