Towing Schweizer Gliders with tost rings?
Old December 19th 10, 11:09 PM posted to rec.aviation.soaring
Default Towing Schweizer Gliders with tost rings?
I am wondering if anyone has experience both physical and legal in
rigging Schweizer gliders to be towed with tost rings
I have thought about modifiying the moving part of the tow hitch
(making it narrower).
I have also thought about installing tost hitches on the glider.
We waste a lot of time switching the weak link end to end.
Bill Snead
Old December 19th 10, 11:33 PM posted to rec.aviation.soaring
Andy[_1_]
Bill Snead
Some operators thread a tost link and a Schweizer ring on the same end
of the tow rope. I would think that would be a lot better than an
illegal /unapproved modification to the tow hook. I suppose there is
some small risk that the big Schweizer ring could foul something when
the tost rings were in use.
Andy
Andy (GY)
Old December 20th 10, 12:15 AM posted to rec.aviation.soaring
vontresc
Bill Snead
of the tow rope. *I would think that would be a lot better than an
illegal /unapproved modification to the tow hook. *I suppose there is
Andy
Andy (GY)
We use a bridle with Tost rings for the Tost equipped gliders in our
club. The bridle simply loops through the Schweizer ring at the end of
the rope. Really doesn't take much time to switch out the bridle
unless you can't find it :-)
The other solution i've seen is to have both styles of rings at the
end of the rope. Either solution is way better than using incorrect
rings.
Peter
Old December 20th 10, 12:51 AM posted to rec.aviation.soaring
ray conlon
Bill Snead
Andy
Andy (GY)
rings.
Peter- Hide quoted text -
- Show quoted text -
NO NEVER use the wrong ring with ANY hook, I understand that a TOST
ring has been known to "jam" a Schweizer hook and make it un-able to
release.....I know someone who experienced this foul up because of a
"new" lineboy who had not been properly taught the difference. Their
is a sevice bulliten out since last year about tolerences for
Schweizer hook wear limits, check the K&L website.
Old December 20th 10, 01:19 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
Bill Snead
Andy
Andy (GY)
rings.
I can't begin to count the number of hookups I have done in the last year, both Tost and Schweizer rings. It only takes a few seconds to detach one weak link and attach another. I have run into a few guys hooking up who were relatively unaware of the need for different rings, amazing if you ask me. Operators need to insure that "volunteers" who are doing hookups are properly instructed on the procedure. I fly a 1-34 quite regularly and the only problem is finding the proper weak link when I am ready to go. I would never let someone try to hook up a Tost ring to a Schweizer hook.
Old December 20th 10, 12:29 PM posted to rec.aviation.soaring
Tom[_12_]
"Some operators thread a tost link and a Schweizer ring on the same
end
of the tow rope. "
Two tow rings on the end of the tow rope makes it heavier, and will
fly lower behind the towplane making it more likely to hit objects on
the ground.
Tom Knauff
Old December 20th 10, 02:30 PM posted to rec.aviation.soaring
Andy[_1_]
end
of the tow rope. "
the ground.
Tom Knauff
How can a rope with 2 ring sets be heavier than a rope terminated by a
Schweizer ring with a tost weak link added to the end?
Surely the only way to avoid the weight of 2 ring sets is to change
the whole tow rope. In any case I doubt the difference in rope droop
is significant and suspect it is probably more influenced by the type
of ball used to protect the rings.
It is, however, certain that if a weak link is added to the end of the
rope then the new end will fly lower by some fraction of the weak link
length.
This is probably only of academic interest except to those tow pilots
that consistently clear obstacles by a few inches. Those pilots will
appreciate the rope being exactly the same for each approach and
landing.
Andy
Old December 20th 10, 03:26 PM posted to rec.aviation.soaring
bildan
end
of the tow rope. "
the ground.
Tom Knauff
There are lots of really neat stuff in the Tost catalog - including a
tow rope retract winch. The late Fred Robinson installed them on his
Pawnees. The resulting increase in operational efficiency from
shorter landings and taxi-backs equaled a third tow plane, he said.
Tost also had a really neat connect/disconnect system which allows
quick change of rings and weak links. This also adds to efficiency in
that the "crawl under and hook-up" protocol can be done before the tug
arrives with the rope snapped onto the weak link/ringset leader in
seconds.
Finally, use only the correct ring/ringset. Any other combination is
a significant risk not worth trying for a bit of convenience.
Old December 20th 10, 04:43 PM posted to rec.aviation.soaring
Alpha One
Minor correction.
Two of Fred Robinson's Pawnees did have rope retract winches, but they
were not the Tost ones.
To email, replace contestid with the real thing. (spelled out)
Old December 20th 10, 04:56 PM posted to rec.aviation.soaring
bildan
On Dec 20, 9:43*am, Alpha One wrote:
Minor correction.
tow rope retract winch. *The late Fred Robinson installed them on his
Pawnees. *The resulting increase in operational efficiency from
Whose retract winches were they?
Commercial Rating for Towing Gliders not needed? in US chris Soaring 22 November 3rd 10 04:50 AM
Auto Towing 2 Place Gliders [email protected] Soaring 11 April 21st 06 05:10 AM
US FAR 61.113 Private Pilots Towing gliders for compensation. Jackal Soaring 21 January 23rd 05 04:37 PM
Libelles & Tost Rings nowhere Soaring 9 July 21st 04 05:08 PM
FS: Schweizer 1-34, Schweizer Open Trailer F.L. Whiteley Soaring 2 April 10th 04 02:52 AM
