Master contactor question
Old October 28th 09, 08:30 PM posted to rec.aviation.homebuilt
rich[_2_]
Default Master contactor question
My homebuilt's master contactor is going bad. Sometimes when I turn it
on it doesn't make connection. It's got 1700 hours on it, so I'd just
as soon replace it. But the way the builder wired it, he's has
positive power from the battery going through the master switch to the
small terminal on the contactor. (cole-Hersey type) But the master
contactors, such as Spruce sells, are set up to actuate with ground
power going to the small terminal. They also have plastic around their
mounting feet so their case doesn't make ground. A starter contactor
would work perfectly with the way the plane is wired. I just wonder,
are starter contactors made to withstand continous use, like a master
contactor does? And how can one tell the difference in the two, they
look identical? And if not, can the master/continuous duty type be
made to work with postitive power to the small terminal?
Master cylinders [email protected] Home Built 25 July 29th 08 02:08 AM
Battery Contactor Diode? Skrud Home Built 25 September 11th 06 06:17 PM
PA28-180 Power Contactor Relay source? Mike Noel Owning 5 August 10th 05 04:40 AM
Master Switch Lakeview Bill Piloting 23 July 20th 05 01:46 AM
RC Plane Master Steve Simulators 0 December 20th 03 02:40 PM
