#11
TOST Tow retractor systems are on my website catalog page
http://www.wingsandwheels.com/page31.htm Hundreds in use! tim Please visit the Wings & Wheels website at www.wingsandwheels.com "bildan" wrote in message ... On Dec 20, 5:29 am, Tom wrote: "Some operators thread a tost link and a Schweizer ring on the same end of the tow rope. " Two tow rings on the end of the tow rope makes it heavier, and will fly lower behind the towplane making it more likely to hit objects on the ground. Tom Knauff There are lots of really neat stuff in the Tost catalog - including a tow rope retract winch. The late Fred Robinson installed them on his Pawnees. The resulting increase in operational efficiency from shorter landings and taxi-backs equaled a third tow plane, he said. Tost also had a really neat connect/disconnect system which allows quick change of rings and weak links. This also adds to efficiency in that the "crawl under and hook-up" protocol can be done before the tug arrives with the rope snapped onto the weak link/ringset leader in seconds. Finally, use only the correct ring/ringset. Any other combination is a significant risk not worth trying for a bit of convenience. __________ Information from ESET NOD32 Antivirus, version of virus signature database 5718 (20101220) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5718 (20101220) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
On Dec 19, 3:09*pm, " wrote:
I am wondering if anyone has experience both physical and legal in rigging Schweizer gliders to be towed with tost rings I have thought about modifiying the moving part of the tow hitch (making it narrower). I have also thought about installing tost hitches on the glider. We waste a lot of time switching the weak link end to end. Bill Snead I would not do any filing to change the Schweizer hook. There is an AD on the hook which specifies certain demensions. I do not think that "width" was one of the demensions, I would have to check the AD.. but the size and profiles of the "step" in the hook are specified. If the hook does not meet the AD specifications, then the hook will not pass the inspection and cannot be used. We use a 7/16 3 ply ploy tow rope with eye splices, changing out the weak link for the proper Schweizer or Tost ring takes seconds. Two eye splices work wonders for quick change outs. T |
On Dec 20, 8:30*pm, T wrote:
On Dec 19, 3:09*pm, " wrote: I am wondering if anyone has experience both physical and legal in rigging Schweizer gliders to be towed with tost rings I have thought about modifiying the moving part of the tow hitch (making it narrower). I have also thought about installing tost hitches on the glider. We waste a lot of time switching the weak link end to end. Bill Snead I would not do any filing to change the Schweizer hook. There is an AD on the hook which specifies certain demensions. I do not think that "width" was one of the demensions, I would have to check the AD.. but the size and profiles of the "step" in the hook are specified. If the hook does not meet the AD specifications, then the hook will not pass the inspection and cannot be used. We use a 7/16 3 ply ploy tow rope with eye splices, changing out the weak link for the proper Schweizer or Tost ring takes seconds. Two eye splices work wonders for quick change outs. Thanks for for informative replies. Putting a Tost ring on a standard Schweizer would not be safe. It would probably jam on to the hitch. It does seem to me, however, that the moving part of the Schweizer hitch could be redesigned to safely accept a tost ring. I would suspect that getting the paper work approved by the FAA would require a major effort. Also, I would think that unless all Schweizers had the redesigned hooks it would cause confusion that might result in more small rings being hooked up to old Schweizer hitchs. 6W |
Commercial Rating for Towing Gliders not needed? in US | chris | Soaring | 22 | November 3rd 10 04:50 AM |
Auto Towing 2 Place Gliders | [email protected] | Soaring | 11 | April 21st 06 05:10 AM |
US FAR 61.113 Private Pilots Towing gliders for compensation. | Jackal | Soaring | 21 | January 23rd 05 04:37 PM |
Libelles & Tost Rings | nowhere | Soaring | 9 | July 21st 04 05:08 PM |
FS: Schweizer 1-34, Schweizer Open Trailer | F.L. Whiteley | Soaring | 2 | April 10th 04 02:52 AM |
