Beating humidity
Old December 11th 10, 09:42 PM posted to rec.aviation.soaring
Andy[_10_]
Default Beating humidity
Last year for the first time since I bought my gilder I discovered
what cold, humid, Northern California winter air can do to the
untreated steel parts on my glider. This year I was determined to
keep corrosion at bay and bought a dehumidifier to put in the
trailer. I also bought one of those radio-remote temperature and
humidity sensors to put inside the trailer to keep track of the
effectiveness of my efforts.
My Cobra trailer is pretty well sealed except for a gap between the
tailgate and the fiberglass top. I positioned the dehumidifier on the
trailer floor between the tailboom and the wing and sealed the air
gap. I checked after the first week and discovered the dehumidifier's
water receptacle was about 1/3 full. The past couple of days have been
rainy and cool - low 50s and 77% humidity this morning. Inside the
trailer it's a few degrees warmer and the really good news is the
humidity is 22%.
I'll probably do a couple of experiments in the coming weeks to see
how long it takes to get the humidity down and how long it takes to
drift back up to ambient levels with the dehumidifier of. I know that
not everyone keeps their trailer near 110v power outlets and my
dehumidifier is 330 watts, so batteries with an inverter and/or solar
cells are not an option for continuous operation, but maybe it would
work if you could get things dry in a burst and let the trailer sit
for a period of time before giving it another burst.
Here's the dehumidifier I bought:
http://www.amazon.com/gp/product/B00...ef=oss_product
9B
Old December 11th 10, 09:57 PM posted to rec.aviation.soaring
John Cochrane[_2_]
untreated steel parts on my glider. *This year I was determined to
trailer. *I also bought one of those radio-remote temperature and
humidity is 22%.
9B
I did some similar experiments a while ago. The big issue is the daily
condensation cycle. All our gliders are sopping wet inside the
trailers many mornings. I saw daily 100% humidities. Inside a hangar
can be worse than outside, since the solar vent no longer works. Also
hangars here in the midwest often have a very cold concrete floor.
Then, you get warm humid spring days, and it's just a moisture
magnet.
I found the "mighty dry" dehumidifier and cut a hole in the bottom of
the trailer to release the water. It worked great while I had a 110V
supply. Alas, I now have to park away from power.
A dehumidifier isn't a great idea where in freezes in the winter. You
can also put a 40 w bulb in, or better (what I use) a bilge heater
from your local boat store. This is a 40w heater designed to address
similar humidity problems in boats. It keeps the glider just slightly
warmer than ambient and seems to help a lot with the condensation
issue.
The world is still waiting for a good humidity solution for trailers
parked away from power.
John Cochrane BB
Old December 11th 10, 10:31 PM posted to rec.aviation.soaring
I insulated the inner walls of my older all metal trailer with 1/8"
inch thick foam. Type used underneath automobile headliners. Worked
wonders with condensation issues I had. Delays the cooling at night
and moderates the heat in the daytime. I open it in the morning and
have no moisure to speak of on my glider. It may still sometimes occur
but it has greatly helped. Before, with the bare metal, it was
terrible, like a glass of iced tea in the summer, dripping wet walls.
I am down in Florida though so your milage my vary. Humid for sure,
but not as cold although our low will be in the upper 20's tomorrow
night.
In addition to this foam liner I only have a solar powered vent fan.
Craig
Old December 11th 10, 10:50 PM posted to rec.aviation.soaring
Andy[_10_]
On Dec 11, 1:57*pm, John Cochrane
humidity is 22%.
9B
magnet.
issue.
John Cochrane BB
I may not understand enough about the condensation cycle. But I would
think if you can get the absolute amount of water vapor inside the
trailer down low enough you'd have a decent chance of keeping it from
condensing through a reasonably wide temperature swing. Fortunately
where I live the swing is usually only 20-25 degrees. If you have to
heat your glider trailer, well that's a whole different set of issues
I guess.
9B
Old December 11th 10, 11:27 PM posted to rec.aviation.soaring
John Cochrane[_2_]
where I live the swing is usually only 20-25 degrees. *If you have to
I guess.
9B
That's a thought that has occurred to me. Seal the thing up tight,
spread drying crystals all over the place. However, then it would get
really super hot in the middle of the day which I'm not so sure is a
good idea.
John Cochrane
Old December 12th 10, 12:50 AM posted to rec.aviation.soaring
Darryl Ramm
humidity is 22%.
