official sunset/sunrise
Old April 19th 10, 05:05 PM posted to rec.aviation.soaring
PK
Default official sunset/sunrise
Since most of us that fly cross country (or locally as weel), and are
restrained by the FAR's to be on the ground before sunset assuming
that we don't have position lights. Since most of us use some kind of
navigational devise (SeeYou, Glide Navigator, WinPilot etc.), I am
wondering if any of these programs utilize some data showing sunset at
the region one happens to be in? I am running WinPilot, and not aware
of of any data availabe in conjunction with it. What is everybode else
doing?? 6PK
Old April 19th 10, 06:12 PM posted to rec.aviation.soaring
Darryl Ramm
restrained by the FAR's to be on the ground before sunset *assuming
doing?? 6PK
SeeYou Mobile displays sunrise and sunset on one of the stats pages.
There are various (free) sunrise/sunset calculators for the iPhone and
probably other platforms.
The US Naval observatory will generate tables you can print out if you
need an "official" time.
Darryl
Old April 19th 10, 06:24 PM posted to rec.aviation.soaring
doing?? 6PK
My system is very crude. I use a Garmin 12xl to drive a B50 which in
turn drives my PDA. One of the 12xl screens displays official sunrise
and sunset for the current coordinates. Switching 12xl screens does
not effect NMEA data or the PDA presentation. So if I need the sunset
time, I simply select to the sunrise/sunset screen on the Garmin.
http://www.soaridaho.com
Old April 19th 10, 07:48 PM posted to rec.aviation.soaring
Mike the Strike
doing?? 6PK
My system is very crude. *I use a Garmin 12xl to drive a B50 which in
turn drives my PDA. *One of the 12xl screens displays official sunrise
and sunset for the current coordinates. *Switching 12xl screens does
not effect NMEA data or the PDA presentation. *So if I need the sunset
Waynehttp://www.soaridaho.com
One of the problems we've seen is that there is really no such thing
as an "official" sunset time, just times calculated from astronomical
tables based on a lat/long on the earth's surface. Although these
agree with each other reasonably well, they use geometric
approximations of the earth's shape. Even over sea, there is an
uncertainty of a minute or so over the time the sun actually sets
because of differences in atmospheric refraction. In mountainous
country (like we are in Arizona), actual sunset time can differ from
that calculated in tables by many minutes. This has led to some
grumbling when flights were disallowed because landing occurred after
a calculated sunset, but before an actually observed sunset.
Another wrinkle at our home field is that our prevailing winds have us
land to the west on our main runway and this is definitely easier and
safer just after sunset than just before it, when the setting sun
would be in your face. Fortunately for us, mountains to our west
result in sunset at the field before the computed sunset for our
location, so folks looking at the "official" sunset time don't ding
us. Presumably, though, we should still show position lights if we
land after the sun has actually set at our field.
Old April 19th 10, 08:52 PM posted to rec.aviation.soaring
Darryl Ramm
doing?? 6PK
tables based on a lat/long on the earth's surface. *Although these
approximations of the earth's shape. *Even over sea, there is an
because of differences in atmospheric refraction. *In mountainous
that calculated in tables by many minutes. *This has led to some
would be in your face. *Fortunately for us, mountains to our west
us. *Presumably, though, we should still show position lights if we
It may be semantics but the problem some pilots run into is there is
*exactly* a precise definition of sunset time, it's just too bad it
might be different from what they observe because of what you mention.
Which is why I assume the OP is after a tool that gives pilots
"official times" (which for us in the USA are the US Naval Observatory
times -- i.e. Judy will look at http://aa.usno.navy.mil/data/docs/RS_OneDay..php
for your badge or record flight). SeeYou seems to be close (~1 minute)
to the naval observatory tables when I checked, I presume Garmin gets
this right. Hopefully everybody understands there is absolutely no
leeway on this, if you are outside the official sunset times by even a
small amount you are going to have problems with badges and records.
