#11
Good add Bill - I'd forgotten that my shop wouldn't let me laser cut the panel directly if I couldn't give them the chemical composition of the epoxy being used - out of fear of toxic fumes. That necessitated the use of a template router. If you can get a shop to let you laser cut the fiberglass directly you cut out the intermediate step and it all goes much faster. Also a lot easier to cut square holes and fine details that way.
Same process as the water jet - just a different tool. |
Hello,
I just purchased a 29. Thinking about a new panel. Does anybody still have the files ? I like the process of fitting it using the plastic first. I don’t like reinventing the wheel. Any help would be appreciated. Thank you Thanks! Jake |
I have one, I’ll email it tomorrow.
At 19:35 28 December 2018, wrote: Hello, I just purchased a 29. Thinking about a new panel. Does anybody still have= the files ? I like the process of fitting it using the plastic first. I= don=E2=80=99t like reinventing the wheel. Any help would be appreciated. = Thank you Thanks! Jake |
On Friday, December 28, 2018 at 7:35:46 PM UTC, wrote:
Hello, I just purchased a 29. Thinking about a new panel. Does anybody still have the files ? I like the process of fitting it using the plastic first. I don’t like reinventing the wheel. Any help would be appreciated.. Thank you Thanks! Jake Theres a drawing of all the different ASG29 panels on the Schleicher website |
Here's a link to a .DWG file.
https://drive.google.com/open?id=113...4zNb2IFuOZWkH_ Andy Blackburn 9B ________________________ Hello, I just purchased a 29. Thinking about a new panel. Does anybody still have the files ? I like the process of fitting it using the plastic first. I don’t like reinventing the wheel. Any help would be appreciated.. Thank you Thanks! Jake |
On Thursday, January 20, 2011 at 5:09:34 PM UTC-5, Larry Goddard wrote:
Trying to help a friend with instrument layout for a new panel. Anyone have a cad drawing of one of these? Larry Zero One I have one for the ASW27 in DWG. How do I get it to you? Gary "SQ" ASW27b |
Trying to help a friend with instrument layout for a new panel. Anyone have a cad drawing of one of these? Larry Zero One Larry, Not only do I have the CAD file, I have many instruments that have the back measurements. So, you can move them around at will in the cad file to see if they are going to fit in the panel. The fronts don't mean much in this job other than looking what will be in the air. The SN-10 comes to mind. Some instruments have inlarged backs beyond the standard. I will send all I have with it if you like. I do have DropBox if you want them. I can post the link Gary ASW27b 27-148 "SQ" |
PIK-20D Instrument panel | Solo | Soaring | 5 | February 15th 09 06:50 PM |
CAD drawing for DG instrument panel... | Marc Ramsey | Soaring | 5 | April 7th 06 07:12 AM |
Instrument Panel | ccwillwerth | Home Built | 7 | February 9th 06 02:15 PM |
DG-300 instrument panel | [email protected] | Soaring | 14 | January 29th 06 02:48 PM |
LS 6 b instrument panel | John Brenann | Soaring | 4 | November 19th 05 04:37 AM |
