Transponder antenna installations
Old February 6th 11, 08:18 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default Transponder antenna installations
On Feb 6, 11:12*am, jcarlyle wrote:
I understand your point - I saw those suggestions on my L2
instructions, laughed, and pitched it. Why should you pay for
transponder output just to heat up the antenna cable with outdated
RG-58, when low loss LM240 is only $0.70 more per foot? And if RG-58
is bad, RG-174 is 4 times worse...
-John
On Feb 6, 1:27 pm, JJ Sinclair wrote:
The instructions from Advanced Aircraft Electronics call for RG-58A/U
unless wire bundle size is critical where the smaller RG-174/U may be
used if length is held to 20 feet or less.
JJ- Hide quoted text -
- Show quoted text -
You're right John.................I'll disregard the manufactures
instructions and go with something I heard on ras.............
Yeah, right!
JJ
Old February 6th 11, 08:47 PM posted to rec.aviation.soaring
jcarlyle
Good point - everything on RAS is always suspect.
Would you believe an attenuation calculator from Times Microwave? See
http://www.timesmicrowave.com/cgi-bin/calculate.pl
Another option is to look up attenuation values on Newark and Allied,
since a manufacturer has a vested interest in lying. Oh, wait -
Advanced Airborne Electronics is a manufacturer...
-John
Yeah, right!
JJ
Old February 6th 11, 09:59 PM posted to rec.aviation.soaring
On Feb 6, 1:14*pm, "John Scott" wrote:
I installed an L-2 antenna with my transponder. *While my wings and tailboom
are carbon fiber, the nose of my glider is fiberglass. *I installed the L-2
vertically on the bulkhead that closes off the nose ahead of my feet. *I've
not noticed any effect on my other instruments in the panel or on my GPS
(CA302). *I have noticed that my feet still get cold at altitude, so I don't
think the power output is a problem. *The vertical orientation means my
glider is at the center of a very fat horizontal donut.
John Scott
We did an LS-3 this way with good results.
Cookie
Old February 7th 11, 03:19 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Yeah, right!
JJ, call AAE and ask about the LM240 cable. It might be their
recommendation was aimed at airplanes carrying 200+ watt transponders
and using shorter cable runs, compared to gliders that might using units
with 150 watts or less and long cable runs. Also, looking at the
transponder manufacturer's recommendation is probably a better
indication of what's needed than the antenna manufacturer. My Becker
instructions made quite a fuss about which cable to use.
Generally, I like to go the "good stuff" for transponders, as
attenuation per foot is much higher at transponder frequencies than our
communication radios frequencies (factor of 8).
email me)
Old February 7th 11, 04:55 AM posted to rec.aviation.soaring
Paul Remde
Hi,
The Trig TT21 and TT22 manual is also quite fussy about transponder antenna
cable. But it important to note that many of the "long run" antenna cables
they recommend are extremely expensive.
I recommend mounting the transponder unit (it is separate from the control
head) as close to the antenna as possible. When that is done I have
received customer feedback that RG-58 cable works fine - with all required
tests passed with flying colors.
Paul Remde
Yeah, right!
recommendation was aimed at airplanes carrying 200+ watt transponders and
using shorter cable runs, compared to gliders that might using units with
150 watts or less and long cable runs. Also, looking at the transponder
manufacturer's recommendation is probably a better indication of what's
needed than the antenna manufacturer. My Becker instructions made quite a
Generally, I like to go the "good stuff" for transponders, as attenuation
per foot is much higher at transponder frequencies than our communication
Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email
me)
Old February 7th 11, 03:18 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
On Feb 6, 9:57*am, jcarlyle wrote:
JJ, please don't use RG-58 for a transponder cable - it has very high
attenuation per foot. Times Microwave LM240 is a much better choice,
with only 1/3 of the attenuation of RG-58 at 1 GHz. I usually use
Times Microwave LM300, with only 1/4 the attenuation of RG-58, but it
has double the diameter. Both of these cables have a greater than 20
year life outdoors.
-john
On Feb 6, 9:07 am, JJ Sinclair wrote:
I second the L-2, di-pole antenna suggestion, all inside with nothing
sticking out to get ripped off. Carve a1"X 1"X4" balsawood block so
that it matches the inside curve of your non-carbon fuselage, then
glue the antenna vertical to the flat side and the curved side to the
inside aft fuselage. *Keep it about 6" away from metal objects like
your elevator push-rod, etc. Secure the RG-58 lead so that it can't
get tangled with controls and you're good to go.
Hope this helps,
The Becker 4401-175 manual does say that RG-223/U is preferred over
RGU-58, but it doesn't mention LM-240? As a mechanic I am bound to
follow the appropriate tech data. Does LM-240 use the same BNC
fittings I have in stock? Can I use my crimper? What would my log book
entry say? Installed Becker 4401-175 transponder in accordance with
opinions found on ras?
:) JJ
Old February 7th 11, 04:46 PM posted to rec.aviation.soaring
Willy VINKEN
On Mon, 7 Feb 2011 06:18:57 -0800 (PST), JJ Sinclair
year life outdoors.
-john
Hope this helps,
:) JJ
'Aircell 5' is a good substitute for plain vanilla RG 58/U coax
cable.
It fits standard BNC connectors.
Attenuation at 1000 MHz is about 32 dB/100m (compared to 54 for RG58)
Willy VINKEN -ON5WV-
Old February 7th 11, 09:27 PM posted to rec.aviation.soaring
Grider Pirate
year life outdoors.
-john
Hope this helps,
:) JJ
*'Aircell 5' *is a good substitute for plain vanilla RG 58/U coax
cable.
Willy VINKEN *-ON5WV-- Hide quoted text -
....and Aircell 5 IS listed in the manual for the Trig transponders.
RG-58 is not.
Old February 7th 11, 11:00 PM posted to rec.aviation.soaring
jcarlyle
Trig is probably “fussy” because they think you should deliver the
transponder power to the antenna, not use it to heat the cable. I
think it's significant that Trig doesn’t specify the use of RG-58 at
all.
Aircell cables are European, they aren’t easily available in the US,
and would be expensive if you could order them. Attenuation for
Aircell 7 (the best cable recommended by Trig) is 6.9 dB per 100 feet
at 1 GHz. US made LMR300 is even better, it has an attenuation of 6.4
dB per 100 feet at 1 GHz. LMR240 comes in with a bit higher
attenuation at 8.0 dB per 100 feet at 1 GHz.
As for cost, 15 feet of bare LMR240 is $13.35. You can get a complete
LMR240 cable made with a TNC at one end and a BNC at the other for
only $30. Doesn’t seem outrageous.
-John
On Feb 6, 10:55 pm, "Paul Remde" wrote:
Hi,
Paul Remde
Old February 7th 11, 11:07 PM posted to rec.aviation.soaring
year life outdoors.
-john
Hope this helps,
:) JJ
cable.
RG-58 is not.
We use RG 400 for our transponder antenna cables. Trig says it is
good for up to 8'4".....(So does Garmin.)
Since you can mount the trig transmitter box wherever you need,
staying less than 8' is easy.
Cookie
Transponder Antenna Rick Fuller Soaring 6 January 30th 08 07:03 PM
Transponder Antenna Location [email protected] Soaring 15 January 17th 08 07:56 PM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 05:29 PM
Oil on transponder antenna Bob Owning 12 May 9th 04 09:59 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 04:32 AM
