Wing Launch - Can it pull your wings off?
Old August 12th 10, 11:16 PM posted to rec.aviation.soaring
ContestID67[_2_]
Default Wing Launch - Can it pull your wings off?
I was sent this link from a UK soaring friend of mine about a death
when the wings came off of a glider during a winch tow.
http://www.dailymail.co.uk/news/arti...ll-glider.html
Sad story. A few things;
- My friend's thought was that the wing pins were left out. Howerver,
this was the second flight of the day. Both winch launches. So I
would think that the wing pins were installed but the wings failed
under a winch load. Which glider was it? Older? Wooden spars?
Never having had a winch launch, what happens if you don't release
back pressure at the top? Can you pull your wings off? Maybe
safeties on the pins were missed and the pins wiggled out on the
second flight after staying in for the first.
- I was under the impression that the BGA required parachutes for all
pilots. Wrong? 1000 ft should have been enough to get out in time
but who knows what was happening in the cockpit or if she was 1000 MSL
or AGL at the time.
Thanks.
- John DeRosa
Old August 12th 10, 11:30 PM posted to rec.aviation.soaring
Tony[_5_]
when the wings came off of a glider during a winch tow.http://www.dailymail.co.uk/news/arti...lunged-death-b...
Sad story. *A few things;
- My friend's thought was that the wing pins were left out. *Howerver,
this was the second flight of the day. *Both winch launches. *So I
under a winch load. *Which glider was it? *Older? *Wooden spars?
back pressure at the top? *Can you pull your wings off? *Maybe
pilots. *Wrong? *1000 ft should have been enough to get out in time
or AGL at the time.
Thanks.
- John DeRosa
I suppose if you overload the structure you can rip the wings off
anything. No glider is immune from this.
Old August 13th 10, 12:07 AM posted to rec.aviation.soaring
or AGL at the time.
Thanks.
- John DeRosa
There was a thread about this recently.
The Gist:
IF glider is in proper condition
AND correct weak link is used
THEN- you won't pull the wings off on launch.
And- 1000 ft is not much time to asess, open canopy, get out, and open
chute. Virtually no chance.
FWIW
UH
Old August 13th 10, 12:12 AM posted to rec.aviation.soaring
Frank Whiteley
or AGL at the time.
Thanks.
- John DeRosa
It was a Foka 4.
Foka-4 was a derivative of the Foka line
http://en.wikipedia.org/wiki/Foka_%28glider%29
Cobra was the next to last iteration, with 17m being the last.
http://en.wikipedia.org/wiki/SZD-36_Cobra_15
Note the comments on failures.
I don't know that the 4 had the same wing join design, but suspect it
was very similar.
There was a wing failure on a Cobra in the US and a sobering analysis.
http://www.sylacaugasoaring.com/SZD%...%20WARNING.htm
The SHK has an expanding vertical pin. There's an anecdotal story of
someone who used the right-hand to expand the pin, and finished the
job with left-hand, in the opposite direction. The wings reportedly
departed at the top of the launch. The pilot reportedly pulled the
tail chute on the way down.
I believe that some German studies found that successful egress and
parachute deployment below 600m is unlikely, of course there are
exceptions. The better emergency chutes are life saving from 100ft
agl at 100kts horizontal.
Wing failure on a winch launch is very rare. There was a K-7 at RAF
Dishforth in the UK a while back, but the investigation determined
there was prior damage to the spar which was not found following
another incident. There was a homebuilt in Colorado that had a wing
failure due to aileron flutter during a winch launch. After two weak
link breaks, the pilot doubled the weak link (unknown to the winch
crew). The described flight path was one of climb, level off, climb,
level off, climb, glider breakup, crash. The wing inspection hatch
was found early in the flight path. What did not appear in the NTSB
report was that the pilot was refused further tows at the local FBO
after the glider had suffered significant aileron flutter on aero tow.
I winched at RAF Bicester when it was the RAF/GSA Centre. Appropriate
weak links were always used, like any UK club. It's not a long run,
but easy enough to climb away on the thermal day.
Steel wire rope used in many places typically has a breaking strength
of 2800-3500lbs. The new UHMWPE 12-strand ropes (Spectra, Plasma,
Dyneema, Amsteel) now in common use are nominally 3500-5400lbs
breaking strength at similar diameters, thus use of correct weak links
are essential to avoid damaging a glider as some winches have
substantial power and there are also gusts and thermals to allow for.
Frank Whiteley
Old August 13th 10, 05:30 PM posted to rec.aviation.soaring
bildan
or AGL at the time.
Thanks.
- John DeRosa
It was a Foka 4.
Foka-4 was a derivative of the Foka linehttp://en.wikipedia.org/wiki/Foka_%28glider%29
Cobra was the next to last iteration, with 17m being the last.http://en.wikipedia.org/wiki/SZD-36_Cobra_15
was very similar.
