#11
On Sun, 01 Nov 2009 09:51:45 -0800, kirk.stant wrote:
This looks like a natural for a single blade prop, folding flush into a contoured recess in the bottom of the nose. That would be nice to see from a propeller efficiency point of view too, because the prop could be bigger while absorbing the same power. The bigger the prop the more efficient it is. Propeller ground clearance would be irrelevant for a sustainer system. I remember seeing an Antares 20E and an ASW-22ble launch within 10 minutes of each other, so the ground and air conditions were very similar. The ASW-22 has 49hp (36 kW) and (I think) a 0.9m diameter prop while the Antares swings a 2m prop with a 47 kW motor. The Antares was off the ground in about 1/3 the run the '22 needed and climbed out at least twice as fast. I don't know how the takeoff weights would compare, but if they're not too different the additional 30% power output in the Antares wouldn't account for the takeoff and climb out difference I saw, but the different props could easily do it. A two blade prop is rather more efficient than a 5 or 6 blade unit and the almost 5:1 difference in swept area would make a big difference to drive efficiency, especially at low speeds. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Sun, 01 Nov 2009 11:51:45 -0800, LimaZulu wrote:
-LAK17a has front tow hook placed bellow instrument panel -95% is efficiency of motor+controler. Motor have good cooling, and it not looks that heating will be a problem. It is just warm and controler is rated for much higher power and is not even warm. I noticed your web site comments about eliminating the drag from the pylon and engine, but didn't mention the effect that the pylon would have on propeller efficiency. Since your prop is a similar size to a conventional sustainer prop, have you calculated effect on prop efficiency of moving it from the pylon to the nose? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
kirk.stant wrote:
This looks like a natural for a single blade prop, folding flush into a contoured recess in the bottom of the nose. I like it! Kirk Another good idea from the model world :-). Needs a hefty counterweight at those dimensions of spinner (small) and prop (large) though. /AndersP |
On Nov 1, 7:07*am, Darryl Ramm wrote:
On Nov 1, 4:29*am, Andy wrote: On Nov 1, 1:49*am, LimaZulu wrote: First flight of Front Electric Sustainer - FES http://www.front-electric-sustainer.com http://www.youtube.com/watch?v=TNOKq6PKIvM Regards, Luka Znidarsic If I read the specs right you can operate at full power for 14.4 minutes over which time you can climb a bit over 4,300 feet. *How's that compare to other sustainers? *This seems simpler than most other configurations which is nice. 9B It would be interestingly they claim level flight for 120km which is greater distance than a 4,300' climb will normally allow you to glide. Just plucking numbers out of thin air of 50 knots for optimal climb and cruise speeds (I expect climb would be slower) and an L/D of 50:1. You would travel 22 km in the climb and glide 65km for a total of 87km. It would require a L/D 74 to match the straight cruise. The exact optimal speeds and the profile of the climb as battery power diminishes likely affects all this. Looks like nice packaging. I am curious as well what happens to the forward air cockpit air vent, nose pitot tube, nose tow hook, and where cooling air for the engine comes from (presumably the nose hole). At 95% efficiency the 15kW motor will generate 750W. Darryl I mis-read the projected climb as 1.5 m/s instead of 1.6. This still leaves total climb capability a bit over 4,500 feet so the straight cruise must get more out of the motor than a sawtooth, though I am not clear why this would be true. 9B |
![]() "Andy" wrote in message ... This still leaves total climb capability a bit over 4,500 feet so the straight cruise must get more out of the motor than a sawtooth, though I am not clear why this would be true. One good reason is because the whole electrical system, especially the battery itself, is more efficient when operated at lower currents. At higher power outputs, a greater percentage of the battery's precious stored energy turns into waste heat, so less of the battery's stored energy is available to actually propel your aircraft.. Vaughn |
On Nov 1, 2:49*pm, "vaughn"
wrote: "Andy" wrote in message ... *This still leaves total climb capability a bit over 4,500 feet so the straight cruise must get more out of the motor than a sawtooth, though I am not clear why this would be true. One good reason is because the whole electrical system, especially the battery itself, is more efficient when operated at lower currents. *At higher power outputs, a greater percentage of the battery's precious stored energy turns into waste heat, so less of the battery's stored energy is available to actually propel your aircraft.. Vaughn True - though I was under the impression that a sawtooth profile is more efficient for the overall glider-motor system. I'm at a loss as to why the cruise mode for this system would produce nearly twice the range of the sawtooth - at least according to math on the various specs quoted.. The electric motor would have to REALLY hate being run full out. 9B |
Andy wrote:
