Wing Ballast Distribution
Old December 11th 09, 12:37 AM posted to rec.aviation.soaring
tstock
Default Wing Ballast Distribution
Also helps stabilize the glider in a spin.
Could you explain this statement for us newbies... this is opposite of
what I would have expected so I would like to understand why it is so.
Thanks!
-tom
Old December 11th 09, 12:52 AM posted to rec.aviation.soaring
John Smith
Just don't worry. All moderately current regulations ask that a glider
is recoverable from a fully developed spin with any possible ballast
distribution.
Old December 11th 09, 12:53 AM posted to rec.aviation.soaring
Craig[_2_]
Thanks!
-tom
Dave's right, but I think he was just poking fun. The higher
rotational inertia tends to flatten the spin and make it harder to
recover from. Most of the long wing ships aren't certified for
spinning even without ballast.
Craig
Old December 11th 09, 12:56 AM posted to rec.aviation.soaring
Greg Arnold
Thanks!
-tom
Craig
Presumably, the higher rotational inertia also makes it harder to get
into a spin.
Old December 11th 09, 02:17 AM posted to rec.aviation.soaring
Brian Whatcott
jcarlyle wrote:
Why would aircraft designers want to keep weight towards the wing
tips? Does it have something to do with going from a 15m to an 18m
span? Wouldn’t the increased moment of inertia and wing spar bending
negatively affect performance?
-John
Loading the wings mitigates wing bending. Wings want to fold up from
fuselage loads, so spreading a wing loading can reduce stress at the
wing/fuselage junction.
Brian W
Old December 11th 09, 02:24 AM posted to rec.aviation.soaring
Brian Whatcott
Andy wrote:
Ballast towards the wings tips increases the g-limit at any given
weight versus ballast towards the wing root. It may or may not affect
the flutter limits - but my initial hypothesis would be that it
reduces the natural frequency of the wing in bending which would
probably help on flutter. /snip/
9B
For the usual wing that has some sweep back, wing bending provides
reduced AofA which is favorable: swept forward wings do the opposite,
unless they are very stiff. Lateral weight distribution plays into this
effect too.
Brian W
Old December 11th 09, 02:25 AM posted to rec.aviation.soaring
Brian Whatcott
Dave Nadler wrote:
On Dec 10, 1:02 pm, SoaringXCellence wrote:
The weight toward the tips provides an interial resistance to roll.
That means the ride is a little smoother as the wing has greater
resistance to differential vertical gusting across the wingspan. It
is the same principle that tightrope walkers use by carrying a long
heavy pole.
Hmmm... I don't think so. Twin jets are noted for more severe spin
characteristics.
Brian W
Old December 11th 09, 02:27 AM posted to rec.aviation.soaring
Brian Whatcott
Spin loading and sharp edge gust loading are different wing cases.
Brian W
JJ Sinclair wrote:
I believe it was the Constellation that was bpopping rivets in
turbulence, the fix was 300# of lead in each wing tip.
JJ
heavy pole.
Old December 11th 09, 02:30 AM posted to rec.aviation.soaring
Brian Whatcott
JJ
LAK-12 has 20lbs in the leading edge of each tip.
Frank Whiteley
Front loading of aeroelastic surfaces has a comparable effect to forward
(dynamic) balancing of control surfaces like flaps, elevator, ailerons:
It pushes away the flutter envelope.
Brian W
Old December 11th 09, 02:44 AM posted to rec.aviation.soaring
Andreas Maurer
On Thu, 10 Dec 2009 10:02:55 -0800 (PST), SoaringXCellence
heavy pole.
I beg to differ - at least for certain gliders it's vice-versa.
In the AS 22-2 (the mother of all ASH-25s) it is strictly required to
fill the outer wing tanks first (and empty them last) - the limiting
factor is the bending momentum of the wing of course.
The interesting part:
Even with completely filled outer wing bags (about 120 lbs per wing)
the roll rate doesn't suffer at all.
But filling the inner wing tanks (about 100 lbs per wing) instead of
having a co-pilot on board reduces the roll rate significantly.
Don't ask me why.
visualisation of the lift distribution over a wing Stealth Pilot[_2_] Home Built 195 December 16th 09 03:17 AM
Wanted: Schempp Hirth Wing Ballast Cap Paul Cordell Soaring 7 August 17th 07 08:30 PM
Fin/wing water ballast ratio? DG-300 [email protected] Soaring 0 May 2nd 06 06:52 PM
747 weight distribution Robin General Aviation 25 June 22nd 05 03:53 AM
Distribution of armor on a B-52 B2431 Military Aviation 12 August 16th 04 09:07 PM
