On Sep 22, 8:22*pm, Dave J wrote:
I'm having an embarrassing problem. My brain seems to shut down lately as soon as the key is out of the ignition. It's little things, like leaving my kneeboard (with gas card) or charts in the airplane, forgetting to completely tie down the aircraft, forgetting to properly fill out club paperwork, etc. Well, some things are an inconvenience and others are safety related, and the latter is what needs the most attention. The checklist is obvious, but, a broader measure would be to remember that you're having the problem and to develop habits to mitigate it. I have a similar problem which is that I forget something once in awhile, and so I'm usually paranoid that I'm forgetting something so I waste several minutes checking and rechecking the cockpit. I tell myself it's better that than leaving the master switch on or forgetting a tie-down. Here's an idea: Organize your postflight and make it a routine. Your shutdown checklist will be stuff like the master switch, avionics master, radios, control lock, keys... Get out and tie down the plane for safety. (Stretch legs.) Then do your paperwork; Hobbes, tach, whatever. Check under and behind the seats as you exit and on the dashboard, then do your postflight walkaround. You know you've tied down the airplane and put the pitot sock on, but, you're also looking for obvious stuff like missing fuel caps, low tires, oil leaks. Finally, after you've done your walkaround, check the cockpit one last time and make sure everything is secured and that you have all of your stuff. Always do it in that order: Panel checklist, tiedown, paperwork, cockpit check, walkaround, cockpit. Make it a ritual. If you're like me, you'll get to the gate and turn around again just to make sure. : -c CFI, Troutdale, Oregon |
Dave J schreef:
I'm having an embarrassing problem. My brain seems to shut down lately as soon as the key is out of the ignition. It's little things, like leaving my kneeboard (with gas card) or charts in the airplane, forgetting to completely tie down the aircraft, forgetting to properly fill out club paperwork, etc. It's all getting embarrassing, and I'm starting to get a little nervous. So far, I have not done anything stupid in the air -- that I know of -- but, I do wonder if I will. A possible factor is that I'm flying much less than I used to, always alone, and usually with very tight time constraints. Any advice? Does this happen to anybody else? How do you stay focused until your outside the gate? Count yourself lucky. I am still in the stage where my instructor reproaches me my brain quits the moment the wheels touch the grass. Worst of all, he is damned right, too. |
On Sep 23, 3:38*am, jan olieslagers
wrote: and usually with very tight time constraints. Could this be the root of your problem? Rushing promotes oversight. Allow more time for you to take your time to do the housekeeping duties post flight. |
Could this be the root of your problem? *Rushing promotes oversight. Allow more time for you to take your time to do the housekeeping duties post flight. OOOPS, the above quotation in my original response should have been attributed to to Dave J, not Jan. Sorry Jan! |
On Sep 23, 8:38*am, BeechSundowner wrote:
and usually with very tight time constraints. Could this be the root of your problem? *Rushing promotes oversight. Allow more time for you to take your time to do the housekeeping duties post flight. Hey, thanks for writing. Yeah, I think it could be. We've got an 18 month old baby and what happens is that I am usually allotted a 3 hour block of time to venture out on my own recognizance. It takes me about 50 minutes to/from the airport, plus preflight, and I'm lucky to get in the air for an hour. Postflight is getting short shrift, I suppose because I'm rushing to get home. -- dave j |
Primus 1000 FMS brain damage | Ron Garret | Instrument Flight Rules | 19 | February 5th 08 08:02 PM |
Help me clear up my brain fart | Ekim | Piloting | 63 | November 13th 03 07:23 PM |
Right Engine Still Feathers and shuts down. | AIR ADVENTURE82 | Owning | 2 | September 14th 03 04:03 PM |
Prop Feathers and Engine Shuts down after landing???????? | AIR ADVENTURE82 | Owning | 16 | August 29th 03 09:36 PM |
Prop Feathers and Engine Shuts down after landing???????? | AIR ADVENTURE82 | Piloting | 3 | August 21st 03 05:42 AM |
