Primus 1000 FMS brain damage
Old February 2nd 08, 05:34 AM posted to rec.aviation.ifr
Ron Garret
Default Primus 1000 FMS brain damage
Today I departed out of RIL as a passenger on a Citation V Ultra being
flown under Part 135. Despite the winds and terrain favoring a
departure from runway 26, we departed runway 8. One of the consequences
of this was that we needed a 5500 foot ceiling, which we darn near
didn't get and we almost got stuck there.
When I asked why they departed runway 8 instead of 26 (whose departure
minimums require only a 3500 foot ceiling) I was told that the Honeywell
Primus 1000 FMS could not be programmed to properly fly the Squat 1
departure (http://204.108.4.16/d-tpp/0801/06741SQUAT.PDF). In
particular, the procedure requires that the plane fly to YIRDU
intersection before turning towards SQUAT, but the Primus 1000 always
interpolates its turns (i.e. it would start turning towards SQUAT
slightly before reaching YIRDU), and this cannot be overridden.
This all sounded a little farfetched to me. Leaving aside the fact that
it's only a 15 degree turn, I don't understand how any IFR-certified GPS
(let alone one that they would install on a freakin' jet) could not
properly fly a published GPS departure procedure.
Can anyone here shed any additional light on this situation? Is this
really true, or did I get told a tale?
rg
Old February 2nd 08, 07:27 AM posted to rec.aviation.ifr
Scott Skylane
Ron Garret wrote:
/snip/
rg
Ron,
I'm not sure what they were trying to tell you, but there are no "fly
over" waypoints on this procedure, they are all "fly past", i.e. it's
perfectly acceptable (and expected) to anticipate any turns. Yes, any
competent FMS can handle this easily (though, I'm not familiar with the
Primus 1000 specifically).
Which direction was your destination? If it was eastbound, this
particular procedure takes you quite a bit out of your way. Perhaps the
crew wanted to save gas/flight time by departing 8. That doesn't make
much sense, though, if it meant a real possibility of getting stuck
there, instead of actually departing. Not only that, but both of the
Rwy 8 DP's allow a 400-1 takeoff minimum, assuming you can maintain 320'
per NM on the climb out, something I would think a Citation could handle.
Happy Flying!
Scott Skylane
Old February 2nd 08, 07:36 AM posted to rec.aviation.ifr
Ron Garret
Scott Skylane wrote:
Ron Garret wrote:
/snip/
rg
Ron,
Due west. Burbank.
rg
Old February 2nd 08, 07:51 AM posted to rec.aviation.ifr
Scott Skylane
Due west. Burbank.
rg
Well, then I am at a complete loss. The appropriate DP in that case,
given a Rwy 8 departure, would be the EDUKY ONE. That DP is the only
one that *does* contain a "fly over" waypoint, the very thing your pilot
said his FMS *couldn't* do!
Happy Flying!
Scott Skylane
Old February 3rd 08, 04:44 PM posted to rec.aviation.ifr
Sam Spade
rg
You got a tale, on a number of levels, plus I have to wonder about the
competence of that crew.
First, an IFR FME (or for that matter a panel mount) must be able to
handle both flyover (FO) and fly-by (FB) waypoints. There are two RNAV
DPs for Runway 8 and one for 26.
There is also a VOR/DME based ODP for Runway 8, but not for 26.
So, the basic takeoff minimums apply to the ODP for Runway 8 and to the
SQUAT RNAV DP for Runway 26. (26: 3400-3 or standard with a min CG of
360/NM to 10,000. 8: 5500-3 or standard with a min CG of 370/NM to 13,000)
The basic Runway 8 takeoff minimums do not apply to the two RNAV DPs for
that runway. They each have their own takeoff minimums and CGs. The
two RNAV DPs have the mandatory 400-1 requirement even with a CG,
whereas the "steam gauge" ODP is standard with its climb gradient.
Seems that they were not willing to do any of the three RNAV DPs, thus
opted for the steam gauge ODP.
Not a good choice at this airport. Runway 26 is downhill and with the
use of the SQUAT ONE there is virtually no terrain threat. In fact,
engine failure procedures off Runway 26 should be a piece of cake
compared to Runway 8.
SQUAT is a FB waypoint. The only FO waypoint for any of the three RNAV
DPs is USUNE.
Squat is speed limited so the turn doesn't occur two early for the AWRAW
or EDUKY transitions. There is no speed limit for the JNC transition
because there is a very small course change.
And, you say they needed a 5500-1 ceiling for Runway 8. True, but only
if they couldn't do 370 per mile to 13,000. If that airplane can't do
that, it shouldn't be doing IMC charters at an airport like Rifle.
Departing on the SQUAT on Runway 26 requires a slightly less climb
gradient and only to 10,000 feet, which is far less demanding.
I can only speculate:
Maybe they don't really know how to do RNAV DPs? Maybe their database
was out of date? Maybe they misunderstood the takeoff performance
requirements for each runway?
Bottom line: Anyone with their act together in an RNAV aircraft would
have departed Runway 26.
Old February 4th 08, 12:01 AM posted to rec.aviation.ifr
Bonehenge (B A R R Y)
On Sun, 03 Feb 2008 08:44:52 -0800, Sam Spade
I always learn from your posts... G
Old February 4th 08, 07:27 AM posted to rec.aviation.ifr
Ron Garret
I dunno. I grilled them pretty hard and they seemed to know what they
were doing. They didn't get defensive about it or anything.
The crew was quite specific that this one could only do FB, except with
an upgrade that the company was unwilling to pay for. (I even asked
them why don't they just hand-fly the DP, and the answer was that they
could, but that the CDI would still direct them according to the FB
routing, so that wouldn't actually help.)
[xnip]
Yes, exactly. That is exactly what they said.
That's what I thought, and that's what they thought. But they said that
according to the regs they didn't have a choice.
It can certainly do that with both engines, but with an engine out it's
dicey (this, again, according to the crew).
Inconceivable.
Maybe their database was out of date?
Possible, but that's not what they said.
Ditto.
Yeah, that's what I thought.
rg
Old February 4th 08, 03:14 PM posted to rec.aviation.ifr
Sam Spade
All the details aside, there is no RNAV system certified that won't
handle both flyby and flyover waypoints.
Such a limited system could not fly any GPS approaches, because they all
have a flyover waypoint to begin the missed approach.
So, you were being fed some kind of BS.
Also, as to Part 135 single-engine contingencies, they could have a
different procedure than the ODP for Runway 8, if their company chose to.
I will check out the Primus 1000 with some pilots that fly that system. ;-)
Old February 4th 08, 03:16 PM posted to rec.aviation.ifr
Sam Spade
Did you note that the SQUAT 26 DP doesn't have any flyover waypoints?
Old February 4th 08, 06:17 PM posted to rec.aviation.ifr
Ron Garret
I'm not actually sure how to tell the difference. I wansn't even aware
that there was a distinction before this whole incident happened. In my
Cirrus I just select the procedure on the Garmin and hit the NAV button.
rg
Storm Damage john smith Piloting 0 June 23rd 06 10:05 PM
brain scan study on errors about to be made Jose Piloting 0 October 26th 04 12:40 AM
X-15 damage Paul F Austin Military Aviation 7 May 23rd 04 09:11 PM
No Damage History? CFLav8r Owning 26 January 13th 04 05:53 PM
Help me clear up my brain fart Ekim Piloting 63 November 13th 03 07:23 PM