On Nov 1, 2:49 pm, "vaughn" wrote: "Andy" wrote in message ... This still leaves total climb capability a bit over 4,500 feet so the straight cruise must get more out of the motor than a sawtooth, though I am not clear why this would be true. One good reason is because the whole electrical system, especially the battery itself, is more efficient when operated at lower currents. At higher power outputs, a greater percentage of the battery's precious stored energy turns into waste heat, so less of the battery's stored energy is available to actually propel your aircraft.. Vaughn True - though I was under the impression that a sawtooth profile is more efficient for the overall glider-motor system. I'm at a loss as to why the cruise mode for this system would produce nearly twice the range of the sawtooth - at least according to math on the various specs quoted.. The electric motor would have to REALLY hate being run full out. 9B If I go bike-riding, it is a lot easier to go around the hills than to go over them. If I am driving a car, my gas mileage is better when I go around hills rather than over them. What is it about sustainer gliders that causes them to be different? Of course, the sustainers that we have now have engines that run too fast for sustained cruising, have a pylon creating a lot of drag, etc. But eliminate those problems, and isn't it more efficient to cruise at a constant altitude? |
On Nov 1, 6:56*pm, Greg Arnold wrote:
Andy wrote: On Nov 1, 2:49 pm, "vaughn" wrote: "Andy" wrote in message .... *This still leaves total climb capability a bit over 4,500 feet so the straight cruise must get more out of the motor than a sawtooth, though I am not clear why this would be true. One good reason is because the whole electrical system, especially the battery itself, is more efficient when operated at lower currents. *At higher power outputs, a greater percentage of the battery's precious stored energy turns into waste heat, so less of the battery's stored energy is available to actually propel your aircraft.. Vaughn True - though I was under the impression that a sawtooth profile is more efficient for the overall glider-motor system. I'm at a loss as to why the cruise mode for this system would produce nearly twice the range of the sawtooth - at least according to math on the various specs quoted.. The electric motor would have to REALLY hate being run full out. 9B If I go bike-riding, it is a lot easier to go around the hills than to go over them. *If I am driving a car, my gas mileage is better when I go around hills rather than over them. What is it about sustainer gliders that causes them to be different? *Of course, the sustainers that we have now have engines that run too fast for sustained cruising, have a pylon creating a lot of drag, etc. *But eliminate those problems, and isn't it more efficient to cruise at a constant altitude? There will always be drag/inefficiency from the prop itself. But how significant that is needs a back of the bigger envelope than I have handy. In addition to what you already mentioned, most sustainers and some self launchers run two stroke engines. They have a noticeable powerband, so you run them in that band and climb (if you are lucky..). They often just wont run reliably at lower RPM, will oil up plugs etc. The electrics are a whole different kettle of fish. The sustainer here has the advantages of electrics (being able to run at reduced power) and prop optimization for sustainer use only (the prop does not need to handle self launch). The electrics have the benefit of not having to worry about mixture settings at altitude, somethign many self launchers or sustainers cannot deal with except by adjustment on the ground. I hope the people making this produce some performance data for high density altitudes (~10,000'). Around mountains 'out-west' most sustainers are next to useless. Darryl |
On Sun, 01 Nov 2009 19:14:52 -0800, Darryl Ramm wrote:
The electrics have the benefit of not having to worry about mixture settings at altitude, somethign many self launchers or sustainers cannot deal with except by adjustment on the ground. I hope the people making this produce some performance data for high density altitudes (~10,000'). Around mountains 'out-west' most sustainers are next to useless. Judging from the performance of free flight models at Denver vs the same models at Sacramento, the FES should be better than an IC sustainer. Its noticable that power models lose performance big-time at Denver while rubber powered models are much less affected. Now doubt this is due to the way an IC engine loses power with altitude while electric or rubber motors are unaffected. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Nov 2, 2:36*pm, Martin Gregorie
wrote: On Sun, 01 Nov 2009 19:14:52 -0800, Darryl Ramm wrote: The electrics have the benefit of not having to worry about mixture settings at altitude, somethign many self launchers or sustainers cannot deal with except by adjustment on the ground. I hope the people making this produce some performance data for high density altitudes (~10,000'). Around mountains 'out-west' most sustainers are next to useless. Judging from the performance of free flight models at Denver vs the same models at Sacramento, the FES should be better than an IC sustainer. Its noticable that power models lose performance big-time at Denver while rubber powered models are much less affected. Now doubt this is due to the way an IC engine loses power with altitude while electric or rubber motors are unaffected. -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Really good point - I believe it's true that most of the power loss with altitude is from loss of power produced by the engine, not prop efficiency. Electric motors don't have this power loss because they don't depend on combustion. 9B |
The HPH 304S Turbine sustainer glider | kd6veb | Soaring | 2 | September 23rd 09 05:10 AM |
would an electric sustainer be practical | Brad[_2_] | Soaring | 7 | July 24th 09 06:29 PM |
Sustainer engine ignition noise (Solo2350) | Per | Soaring | 8 | January 4th 07 05:56 AM |
DG goes the sustainer option. | Paul | Soaring | 25 | June 4th 04 12:16 AM |
Chasing the front | Paul Tomblin | Piloting | 7 | April 21st 04 01:09 PM |
