FAA publishes proposed changes to amateur-built rules.
Old July 16th 08, 12:51 AM posted to rec.aviation.homebuilt
Jim Logajan
Default FAA publishes proposed changes to amateur-built rules.
The EAA has an article on the proposed changes:
http://www.eaa.org/news/2008/2008-07-15_policy.asp
Old July 16th 08, 02:22 PM posted to rec.aviation.homebuilt
Ernest Christley
Welcome to "Joe's House of Incomplete Aircraft". We're all having a good time.
I do like the part about requiring the inspector to question the builder about the build process. Even if I do pay
someone to help me, I should at least know what is going on. I wished the EAA did more to question builders before
handing out awards. Beyond insuring that they're giving awards to amateurs, it would go a long way to promoting their
goal of education.
Old July 16th 08, 03:35 PM posted to rec.aviation.homebuilt
BobR
We should all be very happy that the government worked so hard and
spent so much of our tax dollars to finally make everything perfectly
CLEAR.
Old July 18th 08, 04:16 PM posted to rec.aviation.homebuilt
CLEAR.
Embarrassing, eh?
Despite claims to the contrary, putting on an air-show is no guarantee
of competence in other areas. In the same vein, the fact a hack
politician holds a particular office is no guarantee they are
qualified to do so. Indeed, the biffy handlers and the political
hacks have wasted more than TEN YEARS trying to resolve what is at
best, a fairly simple problem.
-R.S.Hoover
Old July 16th 08, 07:00 PM posted to rec.aviation.homebuilt
Jim Logajan
"The FAA is proposing that an amateur builder fabricate a minimum of 20
percent of an aircraft and assemble a minimum of 20 percent of the
aircraft."
Mixing objective measures (e.g. percentages or fractions) without objective
definitions is absurd. Are those 20% numbers to be determined by weight, by
volume, by part count, by cost, by width, by height, by length, by labor
hours worked or avoided, or what?
They never knew what they wanted amateurs to prove and they still don't.
Old July 16th 08, 08:47 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Jim Logajan" wrote in message
I think that their real objective is shut down aircraft factories
masquerading as homebuilders. I don't think that is an unreasonable goal, but
it may be up to us to figure out how they can do that without stepping on the
toes of honest homebuilders and honest suppliers, and then convincing them.
Vaughn
Old July 17th 08, 10:25 AM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Wed, 16 Jul 2008 19:47:20 GMT, "Vaughn Simon"
Vaughn
why would they or you want to????
surely the goal for aircraft building is structurally sound aircraft.
the way managed manufacturing is going you will eventuially have the
choice of something built by clued up enthusiasts in your own country
or something tacked together and given a slick paint job in some asian
sweat shop.
why deny your own people the opportunity to build an industry?
certification is just a 1930's quality assurance program out of
england. it is not the only way that safe sound aircraft can be built.
if the 'aircraft factories masquerading as homebuilders' are producing
sound aircraft why do you seek to stop them? jealousy? envy?
Stealth Pilot
Old July 17th 08, 01:25 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Stealth Pilot" wrote in message
The quality (or lack of) of the product produced by these unofficial
"aircraft factories" is not the issue.
Those folks are abusing regulations that are designed to allow amateur design
and construction of experimental aircraft. The FAA wants to stop that. One way
or another, the FAA WILL stop that. The easiest way for the FAA to proceed is
to produce new regulations that will make things just as hard on the true
amateurs as it will on the rogue "aircraft factories".
Don't get me wrong. I feel that the availability of CNC-made predrilled
kits and parts to the amateur is a wonderful thing and probably produces a safer
aircraft compared to a true one-off build. I would hate to see the practice
regulated out of existence because a few folks are abusing the system.
I would simply prefer for those "aircraft factories" to make their own case
to the FAA if they feel that they should be allowed to operate and (more
importantly) for the true amateur who has been operating within the spirit of
the regulations to be left alone.
If that dialog leads to an improvement of the certification process that
allows a small company to afford to actually design and build a safe aircraft at
a profit, so much the better!
Vaughn
Old July 17th 08, 02:58 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
On Thu, 17 Jul 2008 12:25:55 GMT, "Vaughn Simon"
Vaughn
so you have a mixture of emotions there.
the puritanical desire to stop anyone actually getting ahead.
an unrealised desire to have the regulations freed up.
my point is why chime in and ask for them to be banned? why not ask
for the regs to be relaxed so that it can occur.
base it on a safety case. if it isnt causing a problem start
supporting aviation enterprises.
while you are at it why not support the much more sensible private
owner maintenance system that the canadians have introduced.
Stealth Pilot
Old July 28th 08, 08:30 AM posted to rec.aviation.homebuilt
On Wed, 16 Jul 2008 13:00:47 -0500, Jim Logajan
aircraft."
At one time they said 51% of the parts and they clarified that to say
building one wing rib is as good as building all of them.
constructiong one elevator is as good as both.
Roger (K8RI) ARRL Life Member
N833R (World's oldest Debonair)
www.rogerhalstead.com
2008 Proposed US Competition Rules Changes [email protected] Soaring 18 December 31st 07 07:21 PM
Flight Restrictions on non-amateur built experimental aircraft?? Don W Home Built 9 April 20th 07 11:23 PM
US Contest Rules Proposed Changes for 2006 Ken Sorenson Soaring 18 January 12th 06 04:30 PM
clever amateur built placard mods Joa Home Built 5 January 8th 04 08:10 AM
restrictions on Amateur built aircraft Rob Home Built 3 October 20th 03 08:37 PM
