#11
In article , betwys1
@sbcglobal.net says... Dave Doe wrote: /snip/ On transfer from a Class C approach controller to a Class D tower facility under the umbrella, I got the following direction yesterday when flying in from the west: "Fly a right downwind to runway 17L , clear to land." Got the picture? What is the first turn direction? On which runway do you turn final from base? :-) Brian W &&& Sounds like you'd turn left onto the downwind, turn right base and fly past 17R to turn final and land on 17L. Sounds good to me. Well, that's what I did, and there was no problem. In fact the FAA recommended join is 45 degrees to the downwind leg, so a left turn onto downwind was no issue. Flying a right pattern across a parallel runway would only happen when both runways are not in use, obviously. Not at all. It's up to the controllers surely (I assume we're talking about a towered/controlled field!?!?) -- Duncan. |
brian whatcott wrote:
Flying a right pattern across a parallel runway would only happen when both runways are not in use, obviously. Obviously? Isn't the one you're making the approach to in use? |
I have received almost identical instructions when approaching Centennial,
CO (KAPA) from the west. Centennial has runways 17R and 17L and both were in use when I was cleared to land on 17L. "brian whatcott" wrote in message ... On transfer from a Class C approach controller to a Class D tower facility under the umbrella, I got the following direction yesterday when flying in from the west: "Fly a right downwind to runway 17L , clear to land." Got the picture? What is the first turn direction? On which runway do you turn final from base? :-) Brian W |
Dave Doe wrote:
In article , betwys1 @sbcglobal.net says... Dave Doe wrote: /snip/ On transfer from a Class C approach controller to a Class D tower facility under the umbrella, I got the following direction yesterday when flying in from the west: "Fly a right downwind to runway 17L , clear to land." Got the picture? What is the first turn direction? On which runway do you turn final from base? :-) Brian W &&& Sounds like you'd turn left onto the downwind, turn right base and fly past 17R to turn final and land on 17L. Sounds good to me. Well, that's what I did, and there was no problem. In fact the FAA recommended join is 45 degrees to the downwind leg, so a left turn onto downwind was no issue. Flying a right pattern across a parallel runway would only happen when both runways are not in use, obviously. Not at all. It's up to the controllers surely (I assume we're talking about a towered/controlled field!?!?) This was the situation on Sunday at Wiley Post,(PWA) at Oklahoma City. I would expect Oke City Approach (at Will Rogers) to vector traffic appropriately, if PWA 17L & R were both active. But it's the controllers' call, no doubt! Brian W |
Steven P. McNicoll wrote:
brian whatcott wrote: Flying a right pattern across a parallel runway would only happen when both runways are not in use, obviously. Obviously? Isn't the one you're making the approach to in use? Yes indeed, the clearance was to 17L PWA from the west. 17R a shorter runway there, was not in use. Brian W |
I would sympathize with a green pilot on his first approach across
finals of an active approach! Regards Brian W Jon Woellhaf wrote: I have received almost identical instructions when approaching Centennial, CO (KAPA) from the west. Centennial has runways 17R and 17L and both were in use when I was cleared to land on 17L. "brian whatcott" wrote in message ... On transfer from a Class C approach controller to a Class D tower facility under the umbrella, I got the following direction yesterday when flying in from the west: "Fly a right downwind to runway 17L , clear to land." Got the picture? What is the first turn direction? On which runway do you turn final from base? :-) Brian W |
![]() "Edward A. Falk" wrote That's what I'm thinking, but I'd definitely ask them to confirm they want me to cross the 17R approach. Why? The instructions were clear, there was only one way to fly that approach, so the controller knew he would be crossing the approach path for 17R. This isn't at all related to taxi instructions. Take a quick look up the glide slope as you approach it, then do what "the man" says. -- Jim in NC |
ILS approach and VOR Alpha Approach video | DOCTOR Mary Ellen Hall McIntire Yasay, Ph.D, (Div.) | Piloting | 3 | May 22nd 08 01:52 PM |
ILS approach and VOR Alpha Approach video | [email protected] | Instrument Flight Rules | 10 | May 22nd 08 02:15 AM |
ILS approach and VOR Alpha Approach video | [email protected] | Piloting | 4 | May 17th 08 01:19 PM |
Garmin 430 rquestion- does the approach always have to be activated via "activate approach"? | Terence Wilson | Instrument Flight Rules | 46 | February 18th 08 05:46 PM |
Completing the Non-precision approach as a Visual Approach | John Clonts | Instrument Flight Rules | 45 | November 20th 03 05:20 AM |