There was a wing failure on a Cobra in the US and a sobering analysis.http://www.sylacaugasoaring.com/SZD%...%20WARNING.htm
The SHK has an expanding vertical pin. *There's an anecdotal story of
job with left-hand, in the opposite direction. *The wings reportedly
departed at the top of the launch. *The pilot reportedly pulled the
exceptions. *The better emergency chutes are life saving from 100ft
Wing failure on a winch launch is very rare. *There was a K-7 at RAF
another incident. *There was a homebuilt in Colorado that had a wing
failure due to aileron flutter during a winch launch. *After two weak
crew). *The described flight path was one of climb, level off, climb,
level off, climb, glider breakup, crash. *The wing inspection hatch
was found early in the flight path. *What did not appear in the NTSB
I winched at RAF Bicester when it was the RAF/GSA Centre. *Appropriate
weak links were always used, like any UK club. *It's not a long run,
of 2800-3500lbs. *The new UHMWPE 12-strand ropes (Spectra, Plasma,
Frank Whiteley
Frank's analysis is excellent.
I would only add that the wing spar loads incurred during a winch
launch is approximately that of a loop. If a glider is not approved
for loops or its age and condition is such you wouldn't loop it, don't
winch launch it.
Always use the EXACT weak link specified in the manual. If a glider's
manual doesn't specify a winch launch weak link - you're going to be a
test pilot if you winch it.
Bill Daniels
Old August 13th 10, 06:56 PM posted to rec.aviation.soaring
Andy[_1_]
On Aug 13, 8:30*am, bildan wrote:
Always use the EXACT weak link specified in the manual. *If a glider's
What would be the consequence of using a link say 10% weaker than that
specified? If I know the link is weaker I can fly a less agressive
climb profile and accept that I will get a lower launch altitude. If
I forget and climb agressively the link will break - so what?
Andy
Old August 13th 10, 07:35 PM posted to rec.aviation.soaring
Frank Whiteley
specified? *If I know the link is weaker I can fly a less agressive
climb profile and accept that I will get a lower launch altitude. *If
Andy
I've had experience as a winch driver with gliders using weaker links
resulting in frequent breakage. In that case I would suggest the
pilot insisting on using the weaker link be held accountable for the
cost of broken link and any lost rigging. Links are $7 (x4 in this
case) and I'm still looking for a missing strop, shackle, and ring set
($100). Two went missing on a single day, with one having since been
recovered. A few years ago a strop vanished and was found 4.5 years
later.
There are recommendations that if the correct value isn't specified or
known to use 1.3 x MAUW. This is one reference to that formula
http://tinyurl.com/258ba3j
Frank Whiteley
Old August 13th 10, 08:45 PM posted to rec.aviation.soaring
Derek C
Andy
The consequence of using a 10% weaker link would be a greater chance
of a broken weak link and a failed launch, which might be hazardous in
itself under some circumstances. If you use the correct link as
specified by the glider designer and the glider is in airworthy
condition, there should be no chance of a structural failure. All
gliders in the UK have to have an annual inspection and airworthiness
review. The glider that failed was a 30 year old wooden design. It has
been suggested that the tapered main pin might not have been fully
engaged, but the glider had survived a previous winch launch. My
sincere condolences to the family and friends of this young lady
pilot.
http://www.bbc.co.uk/news/uk-england-10949058
Derek C
Old August 13th 10, 08:46 PM posted to rec.aviation.soaring
Derek C
Andy
pilot.
Derek C
Old August 13th 10, 09:00 PM posted to rec.aviation.soaring
bildan
Andy
resulting in frequent breakage. *In that case I would suggest the
cost of broken link and any lost rigging. *Links are $7 (x4 in this
($100). *Two went missing on a single day, with one having since been
recovered. *A few years ago a strop vanished and was found 4.5 years
later.
known to use 1.3 x MAUW. *This is one reference to that formulahttp://tinyurl.com/258ba3j
Frank Whiteley
Again, Frank has provided a good analysis. Again I will add a few
points.
As frank says, a weaker than specified link will muck up the operation
when it breaks.
You really don't want it to break since you will then have to deal
with a launch failure - usually as you load the rope while rotating
into the climb. This, is NOT good.
If your glider was certified with an Approved Flight Manual, as all
JAR-22 gliders are, FAR's require you to operate in compliance with
that manual. That includes using the correct weak link - usually
specified to a + or - 10% tolerance. Incidentally, that also applies
to aero tow. The old 80-200% rule only applies to gliders without an
AFM. (i.e.Schweizers)
If you are being launched with one of the new Automatic Tension
Control winches, you must control your airspeed with pitch.
Attempting to climb at a lower angle will result in an over speed
condition.
The bottom line is you have no choice in weak links - you must use the
one specified in the manual.
physics question about pull ups John Rivers Soaring 59 June 10th 10 01:21 PM
FS: Wings&Wheels Wing Stand James Hamilton[_2_] Soaring 0 September 12th 09 02:15 AM
Pull up a chair and hear me out: Vaughn Aviation Marketplace 0 February 2nd 06 03:04 AM
Better GPS, Flight Computer, Variable Wing Geometry, abililty to Self-Launch Stewart Kissel Soaring 7 May 2nd 05 07:02 PM
Glider pull-up and ballast M B Soaring 0 September 15th 03 07:29 PM
