Just pull the little red handle!
Old August 30th 10, 08:35 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Default Just pull the little red handle!
Little red handle anyone?
JJ
If I could put one in my standard category asw 27, I would.
In the meantime, why don't we get together and buy flarms, so we don't
run in to each other in the first place. They're even on sale for the
first 50 orders. I put my order in, so if you get one you won't run in
to me next year!
John Cochrane BB
Old August 30th 10, 09:24 PM posted to rec.aviation.soaring
jcarlyle
With a BRS, what happens to your back and feet when you hit the
ground, still strapped inside the cockpit in a sitting position? At
the minimum I'd think you'd want a real good energy absorbing cushion,
and you probably should remember to lower the gear, too. I know, I
know - better alive than dead. But the thought of being crippled for
life is very sobering, too.
DG has posted some of their thoughts on Recovery Systems:
http://www.dg-flugzeugbau.de/rettungssystem-e.html
Yeah, they're pushing NOAH, but there's some good stuff in this
article.
-John
Old August 30th 10, 10:03 PM posted to rec.aviation.soaring
kirk.stant
to me next year!
John Cochrane BB
I agree with John. I prefer to avoid the midair first. So my
priority is PCAS, FLARM, Mode S transponder (with ADS-B out in the
future). With those systems up and running, the chance of a midair
is drastically reduced, IMO.
So instead of crying for a worst case solution, we should be pushing
for fleet wide adoption of less expensive and more useful solutions -
how about radios and FLARM in all gliders and towplanes? Or audio
varios and radios in all trainers? There is a lot we can do,
relatively inexpensively, before we get to the point of installing BRS
chutes in our gliders!
DG also has their NOAH system that can probably be retrofitted to most
gliders a lot easier than a BRS - that would be my first choice,
instead of riding down in the glider after a midair.
Kirk
Old August 30th 10, 10:21 PM posted to rec.aviation.soaring
Andy[_1_]
On Aug 30, 12:35*pm, John Cochrane
For one reason FLARM is not approved for use in US and for another I'm
not aware of any manufacturer that has published a date when it will
be available and approved for use in US.
I think if potential manufacturers were more open with plans,
specifications, and schedules there would be more interest.
Andy
Old August 31st 10, 12:13 AM posted to rec.aviation.soaring
Darryl Ramm
Andy
More interest? Jeez I see a very large interest in the PowerFLARM.
The manufacturer has put back their data for availability.
Distributors like Craggy Aero are now stating availability of
PowerFLARM December 2010. See See http://www.craggyaero.com/collision_avoidance.htm
PowerFLARM cannot be legally sold in the USA without FCC approval, so
that date implies FCC approval. If you want to order one and have
questions about availability or other things call Richard at Craggy,
or any of the other dealers...
There has been lots of comments on r.a.s on specifications. Dave
Nadler, myself and others who are aware of some of the details have
clarified this where there was questions. Seems at least part of the
problem was there were people who wanted to look at the ButterFly/
PowerFLARM European web site and would not believe us that things
there may not exactly apply to the USA version of the product.
Folks are working on putting up a web site with USA specific content,
but in the meantime what else exactly is not clear?
Darryl
Old August 31st 10, 12:41 AM posted to rec.aviation.soaring
Richard[_9_]
Andy
Andy,
I talked with one of the Flarm Directors today. He is confident that
PowerFlarm will be delivered in December 2010. The reason for the
delay was some part procurement problems. I believe the display.
Details at :
Richard
www.craggyaero.com
Old August 31st 10, 06:46 PM posted to rec.aviation.soaring
Tuno
There is a little red handle I would LOVE to have.
Many years ago the skydiving industry came up with a way to jettison a
malfunctioned main canopy and deploy the reserve as a single action by
simply adding a static line from the main parachute's riser to the
reserve parachute's pin. Thus pulling the "cutaway" handle would also
result in a deployed reserve. This system was especially appreciated
at low altitudes!
Since August 4th I've been wondering how difficult it would be to add
a single "red handle" to the glider cockpit, that would be secured to
one of the shoulder straps (i.e. at the pilot's torso, easy to find in
the worst of conditions). Pulling this handle would simultaneously
release the canopy and unbuckle the harness. No fumbling for one set
of handles and then another.
This handle, as I envision it, would look very much like the cutaway
handles in skydiving -- a small pillow attached to teflon cable(s),
brightly colored, hard to pull by accident but easy to find and pull
on purpose.
ted/2NO
Old August 31st 10, 06:54 PM posted to rec.aviation.soaring
Ramy
JJ
to me next year!
John Cochrane BB
Same here. If there was an option to add a BRS to my 27, I would, even
if it will be a substantial cost.
I flew hang gliders with a BRS system for many years, and know of a
number of hang glider pilots saved by this system.
While I doubt it will help with stall/spin accidents, which still
seems to be the cause of many accidents, a proper system should be
able to save most mid airs, control problems and structural failures.
But in the meantime, to address midairs, the PowerFlarm is the obvious
solution, and I just ordered mine. My hope is that within a year of
it's release, pilots who fly without them will feel unwelcome to a
point they will rather get one...
Ramy
Old August 31st 10, 07:05 PM posted to rec.aviation.soaring
Mike Schumann
at low altitudes!
on purpose.
ted/2NO
I suspect that one of the principle risk areas for mid-airs (outside of
contests) is in the pattern, near an airport. There is absolutely no
way a conventional chut can save you when you are this low, no matter
how fast you can get out of the glider. A BRS can.
Mike Schumann
Old August 31st 10, 07:08 PM posted to rec.aviation.soaring
Andy[_1_]
So you are saying that the only manufacturer's web site that provides
any information on PowerFLARM is not related to the US product, but
you still ask me what is not clear?
I have downloaded and read extensive documentation on FLARM, including
a user manual, installation guide, data port specification and also
checked on a FLARM forum. There is lots of information on the
exisitng FLARM products.
Please let me know when and where I can find the equivalent
information on US Power FLARM. That is the clarity I seek.
I have been interested in PowerFLARM since the first announcement of
an intention to make it available in US. That was a long time ago.
Having an interest is not the same as having an intention to spend a
lot of money on a product that is not yet available and for which no
specifications are published.
So, anyone who wants my money please send me the specifications that
the product is being designed to meet, a definition of what capability
will be in the first release, and a schedule for adding features that
are not included in the first release. First dealer to do that will
have the first bite at my wallet.
Andy
Wing Launch - Can it pull your wings off? ContestID67[_2_] Soaring 92 September 5th 10 10:51 PM
physics question about pull ups John Rivers Soaring 59 June 10th 10 12:21 PM
Pull up a chair and hear me out: Vaughn Aviation Marketplace 0 February 2nd 06 02:04 AM
Pull plane by tail hook Tarif Halabi Owning 19 February 24th 04 02:27 PM
Glider pull-up and ballast M B Soaring 0 September 15th 03 06:29 PM
