Beating humidity
Old December 13th 10, 01:05 AM posted to rec.aviation.soaring
Mike the Strike
Default Beating humidity
On Dec 11, 10:15*pm, Eric Greenwell wrote:
On 12/11/2010 9:07 PM, brianDG303 wrote:
Just as a discussion, I have had some experience trying to make even
quite small containers (art exhibit display cases) dust tight with a
notable lack of success, both by me and others I have observed. *As
you seal the container, you don't actually change the amount of air
circulation, I suspect; you just change the velocity of the air at the
inlet points you can't close up. *I am sure there is some benefit to
sealing, but to make a display case dust tight you seal up what you
can, then provide positive pressure through a lot of filters, or in
less critical situation just provide a lot of filter surface area to
lower the resistance of the filtered air. *The problem is that
temperature differences inside to outside create air pressure
differences that push the air in and out. *Perhaps a solution is to
seal up the trailer really well and then provide a source of inlet air
that is drawn across a long desiccant tray or something.
Maybe you need "ballast". Make the trailer airtight, but run a vent tube
from it to a plastic garbage bag half full of air: when the trailer
"breathes" it just moves air in and out of the garbage bag, and soon the
dehumidifier has all the trailer air (and bag air) dry, dry, dry!
email me)
Andy, a few years ago, you were reputed to be moving to Arizona.
Maybe it's time to reconsider where you live? I can confirm that you
are very unlikely to have severe condensation issues here.
However, if we can't talk you into moving to a more sensible climatic
zone, I had to solve a similar situation many years ago when I needed
to maintain a dry atmosphere inside an outside 4'x4' metal cabinet
with sensitive electronic equipment. We ran two 60-watt light bulbs
in series - worked great! About six to ten 60-watt bulbs operated at
60 V should do the trick.
Old December 13th 10, 06:46 AM posted to rec.aviation.soaring
Andy[_10_]
email me)
Maybe it's time to reconsider where you live? *I can confirm that you
with sensitive electronic equipment. *We ran two 60-watt light bulbs
in series - worked great! *About six to ten 60-watt bulbs operated at
Yeah, my move was...uh...delayed.
For now the dehumidifier is working. I don't see a lot of reason why
there would be tons of air movement in and out. There isn't much
temperature differential or change thereto over time. I guess
lightbulbs could help too.
9B
Blue Angels back in Pensacola - practice session - no humidity means little vapor Pensacola Beachcomber Aviation Photos 0 March 23rd 08 04:29 PM
Blue sky and high humidity with aircraft at Mach 0.97 12Sep07 Tom Callahan Aviation Photos 2 September 14th 07 04:54 PM
Beating Nausea S Culver Aerobatics 5 January 30th 07 10:41 PM
Bush and the neocons beating war drums for attack on Iran [email protected] Naval Aviation 1 April 6th 06 06:56 PM
air humidity Corrie Home Built 2 January 19th 04 03:07 PM
