Mode S code?
Old July 16th 04, 02:22 PM
William W. Plummer
Default Mode S code?
I was looking at the FAA N-number database. Everything seems to have a
mode S code, even a friend's balloon that doesn't have a transponder.
Can anybody explain that?
Old July 16th 04, 02:51 PM
On Fri, 16 Jul 2004 13:22:56 GMT, "William W. Plummer"
It's probably easier to assign a code to *everything* that has an N-number.
After all, the FAA may eventually require all aircraft to carry a
transponder. Plus, if your friend's balloon is eventually decommissioned
and the N-number reassigned, the Mode S code is already established.
Old July 16th 04, 03:07 PM
G. Burkhart
"Ron Wanttaja" wrote in message
N-number.
I may be wrong, but isn't the S code unique for an aircraft? If an aircraft
changes its N number, does the S code change too? If an N number is
reassigned to another aircraft does the S code change?
-Greg /X
S code: 53171652
Old July 16th 04, 04:32 PM
William W. Plummer
N-number.
My guess is the S code is unique to the transponder, not the plane.
Old July 16th 04, 05:03 PM
Thomas Borchert
William,
Actually, the S code is programmed into the transponder in setup mode
and can be changed any time. The code is issued by the aviation
authorities for an aircraft registration number. Or, in the case of
airline flights, the actual flight number is programmed into the
transponder, which, as you can imagine, changes quite a bit.
With our German GTX330 installation, the LBA (German FAA-equivalent)
issued a hex code upon installation for our aircraft which was then put
into the transponder.
Thomas Borchert (EDDH)
Old July 16th 04, 07:43 PM
Ron Natalie
"William W. Plummer" wrote in message news:cxSJc.104956 I may be wrong, but isn't the S code
The Mode S goes with the aircraft. Each aircraft registration has a mode S. It's
constant whether the N number changes or what transponder is in the aircraft.
Old July 17th 04, 01:19 PM
Thomas Borchert
Ron,
What's the difference between N number and aircraft registration in
the above quote?
Non-radar transponder codes Michael Instrument Flight Rules 16 February 13th 04 01:15 PM
Transponder code switching Ken Pruchnick Instrument Flight Rules 30 October 12th 03 08:31 PM
"New" ASCC code names Andreas Parsch Military Aviation 0 September 9th 03 08:04 AM
Mode S questoin JerryK Instrument Flight Rules 1 July 17th 03 09:56 PM