Darryl
Old April 20th 10, 04:14 AM posted to rec.aviation.soaring
Brian Whatcott
Darryl Ramm wrote:
/snip/
tables/snip/
might be different from what they observe /snip/
Darryl
I have run into a definition of sunset that used to go like this:
"The time at which the trajectory of the Solar center is six degrees
below the local horizon."
You can see how this could vary when the horizon is the Rockies, versus
five miles West where it might be 5000 ft lower...
Brian W
Old April 20th 10, 04:37 AM posted to rec.aviation.soaring
Darryl Ramm
On Apr 19, 8:14*pm, brian whatcott wrote:
Darryl Ramm wrote:
/snip/
tables/snip/
might be different from what they observe */snip/
Darryl
Brian W
Stop tying to make this hard, there is one proper definition to worry
about for gliding in the USA. That is the table generated by the US
Naval Observatory. The FARs define sunset times as published in the
Air Alamanac which is produced by the US Naval Observatory, but for
practical purposes the official data is the USNO tables I provided the
link to. Those tables are exactly what is used for badge and records
flights in the USA and are the numbers glider pilots need to worry
about (unless the glider is one of the few equipped with lights and
appropriate certification, etc. to fly until the end of civil
twilight, in which case the USNO has civil twilight tables as well).
Darryl
Old April 22nd 10, 06:23 PM posted to rec.aviation.soaring
Brian Whatcott
Stephen! wrote:
brian whatcott wrote in news:6
Using that logic one could say that sunset occurs at 1500 when you are on
the west side of a deep north/south canyon... After all, you can't see the
sun anymore when it goes behind the mountain. It must be sunset, no?
The horizon is the horizon, regardless of the local topography.
Not only could I say that actual sunset might be premature into a high
Rockies field, but more importantly, an accident investigation board
could say that, with backing from a USNO spokesman for that particular
accident site in the Rockies. But as someone has pointed out, an
official FAR night definition which is good for most times and most
places is a different proposition than the odd exceptional cases which
contribute at times to getting pilots killed.
Brian W
p.s. that old definition I (mis)quoted was apparently intended as a
definition for NIGHT rather than sunset, apparently.
Old April 19th 10, 09:54 PM posted to rec.aviation.soaring
MickiMinner
I can't tell how important that "sunset" time really is. I HATE
having a long flight not be counted because of 2 or 3 minutes! Judy
(The badge Lady) is very precise in her checking of the sunset times.
Please don't fall in that trap. I had a pilot in Logan Region 9 North
in 2009 that stayed out and out and out...and finally landed 2 minutes
before official sunset...WHEW!!!!!!!
Old April 19th 10, 11:33 PM posted to rec.aviation.soaring
toad
On Apr 19, 4:54*pm, MickiMinner wrote:
I can't tell how important that "sunset" time really is. *I HATE
having a long flight not be counted because of 2 or 3 minutes! *Judy
Please don't fall in that trap. *I had a pilot in Logan Region 9 North
I had a 1000km flight at Mifflin that I had to abort because of the
approaching sunset. I was comparing SeeYou Mobiles sunset with my
expected finish time and just did not have time to make the last
turnpoint ( just south of the wall ) and then return to Mifflin before
dark.
I still was able to claim a 750km flight ( out of 950km flown )
because I landed before sunset. And I didn't have to fly the Raystown
resevoir in the dark !!!
Todd
Sunrise Patrick R7 Aviation Photos 2 October 19th 08 11:10 AM
Col. Robert Bowman, PhD, U.S. Air Force (ret) - Director of Advanced Space Programs Development under Presidents Ford and Carter. "A lot of these pieces of information, taken together, prove that the official story, the official conspiracy theor Custard Cream Naval Aviation 10 July 14th 07 06:51 PM
Sunrise, Sunset -- the real data, for anywhere in the world [email protected] Piloting 8 June 30th 07 02:59 AM
Jet Sailplane at Sunset Bob C Soaring 0 June 27th 07 07:16 AM
Japan Airlines_Early Bird Sunrise Ducky Aviation Photos 0 February 8th 07 07:31 AM
