On Sep 27, 11:46*am, "Tim Mara" wrote:
Pete Russel (former SAGE Variometer maker) tested TE probes in all directions..Pete reported it worked equally as well off to the left or right as it did up or down.... Its completely dependent on the glider and the length of the probe... In general, UP is much preferred. See ya, Dave |
On Sep 26, 12:13*pm, "kirk.stant" wrote:
It's raining at the field today so here is a serious soaring question to ponder: Should the end of the TE probe on the fin point up or down? Informal surveys at recent contests seem to show a slight preference for up (not counting those "swingers" that go both ways). I've heard all sorts of reasons why each orientation is best - angle of attack during pull-ups, airflow in front of the tail, G-effects on the air column, blah blah blah... I point mine up so I don't snag it when taking off the tail dolly! Comments? Kirk Wet in IL DOWN |
To state the obvious: Male pilots prefer up.
When I had a TE probe installed on my Ka-6E I ask Roger Frank the posting subject question. He responded immediately "it should be UP!! Otherwise some jerk will hang their hat on it."
Wayne HP-14 "6F" http://tinyurl.com/N990-6F "kirk.stant" wrote in message ... It's raining at the field today so here is a serious soaring question to ponder: Should the end of the TE probe on the fin point up or down? Informal surveys at recent contests seem to show a slight preference for up (not counting those "swingers" that go both ways). I've heard all sorts of reasons why each orientation is best - angle of attack during pull-ups, airflow in front of the tail, G-effects on the air column, blah blah blah... I point mine up so I don't snag it when taking off the tail dolly! Comments? Kirk Wet in IL |
Opps, I ment to type "it should be DOWN!! Otherwise some jerk will hang their had on it."
"Wayne Paul" wrote in message ... When I had a TE probe installed on my Ka-6E I ask Roger Frank the posting subject question. He responded immediately "it should be UP!! Otherwise some jerk will hang their hat on it." Wayne HP-14 "6F" http://tinyurl.com/N990-6F "kirk.stant" wrote in message ... It's raining at the field today so here is a serious soaring question to ponder: Should the end of the TE probe on the fin point up or down? Informal surveys at recent contests seem to show a slight preference for up (not counting those "swingers" that go both ways). I've heard all sorts of reasons why each orientation is best - angle of attack during pull-ups, airflow in front of the tail, G-effects on the air column, blah blah blah... I point mine up so I don't snag it when taking off the tail dolly! Comments? Kirk Wet in IL |
On Sep 26, 3:13*pm, "kirk.stant" wrote:
It's raining at the field today so here is a serious soaring question to ponder: Should the end of the TE probe on the fin point up or down? Informal surveys at recent contests seem to show a slight preference for up (not counting those "swingers" that go both ways). I've heard all sorts of reasons why each orientation is best - angle of attack during pull-ups, airflow in front of the tail, G-effects on the air column, blah blah blah... I point mine up so I don't snag it when taking off the tail dolly! Comments? Kirk Wet in IL Up works better for me on Schleicher gliders. This raises the sensing point about 6 inches which reduces errors form wing root vortexes whien I pull really hard. I leave probe in cockpit on claf pad until glider is on the grid with dolly off to avoid damage. FWIW UH |
It's raining at the field today so here is a serious soaring question to ponder: Should the end of the TE probe on the fin point up or down? Informal surveys at recent contests seem to show a slight preference for up (not counting those "swingers" that go both ways). I've heard all sorts of reasons why each orientation is best - angle of attack during pull-ups, airflow in front of the tail, G-effects on the air column, blah blah blah... I point mine up so I don't snag it when taking off the tail dolly! Comments? Kirk Wet in IL I point mine down. I tried it pointed up once, because all the cool kids were doing it. I found that with it pointed up, the onset of 'needle flutter' happened sooner on my glider. Also, if I tie out for a day, and it rains, there is a possiblilty of water getting into my system with it pointed up. |
On Sep 27, 1:44*pm, Grider Pirate wrote:
On Sep 26, 12:13*pm, "kirk.stant" wrote: I point mine down. *I tried it pointed up once, because all the cool kids were doing it. *I found that with it pointed up, the onset of 'needle flutter' happened sooner on my glider. *Also, if I tie out for a day, and it rains, there is a possiblilty of water getting into my system with it pointed up. Put a bag over it and you can keep it pointed up.... |
On Sep 27, 12:49*pm, Whiskey Delta wrote:
On Sep 27, 1:44*pm, Grider Pirate wrote: On Sep 26, 12:13*pm, "kirk.stant" wrote: I point mine down. *I tried it pointed up once, because all the cool kids were doing it. *I found that with it pointed up, the onset of 'needle flutter' happened sooner on my glider. *Also, if I tie out for a day, and it rains, there is a possiblilty of water getting into my system with it pointed up. Put a bag over it and you can keep it pointed up.... After day two of the Memorial Day contest in Huntley this year, we had the regular hangar BS session in the evening. Herb Killian was of the opinion that it should point down. It did have something to do with a pee bag snagging on the upturned TE probe :-) Pete |
![]() According to the ESA website, which adressed this frequently ask question, it should be pointed up according to professor Loek Boermans unless you have the DN/x type probe. This probe should be mounted horizontally, i.e. parallel to the wings. They also explain the reasoning for this. Barry |
Ka-6 TE Probe | vontresc | Soaring | 14 | August 30th 08 03:17 AM |
Probe problem | smf | Home Built | 3 | July 8th 07 01:29 PM |
TE Probe on ASW-15 | [email protected] | Soaring | 4 | April 29th 07 01:43 AM |
Multi - probe | KP | Soaring | 1 | March 7th 05 06:03 PM |
TE-Probe for 1-26D | Heinz Gehlhaar | Soaring | 6 | January 17th 05 10:52 PM |
