Probe problem
Old July 8th 07, 06:49 AM posted to rec.aviation.homebuilt
smf
Default Probe problem
I changed a bad probe on one cyl. My Hanger mate and I had about 8
spares.with very little time. I tried 6 of these and the same thing
happened. . When I snugged it up to the exaust pipe it would read 76..If I
took it out and put heat to it it worked ok. I did this to 5 or 6 and the
same thing happened. As soon as I snug it up it would not work. I can't
figure out what is happening. I know all the probes can't be bad .
any ideas
Steve
Old July 8th 07, 07:07 AM posted to rec.aviation.homebuilt
Morgans[_2_]
"smf" wrote in message
any ideas
Try starting your engine after you install them. (GD&R)
Old July 8th 07, 07:20 AM posted to rec.aviation.homebuilt
Bob Kuykendall
Try heating one up and then touching it to the engine to see if the
problem has to do with a short to ground in the wires or gage.
Old July 8th 07, 01:29 PM posted to rec.aviation.homebuilt
smf
I switched the probes and the problem went to the other cyl. It must be
some sort of ground problem because it doesn't quit working until the probe
is snugged up against the pipe.
steve
"Bob Kuykendall" wrote in message
TE Probe on ASW-15 [email protected] Soaring 4 April 29th 07 01:43 AM
Outside air temperature probe dlevy Owning 9 November 7th 06 05:14 PM
More on CHT probe replacement Jim Burns Owning 12 September 1st 05 10:45 PM
TE-Probe for 1-26D Heinz Gehlhaar Soaring 6 January 17th 05 10:52 PM
TE probe for SGS2-33 Rod Pool Soaring 1 May 20th 04 06:08 PM