9B
I think Andy is goign about this right. I face rust issues on
machinery in my woodwork shop and use a DeLonghi Dehumidifier, as well
as special covers and waxing on exposed die cast surfaces etc. to keep
rust issues down. The exact humidifier I uses is no longer
manufactured, its a fairly large one designed for basements etc, with
a built in pump to get the caught water outside. If I had my trailer
at home I would probalby have a similar dehumidifier in the front,
turn it down to a pretty low humidity and let it run. All it needs is
for the temperature to get warm enough and it kick on an scrub out the
moisture (where Andy lives near me this is not a problem). In colder
weather I'd think about insulation and lightbulbs/heaters as well.
Andy I hope you have a fiberglass trailer top or some way of putting
the antenna of the sensor outside? Are you logging this to a computer?
The results would be interesting.
With a dehumidier like this inside you want to seal the trailer really
well. You can go around the trailer carefully sealing up obvious holes/
vents etc. but as a warning I've also noticed on my 18m Cobra trailer
at least that the gas struts deform the side of the lid enough that it
is a poor seal along the sides near where the gas struts attach to the
lid. Somethign I've not tried to fix and not sure if there is an easy
fix for. So I wonder about this happening on a 15m trailer as well.
You want to do some playing inside the trailer and see if it seals
well for you.
I remain skeptical of some of the solar vents as being that useful and
maybe contribute themselves to problems. I'd like to see actual
humidity and air and surface temperature measurements inside trailers
and started to build a system to do this but never finished it.
Darryl
Old December 12th 10, 01:21 AM posted to rec.aviation.soaring
Andy[_10_]
humidity is 22%.
9B
vents etc. *but as a warning I've also noticed on my 18m Cobra trailer
well for you.
Darryl
Yeah, I've got the glass top trailer, which has no venting that I can
find. The side rails seem to seat pretty well with the rubber seal on
the sidewall sill. The tailgate sits pretty low vs the top so I
stuffed the gap with a little bathroom rug to at least keep the air
from circulating between inside and outside.
The humidity sensor is one of those cheap Honeywell units you use
around the house. It has a range of maybe 75 feet. No computer
logging. If I could get a logging unit cheap I'd take more systematic
measurements. I also made a suspended tarp "carport" next to my
garage for the trailer to sit under partly to keep the sun off but
mostly so I don't have to spend hours buffing out the stains from tree
sap and bird poop that find the top. So far it works great and I don't
have to worry about temperature extremes.
It was easier when I kept the trailer in a hanger in the high desert,
but I think I've got the new situation under control finally.
9B
Old December 12th 10, 01:27 AM posted to rec.aviation.soaring
Darryl Ramm
humidity is 22%.
9B
well for you.
Darryl
measurements. *I also made a suspended tarp "carport" next to my
9B
The fiberglass top trailers or maybe just being 15m may be different.
On my 18m aluminum top trailer there was dust inside on windy days and
that lead to investigation and you could see dusty areas on top of the
lower rubber seal on the trailer where the dust had been blowing
through a gap and crawling around inside with the lid closed you can
see where the small gaps where the lid is bowing.
Darryl
Old December 12th 10, 05:07 AM posted to rec.aviation.soaring
brianDG303[_2_]
humidity is 22%.
9B
well for you.
Darryl
9B
Darryl
Just as a discussion, I have had some experience trying to make even
quite small containers (art exhibit display cases) dust tight with a
notable lack of success, both by me and others I have observed. As
you seal the container, you don't actually change the amount of air
circulation, I suspect; you just change the velocity of the air at the
inlet points you can't close up. I am sure there is some benefit to
sealing, but to make a display case dust tight you seal up what you
can, then provide positive pressure through a lot of filters, or in
less critical situation just provide a lot of filter surface area to
lower the resistance of the filtered air. The problem is that
temperature differences inside to outside create air pressure
differences that push the air in and out. Perhaps a solution is to
seal up the trailer really well and then provide a source of inlet air
that is drawn across a long desiccant tray or something.
Brian
Old December 12th 10, 05:15 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Maybe you need "ballast". Make the trailer airtight, but run a vent tube
from it to a plastic garbage bag half full of air: when the trailer
"breathes" it just moves air in and out of the garbage bag, and soon the
dehumidifier has all the trailer air (and bag air) dry, dry, dry!
email me)
Blue Angels back in Pensacola - practice session - no humidity means little vapor Pensacola Beachcomber Aviation Photos 0 March 23rd 08 04:29 PM
Blue sky and high humidity with aircraft at Mach 0.97 12Sep07 Tom Callahan Aviation Photos 2 September 14th 07 04:54 PM
Beating Nausea S Culver Aerobatics 5 January 30th 07 10:41 PM
Bush and the neocons beating war drums for attack on Iran [email protected] Naval Aviation 1 April 6th 06 06:56 PM
air humidity Corrie Home Built 2 January 19th 04 03:07 PM
