official sunset/sunrise
Old April 20th 10, 05:32 AM posted to rec.aviation.soaring
Darryl Ramm
Default official sunset/sunrise
On Apr 19, 9:05*pm, brian whatcott wrote:
Darryl Ramm wrote:
* /snip/
You can see how this could vary when the horizon is the Rockies, versus
five miles West where it might be 5000 ft lower...
Brian W
Stop tying to make this hard, there is one proper definition to worry
about for gliding in the USA. That is the table generated by the US
Naval Observatory. The FARs *define sunset times as published in the
Air Alamanac which is produced by the US Naval Observatory, but for
practical purposes the official data is the USNO tables /snip/
Darryl
I have no problem with competitive sporting endeavors adopting a uniform
definition of anything they choose to. * * But supposing that the
Official Definition of Sunset from the USNO and the ACTUAL sunset time,
as described by the USNO, always coincide for a particular place and
time would be an over simplification.
At times, a LETHAL over-simplification.
Take this NTSB accident investigation from April 15th, 2002 for example.
http://www.ntsb.gov/recs/letters/2002/A02_08.pdf
Here an aircraft landing in the Rockies failed to note an intervening
summit. It was subject to a LOCAL sunset that was 25 minutes earlier
than the official sunset time as pointed out by the USNO in a footnote,
mentioned in this report.
Brian W
Again the OP was a question about official sunset times. The official
definition of Sunset by the USNO is what they use to generate the
table. There is no conflict between USNO definition and their own
tables, do you really think there would be? This is not an arbitrary
SSA sporting definition, the SSA is ensuring glider badge and record
flights comply with the strict sunset flight requirements described in
the FARs (unless you can show you are legal to fly to civil twilight).
USNO Definition: "Sunrise and sunset. For computational purposes,
sunrise or sunset is defined to occur when the geometric zenith
distance of center of the Sun is 90.8333 degrees. That is, the center
of the Sun is geometrically 50 arcminutes below a horizontal plane.
For an observer at sea level with a level, unobstructed horizon, under
average atmospheric conditions, the upper limb of the Sun will then
appear to be tangent to the horizon. The 50-arcminute geometric
depression of the Sun's center used for the computations is obtained
by adding the average apparent radius of the Sun (16 arcminutes) to
the [So presumably by incorporation via the Air Almanac reference,
this is pretty much the technical description of Sunset referred to in
the FARs]
I hope pilots get this is a numerical model, they should especially
when presented with a relatively crude table. They need to take into
effect local conditions that affect safety, whether it be terrain,
weather etc. that can all affect local light. But again that was not
the question being asked, which was about official sunset times.
Darryl
Old April 22nd 10, 06:23 PM posted to rec.aviation.soaring
Brian Whatcott
Stephen! wrote:
brian whatcott wrote in news:6
I have run into a definition of sunset that used to go like this:
"The time at which the trajectory of the Solar center is six degrees
below the local horizon."
Using that logic one could say that sunset occurs at 1500 when you are on
the west side of a deep north/south canyon... After all, you can't see the
sun anymore when it goes behind the mountain. It must be sunset, no?
The horizon is the horizon, regardless of the local topography.
Not only could I say that actual sunset might be premature into a high
Rockies field, but more importantly, an accident investigation board
could say that, with backing from a USNO spokesman for that particular
accident site in the Rockies. But as someone has pointed out, an
official FAR night definition which is good for most times and most
places is a different proposition than the odd exceptional cases which
contribute at times to getting pilots killed.
Brian W
p.s. that old definition I (mis)quoted was apparently intended as a
definition for NIGHT rather than sunset, apparently.
Sunrise Patrick R7 Aviation Photos 2 October 19th 08 11:10 AM
Col. Robert Bowman, PhD, U.S. Air Force (ret) - Director of Advanced Space Programs Development under Presidents Ford and Carter. "A lot of these pieces of information, taken together, prove that the official story, the official conspiracy theor Custard Cream Naval Aviation 10 July 14th 07 06:51 PM
Sunrise, Sunset -- the real data, for anywhere in the world [email protected] Piloting 8 June 30th 07 02:59 AM
Jet Sailplane at Sunset Bob C Soaring 0 June 27th 07 07:16 AM
Japan Airlines_Early Bird Sunrise Ducky Aviation Photos 0 February 8th 07 07:31 AM
